STG Comfort Issues: Communication Problems Solved
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post30-03-2012, 22:27    Subject: STG Comfort Issues: Communication Problems Solved Quote
After I forgot to turn off the light, the ARL (Automatic Range Lighting) didn't turn on, and the battery was practically dead. Since then, the central locking only works on the driver's door. icon_eek.gif Even when pressing the key or remote control twice, only the driver's door opens. icon_confused.gif Well, let's check the error memory with VCDS - no luck.
Comfort control unit (STG) failed? All other control units (MSTG), airbag, brake control unit (STG), etc. are functioning properly and can be read without issues.
 Kommunikationsproblem mit Komfortsteuergerät.
 File size:  243.04 KB
 Viewed:  1966 times
Translated on 24-10-2026, 2:20.
Post30-03-2012, 22:54    Subject: STG Comfort Issues: Communication Problems Solved Quote
Hello Kai,
You could try disconnecting the battery completely and waiting for a while.
If it still doesn't work, please send me a private message.
Edit: The problem might be related to the bitrates being used, but it can be fixed.
Translated on 24-10-2026, 2:21.
Post03-04-2012, 21:06    Subject: STG Comfort Issues: Communication Problems Solved Quote
Update: The problem is likely related to the wiring harness or the comfort control module.
Translated on 24-10-2026, 2:22.
Post04-04-2012, 21:35    Subject: STG Comfort Issues: Communication Problems Solved Quote
Consider that the comfort control unit (STG) is likely located in the dry area behind the fuse box. Does anyone have a similar unit with the part number mentioned above?
Post18-04-2012, 17:33    Subject: Solved: [Problem/Issue] Quote
Update:
Used kidney transplant from a deceased insect performed on a Spanish recipient.
Does it now work perfectly icon_lol.gif?
Post18-04-2012, 18:27    Subject: STG Comfort Issues: Communication Problems Solved Quote
Thank you for the feedback!
Translated on 24-10-2026, 2:23.
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
No new posts PLC Communication Problems On-Board Diagnostics (OBD)
No new posts VAGCOM: Communication Problems Diesel Engine Technology
No new posts GRA Communication Issues: Engine & Body Control Units Diesel Engine Technology
No new posts Smart Home Retrofit: Comfort Features Explained Transmission, Chassis, Body & Interior
