T4 Injection Pump
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post20-06-2012, 19:16    Subject: T4 Injection Pump Quote
What is the difference between the distributor injection pump from the ACV (75 kW) and the AHY (111 kW) engines? Since the part numbers from VW and Bosch are different for these two pumps, I assume that different internal components are used.
What does the part number indicate? VE5/11E1750L777 and VE5/11E1750L714-1.
Unknowingly, my friend had a refurbished pump installed, without specifically asking whether that pump had the correct internal components for the AHY icon_sad.gif.
The type plate is not visible when the device is installed, and it is also possible that the internal components (e.g., the rotor...) do not match the information on the type plate.
After the pump was installed, the usual performance was not present. The "experts" quickly "adjusted" the MSW, and the performance was somewhat okay, but above approximately 3000 RPM and under load, things get very dark in the rear icon_peinlich.gif.
In my opinion, the ACV pump needs to be removed and slapped in the face of that idiotic pump manufacturer.
reflexsilber met.
Translated on 26-10-2026, 0:30.
RedR32
Avatar-RedR32
Post20-06-2012, 21:51    Subject: T4 Injection Pump Quote
Okay, here's the translation:
"By the way, the Bosch catalog says:"
Description: Distributor injection pump -
Order number: 0 460 415 985 -
Naming: Distributor injection pump -
Manufacturing setting - -
Type formula: VE5/11E1750L777 -
! Bosch part numbers with trailing letters indicate variants; see SIS documentation.
Article Status: Discontinued.
Exchange number: 0 986 440 571.
Can someone explain this to me in more detail?
reflexsilber met.
Translated on 26-10-2026, 0:32.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts CAV Injection Pump Diesel Engine Technology
No new posts Fuel Injector AFN Diesel Engine Technology
No new posts SDI Fuel Injector: Performance & Reliability On-Board Diagnostics (OBD)
No new posts Injection Pump 1Z - Buy Now! Diesel Engine Technology
