Camshaft Replacement Problems: AKE Issues.
luiggi
Post12-05-2012, 7:01    Subject: Camshaft Replacement Problems: AKE Issues. Quote
I replaced the camshafts in my AKE engine because they were severely worn.
Purchased the complete Campro set, so everything is included, like the Hydros, etc.
Okay, here's the translation:
"Now I have the following problem:"
After each cold start, the vehicle runs on fewer than all cylinders for approximately 15 minutes. This is manifested by a slight vibration and uneven engine running.
Once the car reaches its operating temperature, everything is perfect!
It definitely has to do with the opening of the valves, caused by the hydraulic lifters. When the engine is cold, oil likely leaks out of the hydraulic lifters, which is why I'm experiencing these problems.
Question: I heard that the 2.5L TDI engine has so-called oil return valves. Does anyone know about these, or can anyone tell me if this might be related to my problem?
Thank you.
Translated on 28-08-2026, 0:42.
Post12-05-2012, 10:04    Subject: Camshaft Replacement Problems: AKE Issues. Quote
Hi Luiggi,
You say
. It definitely has to do with opening the valves through which the hydros
flow.
Do you hear the lifters or valves rattling?
A collapsed hydraulic lifter makes itself noticeable with a distinct, loud rattling sound that increases with engine speed.
If that's the case, remove the valve cover, rotate each cylinder to its top dead center (TDC) one by one, and locate the culprit by pressing down on the valve lifters.
You can already locate the affected cylinder using VCDS (by checking the long-term fuel trim values).
If there is no noticeable noise, the timing would be the first thing to check after the repair.
Translated on 28-08-2026, 0:44.
Post12-05-2012, 13:17    Subject: Camshaft Replacement Problems: AKE Issues. Quote
flow.
Or, if there are no rattling or clicking sounds, and everything else seems correct, then it's likely okay to close it.
Translated on 28-08-2026, 0:46.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Leistungsmangel nach Nockenwellentausch beim V6TDI Diesel Engine Technology
No new posts Was zusätzlich wechseln bei Nockenwellentausch Audi V6 TDI Diesel Engine Technology
No new posts Looking for instructions on how to replace the camshaft o... Diesel Engine Technology
No new posts Problems after renovation... Diesel Engine Technology
