Does anyone know about Ardic parking heaters?
vagtuning
Post06-12-2005, 14:58    Subject: Does anyone know about Ardic parking heaters? Quote
NEVER BUY SUCH JUNK!
How can a company be allowed to produce such nonsense publicly?
'A starter motor that permanently locks the control unit after three failed attempts, and even prevents diagnostics without replacement, should, in my opinion, be banned!'
Affected: A4, model year 2005, 1.6 gasoline engine...
Simmerring
Registered VCDS User
Post09-07-2012, 22:03    Subject: Does anyone know about Ardic parking heaters? Quote
Unfortunately, that's true, but I was lucky; I have a "new" Audi A4 from the year 2002.
"It also has an Ardic system installed, which was added later, so it's not readable via VCDS (if that was even intended)."
The part also wasn't working, and no one could diagnose the problem. I called Eberspächer, and they said you can "free of charge" borrow the original Ardic tester from Eberspächer in Torgelow for 10 working days. (A deposit of +1200€ is required, with €0 for shipping via cash on delivery + €6.50 for return shipping).
I had previously opened the heating system completely and checked all the components, and everything seemed to be in good order.
After clearing the error codes, it runs perfectly, and according to the diagnostic device, it has only been running for 56 hours since it was installed in 2002, up to 2012. I find the quality of the heater to be very good (everything is stainless steel, and it's simply designed), except for the problem with the control unit.
Too bad, because then it would have been a heating system that would last forever.
It is also possible to send in the control unit, but I don't know how much that will cost.
Before giving up or starting over, try to diagnose the problem.
For those who are interested, I have attached some documents.
Ardic.pdf
 Betriebszustände
Betriebszustände
 File name:  Ardic.pdf
 File size:  636.7 KB
 Downloaded:  1550 times
Ardic Fehlercodes.pdf
 File name:  Ardic Fehlercodes.pdf
 File size:  939.38 KB
 Downloaded:  2317 times
No new posts Diagnose von Eberspächer Standheizungen Troubleshooting & Guides
No new posts Diagnose nachgerĂźsteter Webasto Standheizungen Troubleshooting & Guides
No new posts 1Z Compression Specs: Does Anyone Know? Diesel Engine Technology
No new posts Kennt sich jemand mit Opel TD's aus ? Diesel Engine Technology
No new posts Kennt jemand die Unterschiede zwischen 1z und afn-Motor?? Diesel Engine Technology
No new posts Steigender Leerlaufverbrauch. Kennt das Jemand? On-Board Diagnostics (OBD)
