I want to have the Lima (likely referring to a specific component or system) externally tested. The reason is that the AFB (likely referring to a specific process or equipment) requires a long installation/removal time.
Okay, I got the Lima and connected it using a jumper cable.
Connect the battery. Attach the positive (+) wire to the B+ terminal and the negative wire to the chassis.
Multimeter connected to a battery and then to a drill.
Increase the speed.
It doesn't work like that
12.8 V
The Lima still has a DFM and an L socket.
Okay, I've taken a diode test lamp, connected it to B+ and then to L.
Increased speed - still nothing.
The LED doesn't light up at any time. Should she not?
'When the lime is standing still?'
Does the Lima need to have a connection from DFM to MSG?
Or is the load of the diode test lamp too low?
It wasn't enough - I didn't want to build a bridge directly.
Unfortunately, I don't have a regular test lamp available right now...
Or, as expected, will the Lima also make it?
Ideas?
