VAG-Com: Group 000 Not Working - Troubleshooting
alca
Post02-09-2003, 18:10    Subject: VAG-Com: Group 000 Not Working - Troubleshooting Quote
Hello professionals.
I could use a little tip.
I borrowed a VAG-Com 303 and I wanted to use the TDI-Graph, but I need to access group 000, but I can't. I get a warning message that it starts at group 001 and upwards.
Does anyone have any advice?
Okay, so I also tried version 2.28, and I was able to access group 000. However, when I go to the default values, I don't see a button to select the TDI graph.
Advice??
PS: I haven't found a better forum yet, and I'm still a beginner in this area, but thanks to your database, I've already been able to identify 2 issues with my car!
KEEP GOING LIKE THAT...........................
Translated on 28-08-2026, 4:13.
Michael II
Post02-09-2003, 21:01    Subject: VAG-Com: Group 000 Not Working - Troubleshooting Quote
If you had done some research, you would know that only the full version of VAG-Com...
indicates group 0.
Please always search first when you have questions like this.
Tschüss
Michael II
Translated on 28-08-2026, 4:15.
alca
Post03-09-2003, 7:35    Subject: VAG-Com: Group 000 Not Working - Troubleshooting Quote
hi
'Well, I already knew that from the full version, which I actually borrowed.'
but it still doesn't work!!
Even in version 2.28 (full version), the '000' group functions, but there is no button for the TDI Graph.
Michael II
Post03-09-2003, 8:00    Subject: VAG-Com: Group 000 Not Working - Troubleshooting Quote
Then, if I were you, I would contact the developer, Ross-Tech.
They are happy to provide information about the full versions.
Tschüss
Michael II
Translated on 28-08-2026, 4:16.
Gremlin
Post03-09-2003, 8:23    Subject: VAG-Com: Group 000 Not Working - Troubleshooting Quote
and even in version 2.28 (full version), the '000' group works, but there is no button with the 'TDI Graph' function there.
a little http://www.cheesebuerger.de/smilies/boese/41.gif would definitely be appropriate!
Then you would at least know that the TDI graph is only available from version 303.1 onwards.
CU Gremlin.
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Suspension Failure: Allroad Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J AC Repair: Troubleshooting Guide (99) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts GRA Retrofit: No Functionality On-Board Diagnostics (OBD)
No new posts Light/bell - no function Transmission, Chassis, Body & Interior
No new posts VW Auxiliary Heater Not Working - Troubleshooting Transmission, Chassis, Body & Interior
No new posts Audi A3 AC Not Working: 8P BKD Repair Guide Transmission, Chassis, Body & Interior
