Car Vacation Checklist: Essential Vehicle Prep (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Post08-11-2012, 18:26    Subject: Car Vacation Checklist: Essential Vehicle Prep Quote
The following points should be checked on the vehicle before starting a vacation trip:
1. Tires.
__ Visual inspection for damage.
Sufficient tread depth.
Air pressure is okay, possibly adjust according to load.
Spare tire, inflated with compressed air.
Condition: Repair kit / Sealant.
2. Powertrain, Electrical System, and Chassis.
Suspension springs are in good condition and not broken.
Are the ball joints and tie rods free of play?
Constant velocity joint boots: Sealing.
__ Engine: Visual inspection for fluid leaks.
Engine: Check oil level.
Next service for the vehicle?
Power steering: Leakage and fluid level.
Coolant: Fluid level.
Coolant (for winter): Is the antifreeze level okay?
Battery: If present, are the fuse holders secure?
Does the lighting system work?
__ Horn __
3. Braking system.
Wear on front and rear brake discs and pads.
Brake hoses and brake lines.
Fluid level of the braking system.
__ Especially important in mountainous areas or when using a caravan: Check the boiling point of the brake fluid and replace it if necessary!
4. Accessories.
Orange safety vest.
__ Alcotest (France)
Spare light bulbs and fuses.
__ Windshield washer fluid (Winter: windshield washer fluid with antifreeze, ice scraper, de-icer, folding shovel, snow chains if necessary).
The "Dieselschrauber Vehicle Holiday Checklist" was created based on a suggestion from Octavia_4x4, thank you very much!
Translated on 28-10-2026, 13:24.
Ratings - Car Vacation Checklist: Essential Vehicle Prep
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings
No new posts Document: MKB AKF, Vehicle vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document Transporter 7D, vehicle braking unevenly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z Inspection Checklist: What to Check at 160,000 km Diesel Engine Technology
No new posts Install AHF in AFN Vehicle? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Lifting the vehicle Transmission, Chassis, Body & Interior
No new posts Lift Kit: Raise Your Vehicle's Height Transmission, Chassis, Body & Interior
