Brake Noise & Steering Vibration Above 120 km/h
oldewurtel
Post12-10-2012, 15:06    Subject: Brake Noise & Steering Vibration Above 120 km/h Quote
Hello fellow enthusiasts,
I would like to briefly share my experiences and solutions for a problem I've been dealing with for some time: brake shuddering and steering wheel vibration at higher speeds.
Brake shudder:
It kept getting stronger, even though I had replaced the brake discs on both the front and rear axles and checked for runout (less than 0.02 mm at the wheel hub or less than 0.06 mm at the brake disc).
The rattling occurred both at low speeds (when braking for a traffic light) and at higher speeds.
Steering wheel vibration:
It occurred at speeds of 120 km/h and approximately 170 km/h. The initial suspicion is an imbalance in the tires. Re-balancing them seemed to provide a slight improvement.
After a long highway drive, I was annoyed and spontaneously decided to buy a new set of tires because another balancing procedure didn't seem worthwhile, even though there was still about 3.5 mm of tread left.
The tires (Michelin, size 205/55 R16) were just under 6 years old.
With the new tires (Bridgestone, 205/55 R16), the car drives 'like new.'
The steering wheel vibration is completely gone, and the brake judder is no longer present! icon_idea.gif
The running smoothness of the entire vehicle is much better.
Here, the combination of (slight) imbalance and hardened rubber (after six years icon_twisted.gif) was likely the trigger.
Best regards, Oldi.
Translated on 30-07-2026, 15:55.
Post12-10-2012, 16:53    Subject: Brake Noise & Steering Vibration Above 120 km/h Quote
Thank you for the information.
Our golf game is starting to get rusty again.
It disappeared after I decided to replace the front brakes, including the rotors and pads. Now it's starting again.
Since I'm planning to switch to winter tires soon anyway, I will pay more attention to making a change.
While I'm comparing the Devil and Beelzebub regarding the age of the shoes on the rubber-soled city runner icon_redface.gif.
Translated on 30-07-2026, 15:59.
Post12-10-2012, 18:59    Subject: Brake Noise & Steering Vibration Above 120 km/h Quote
The combination of (slight) imbalance and hardened rubber (after six years icon_twisted.gif) was likely the trigger.
... or were tires with wear patterns/sawtooth formations from being used on the rear axle (for too long) transferred to the front axle?
Translated on 30-07-2026, 16:00.
Post14-10-2012, 21:31    Subject: Brake Noise & Steering Vibration Above 120 km/h Quote
OK.
The switch from SR to WR didn't change anything.
The brake discs/pads are 2 years and 15560 km old - so they have been used mostly for short distances icon_sad.gif.
Today, I felt that after driving about 120 kilometers on a rural road in the rain, the tires started to feel a bit less smooth.
So, I'll be taking the brakes apart soon, when I have some time, to remove the pads and clean them.
Translated on 30-07-2026, 16:01.
Post14-10-2012, 22:03    Subject: Brake Noise & Steering Vibration Above 120 km/h Quote
...I would first brake properly and see what happens icon_smile.gif!!!!
Translated on 30-07-2026, 16:02.
Post15-10-2012, 9:00    Subject: Brake Noise & Steering Vibration Above 120 km/h Quote
Okay, I've translated the text. Here it is:
"I have done this!"
The hazard lights turned on icon_cool.gif.
It's not quite right... but I'm still playing around with it.
Karma: +1098 / -0   Thank you, like it!
Post15-10-2012, 9:23    Subject: Brake Noise & Steering Vibration Above 120 km/h Quote
Try this: First, warm up with a light pedal pressure, then apply strong braking force when continuing on your way without being affected. Then, brake forcefully one to three times, and afterwards, while continuing, delay the cooling process by applying very slight pressure. Gradually reduce the pressure, and if necessary, repeat the process as described above.
The slower the cooling process after hard braking, the better it works. Important: Never come to a stop with hot brakes and keep your foot on the brake pedal!
Translated on 30-07-2026, 16:03.
No new posts Glow Plug Information: Types, Function & More Technical Articles
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts White smoke and misfire on 2.0 TDI engine On-Board Diagnostics (OBD)
No new posts Golf IV 1.6 AKL - slight jerking/hesitation Gasoline Engine Technology
No new posts V6 TDI BDH: Slight vibration after DK change. Diesel Engine Technology
No new posts Whistling after timing belt replacement Diesel Engine Technology
