Hello Martin,
For questions like this, please always include a vehicle scan with details, so we know which car it is and what parts are installed and configured.
You have found the history of your coding operations in the directory C:\Kaufmann\VCDS-RKS-GER\Debug, specifically in the file CodingLog.txt.
With this, in conjunction with the
Autoscan, it should be possible to determine when your car was coded in what way, and which control units actually belong to your car.
If the CodingLog.txt file lists a control unit that is not actually installed in your vehicle (
Autoscan), it likely belongs to a different vehicle.
Or, you may have received a software update, which could also change the VAG part number (although I doubt this applies to your case). However, if that's the case, you can assume that the control unit was configured during the update to match the specifications for your vehicle.
