Hi everyone.
My steering feels quite vague, even with the 225-series tires.
Now I've tried spinning the wheel, and I noticed that it has a "loose" feel.
So, if I sit directly in front of the wheel and push it towards the wheel arch (both top and bottom), I can feel it move about 1-2mm.
You can hear it too.
I experience the same issue when I touch and move the wheel on the sides.
What could that be?
Wheel bearings?
Tie rod?
Ball joint?
"Addendum:"
Shock absorbers, springs, strut mounts, sway bar links, stabilizer bar bushings, rubber bushings for control arms, ball joints, and tie rod ends have already been replaced throughout the year.
Therefore, I suspect it's more likely to be a tie rod or a wheel bearing.
I don't want to exchange both, but I don't want to end up looking foolish
