G4 1.6 FSI knocking shortly after start?
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post10-01-2012, 10:55    Subject: G4 1.6 FSI knocking shortly after start? Quote
Hello, I have a G4 1.6 FSI engine ("BAD" code). The car makes a knocking/rattling noise for about the first 2 seconds after starting the engine, but then it sounds fine.
I read that it might be the variable valve timing unit.
What do you think? What would the cost of such a repair be at a workshop?
Thank you, Sven.
Translated on 09-07-2026, 5:21.
comco
Karma: +1 / -3   Thank you, like it!
Registered VCDS User
Post11-01-2012, 0:38    Subject: G4 1.6 FSI knocking shortly after start? Quote
Sometimes, FSI engines exhibit a rattling noise, which can also be caused by the timing chain.
The chain replacement, including the chain tensioner, costs approximately from 900 euros.
Please definitely check (or have checked) the oil pump, especially if the noise occurs when the engine is warm or immediately after starting it.
Bye
Jürgen
_________________________________________
Für den Spass/Winterauto: Audi TT Q und die Arbeitstier: Octavia 2 RS,
Für noch mehr Spass: R1200S, Laverda Formula, SV 1000 und NSU MAX
Translated on 09-07-2026, 5:22.
HerrBart
Post16-01-2012, 17:02    Subject: G4 1.6 FSI knocking shortly after start? Quote
The problem is known to Volkswagen. It is indeed related to the camshaft timing system. In cases of extreme noise, it can be replaced, which may reduce the noise, but may not eliminate it completely.
scrdel
Post22-01-2012, 16:29    Subject: G4 1.6 FSI knocking shortly after start? Quote
Thank you for your responses.
Sven.
Translated on 09-07-2026, 5:23.
Hornetdream
Post25-04-2012, 20:51    Subject: G4 1.6 FSI knocking shortly after start? Quote
Regards
Unfortunately, I have to disagree with that, even though the post is quite old...
We had already helped 4 customers with rattling problems in our workshop.
The rattling sound, as I mentioned, is coming from the chain hitting the steering housing... in the upper area...
All 4 motors were completely silent after the chain, guide rails, and wheels were replaced!
Translated on 09-07-2026, 5:24.
scrdel
Post25-04-2012, 22:16    Subject: G4 1.6 FSI knocking shortly after start? Quote
... what did the fun cost the customers?
Sven.
Translated on 09-07-2026, 5:25.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Check Engine Light On After Start? Diesel Engine Technology
No new posts Charging indicator light goes out briefly after engine start Diesel Engine Technology
No new posts TDI No Power After Start - Troubleshooting Diesel Engine Technology
No new posts Engine Spin-Up After Start Diesel Engine Technology
