2.0 TDI BKD engine, 100,000 km, experiencing misfires and loss of boost
servusssss
Karma: +12 / -0   Thank you, like it!
Post02-12-2012, 16:00    Subject: 2.0 TDI BKD engine, 100,000 km, experiencing misfires and loss of boost Quote
Hello fellow DIY enthusiasts,
I'm having trouble with the BKD engine again.
To begin with, this vehicle does not have any coolant leaks, and the intake manifold flap (V157) is new.
The car jerks when accelerating, starting from 2nd gear. Speed from approximately 2000 RPM.
So, I plugged in VCDS and, lo and behold.
The following information is stored in the error memory:
17058 - Spark plug, cylinder 4 (Q13)
P0674 - 000 - Electrical circuit fault.
Environmental conditions:
Speed: 1029 RPM
Torque: 122.0 Nm
Speed: 0.0 km/h
Last: 0.0%
Voltage: 11.10 V
Binary value: 00101111
Temperature: 4.5°C
Binary value: 01110000
This spark plug will be replaced immediately, but I don't think this is the reason for the engine misfire.
Okay, so the usual suspects: Log entries 3, 8, and 11.
This indicated that the boost pressure in the upper range (from approximately 3500 RPM) was 200 mBar too low (see log file). As far as I understand, the AGR (Arbeitsgemeinschaft für relevante Informationen) is also incorrect.
Since I'm not a professional, is my assessment correct, or what's the opinion of the professionals?
I also logged the LMM, and it seems to be working correctly.
Next, I will check the intercooler pipes to see if there are any leaks.
What would you guess? Turbocharger (Variable Geometry Turbine), EGR valve?
I'm not entirely happy with the LOGs, as I did this on the snow-covered road.
"Thank you very much!"
Sure, here's the translation:
"SG Servusssss"
LOG-01-003-008-010LM.CSV
 Luftmassenmesser
Luftmassenmesser
 File name:  LOG-01-003-008-010LM.CSV
 File size:  10.24 KB
 Downloaded:  498 times
LOG-01-003-008-011_neu.CSV
 Logfile 3/8/11
Logfile 3/8/11
 File name:  LOG-01-003-008-011_neu.CSV
 File size:  19.44 KB
 Downloaded:  480 times
Post03-12-2012, 17:34    Subject: 2.0 TDI BKD engine, 100,000 km, experiencing misfires and loss of boost Quote
The boost pressure is generally relatively low before it drops. Is your vacuum system okay, and is there perhaps a vacuum hose that has been chewed through or a membrane that has been torn (e.g., the VTG adjustment on the turbocharger, swirl flaps, etc.)?
servusssss
Post03-12-2012, 20:36    Subject: 2.0 TDI BKD engine, 100,000 km, experiencing misfires and loss of boost Quote
First of all, thank you for the response!
I replaced all the glow plugs, so the error memory is now clear.
The stuttering/jerking/shaking hadn't gone away.
Okay, I've checked the entire intercooler piping system, and I haven't found anything.
Then I checked the vacuum hoses, and lo and behold, one of the clips on the vacuum distributor (or whatever that thing is called) wasn't attached.
The stuttering is gone now, but I still created another log file.
The data looks normal to me, so the problem should be resolved.
"Best regards," or "Sincerely,"
P.S.: I had to do the logging on snow, so it wasn't ideal.
LOG-01-003-008-011_LOG_neu_1.CSV
 File name:  LOG-01-003-008-011_LOG_neu_1.CSV
 File size:  31.13 KB
 Downloaded:  482 times
LOG-01-003-008-011_LOG_neu_2.CSV
 File name:  LOG-01-003-008-011_LOG_neu_2.CSV
 File size:  28.97 KB
 Downloaded:  472 times
Post03-12-2012, 20:42    Subject: 2.0 TDI BKD engine, 100,000 km, experiencing misfires and loss of boost Quote
Yes, the logs are suboptimal because there's not much full throttle. icon_wink.gif But it looks much better.
Thank you for the feedback!
Post03-12-2012, 22:33    Subject: 2.0 TDI BKD engine, 100,000 km, experiencing misfires and loss of boost Quote
As an addition, because the spark plug error initially misled me.
The case of the 16V PD TDI engine being discussed here is something entirely different from that.
"8V PD TDIs are known to have a specific type of problem."
1 error found: [code]
005660 - Spark plug, cylinder 3 (Q12)
P161C - 000 - Interruption.
Error status: 01110000
Error priority: 3
Error frequency: 1
Mileage: 138,712 km
Time: 0
Date: 2000.00.00
Time: 11:52:44
Speed: 945 RPM
Speed: 0.0 km/h
Last: 3.1%
Voltage: 14.52 V
Binary value: 00101100
Temperature: 6.3°C
Binary value: 10110000
Here, the power rail broke.
It's located on the outside, along the head, just like it always has been on the 8V models.
Interestingly, it's ALWAYS the Q12 – now the third one in a row that I've randomly logged.
Perhaps the contact clip breaks because people are hitting it in the wrong place when changing the oil filter.
There's no noticeable shaking, and of course, replacing the crankshaft pulley won't fix the problem.
The solution is to replace the power supply's "antenna."
No new posts Golf 1J Clutch Pedal Not Returning Fully Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BPW Shaking on Audi A4 TDI: Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS control unit new, and coding always resets to 00 On-Board Diagnostics (OBD)
No new posts TDI Shudder: Causes, Solutions & Troubleshooting Diesel Engine Technology
No new posts AGR Cleaning: Flush After 100,000 km? Diesel Engine Technology
No new posts Clutch Pedal Return Slow: Troubleshooting Guide Transmission, Chassis, Body & Interior
