Quote: |
The fuel pump assembly is even available in the bay, which suggests that it sometimes has problems.
Now, to my question: is there anything special I need to be aware of during the installation? |
It fills itself automatically. By the time you've put everything back together, there will be enough fuel in it to prevent it from running dry. Also, it prevents contaminants from entering the system, and it monitors the fuel level sensor.
Buy the Pierburg pump or an OEM (Original Equipment Manufacturer) pump.
I would avoid using a Chinagram.
