Tire Noise Front Right?
yomam
Post12-04-2003, 15:58    Subject: Tire Noise Front Right? Quote
Hello everyone!
Today I put summer tires on my Volkswagen Golf 3 TDI (81 kW), and now I'm having the following problem:
A squealing or grinding noise can be heard from the front right side of the car, especially when taking left turns, which puts stress on the right side of the vehicle.
What does a faulty wheel bearing sound like, and is there an easy way to check it?
'There's nothing to hear when taking right-hand turns... maybe it's just the tire tread pattern (but that would be very strange).'
Best regards, D.
Translated on 22-08-2026, 1:13.
Andy
Post12-04-2003, 18:08    Subject: Tire Noise Front Right? Quote
It sounds like a wheel bearing problem. The best way to confirm this is to jack up the car and spin the wheels.
Best regards, Andy.
Translated on 22-08-2026, 1:14.
Markus H.
Post13-04-2003, 20:44    Subject: Tire Noise Front Right? Quote
That's right, it's probably a faulty wheel bearing.
What is the mileage on this vehicle?
It's just strange why this noise suddenly appears after the tire change. icon_question.gif icon_question.gif
Interestingly enough, the same thing happened with my Volkswagen Golf.
Translated on 22-08-2026, 1:15.
yomam
Post13-04-2003, 21:14    Subject: Noise Reduction: How to Eliminate Annoying Sounds Quote
Hello!
The Golf has now accumulated a mileage of 145,000 kilometers.
So far, I haven't had any problems with wheel bearings or anything else, but with this mileage, it could certainly happen.
On Wednesday, I'm getting two new tires put on the front. And if the noise is still audible after that, I'll go straight to the workshop.
It's strange that I didn't hear anything at all from the winter tires.
I'm sure I wouldn't miss a sound like that. Surely something like that can't just happen from one minute to the next...?
Thank you and best regards.
D.
Translated on 22-08-2026, 1:16.
Andy
Post13-04-2003, 21:22    Subject: Tire Noise Front Right? Quote
Well, firstly, winter tires are usually noisier anyway, so you hear fewer background noises. Secondly, I would guess that the wider summer tires, depending on their offset, exert more force on the bearing.
Best regards, Andy.
Translated on 22-08-2026, 1:18.
yomam
Post13-04-2003, 23:17    Subject: Tire Noise Front Right? Quote
Hello again.
I swapped the rear tires to the front – still no difference. It's probably the bearing, unfortunately.
Andy, how are you satisfied with your GTI-TDI?
Mine is a GT-TDI Special model, manufactured in November 1996 – they might have even been seen in Wolfsburg (or elsewhere)...
Have you experienced any major problems so far?
Best regards, D.
Translated on 22-08-2026, 1:19.
Andy
Post14-04-2003, 0:22    Subject: Tire Noise Front Right? Quote
Yes, that's right, my JUBI was built in WOB.
So far, I haven't had any major problems.
I bought it in November 2001 with 119,000 km on the odometer, and currently it has 153,000 km.
I have fixed the design flaw in the vacuum sensor for the VTG system.
The electric folding mirror on the driver's side was repaired (it was already defective when purchased).
I also replaced the radiator; it was only leaking a little, but I don't like doing things halfway like using a radiator sealant.
Everything else falls under wear and tear items or unnecessary repairs: timing belt, brakes, oil, filters, suspension, cruise control, etc.
Best regards, Andy.
Translated on 22-08-2026, 1:20.
yomam
Post14-04-2003, 22:08    Subject: Tire Noise Front Right? Quote
Hello!
It turns out the wheel bearing on the front right side was actually bad – I need to replace it. Otherwise, I've only had two solenoid valves fail so far.
'How much did the vacuum pump issue cost you? And can my auto repair shop install the new one without any problems (e.g., during a service) and at a reasonable cost?'
Did you notice any difference after that?
My automatic fuel nozzle sometimes regulates the flow too much at the top end, reducing the pressure a bit, then increasing it again, etc.
Best regards, D.
Translated on 22-08-2026, 1:22.
Andy
Post15-04-2003, 12:54    Subject: Tire Noise Front Right? Quote
The fun costs approximately 120 euros in materials.
The installation is usually very easy.
/* Start of annoyance */
The question is whether any workshop would do something like that for a low price. They're so quick to replace entire turbochargers just because of a stuck vacuum sensor.
/* Frustration out */
I can't tell you, I do everything myself.
Please read the following:
/viewtopic.php?t=171&highlight=vtg
/viewtopic.php?t=268&highlight=vtg
I got this part from motair.
After that, I noticed that the setting was working again, what a miracle icon_eek.gif icon_biggrin.gif, but it's also slowly becoming too much of a hassle.
Best regards, Andy.
Translated on 22-08-2026, 1:24.
zzzZZ
Post15-04-2003, 12:57    Subject: Tire Noise Front Right? Quote
With a little luck, you might find a defective charger with a large battery pack on eBay.
I bought one for 30 euros this weekend. I'll then put the small container on it and auction it off again.
If I can get another 20 euros for it, then it will have been worth it.
Translated on 22-08-2026, 1:26.
No new posts Doku 4-cylinder. TDI Clattering/Rumbling, Power Loss Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Acoustic Noise Analysis: Identifying and Locating Sources... General Tips
No new posts Doku Golf 5, Fahrzeug zieht nach links oder rechts Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Whining Noise Front Right, Golf 4 ALH Diesel Engine Technology
No new posts Motorgeräusch rechts vorne Sharan Diesel Engine Technology
No new posts Annoying Rumble: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Engine Vibration at Idle: Causes & Fixes Diesel Engine Technology
