DPF Full: 3.0 TDI (ASB/CDYA) - When to Replace?
Post29-10-2012, 23:37    Subject: DPF Full: 3.0 TDI (ASB/CDYA) - When to Replace? Quote
The 2.0 xPD corks are considered "full" with a weight of 60g and can therefore be used as replacements.
Roughly speaking, at around 200,000 km, you can expect to have to dig deep into your pockets.
What is the limit for the 3.0 TDI ASB/CDYA engine? (The label file doesn't specify this, unlike with the 2.0 engines).
This question mainly arises when buying a used car, especially if the DPF (Diesel Particulate Filter) needs to be replaced just 2 months after the purchase.
Greetings.
Translated on 22-10-2026, 4:51.
michiglaser
2007 Audi A4 Avant
Post06-11-2012, 20:15    Subject: DPF Full: 3.0 TDI (ASB/CDYA) - When to Replace? Quote
There was something written about 0.2 L: https://community.dieselschrauber.org/en/viewtopic.php?t=24798
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 22-10-2026, 4:52.
mullemaus
Post06-11-2012, 22:08    Subject: DPF Full: When Does It Happen on 3.0 TDI? Quote
This question arises especially when buying used cars, when the DPF needs to be replaced 2 months after the purchase.
12 months warranty when purchasing commercial property, with the first 6 months without a reversal of the burden of proof. This should therefore not be of interest to the buyer icon_wink.gif.
Post07-11-2012, 7:00    Subject: DPF Full: 3.0 TDI (ASB/CDYA) - When to Replace? Quote
Hm, isn't the DPF considered a wear and tear part?
Translated on 22-10-2026, 4:53.
Georg-TDI
Post07-11-2012, 11:55    Subject: DPF Full: 3.0 TDI (ASB/CDYA) - When to Replace? Quote
DPF is definitely a wear and tear item!
Where I wanted to buy my Passat with 149,000 kilometers on the odometer,
I have inquired with several sources (including several friends and the ADAC).
I've now driven 10,000 kilometers.
=> no oil consumption.
=> The ash content remains at 42.
Greetings, Georg.
Translated on 22-10-2026, 4:54.
Post07-11-2012, 12:00    Subject: DPF Full: 3.0 TDI (ASB/CDYA) - When to Replace? Quote
If the DPF is due for replacement soon, one could try to negotiate the vehicle price down by the cost of the replacement and then have the cleaning done oneself. icon_smile.gif
This is how you arrive at a very good hourly rate.
Post07-11-2012, 13:11    Subject: DPF Full: 3.0 TDI (ASB/CDYA) - When to Replace? Quote
Hi.
The A6 was bought last Saturday - I wasn't there.
Next Saturday, he will be "available," and I will soon be "connecting" with him... I'll let you know how it goes.
200ml as "full" - that's a valuable piece of information, thank you.
Translated on 22-10-2026, 4:55.
Tobi12345
Post07-11-2012, 14:55    Subject: DPF Full: 3.0 TDI (ASB/CDYA) - When to Replace? Quote
"For vehicles with an ash mass of <= 60 grams or <= 0.52 liters, the vehicle can be operated for an additional 30,000 km." Quote from ElsaWin.
This weight reduction of 60 grams applies to the 4-cylinder engines, while the 0.52-liter reduction applies to the 6-cylinder engines.
"On my A6 3.0 TDI with tuning, the ash mass is 0.20 at 127,000 km. Therefore, based on this, the DPF should reach the end of its lifespan at approximately 360,000 km."
A6 Avant 3,0TDI Tiptronic Bj. 02/2008
Translated on 22-10-2026, 4:56.
Aron
Karma: +5 / -1   Thank you, like it!
Post05-12-2012, 18:26    Subject: DPF Full: 3.0 TDI (ASB/CDYA) - When to Replace? Quote
dieselschrauber wrote:
Hm, isn't the DPF considered a wear part?
"Flush it out! Mine needs an additive change every 120,000 km, and I've had it done twice, then flushed. I didn't even have to remove the catalytic converter; I just tilted the thing upright and backwards, used a bucket of water, aimed from a high position, and poured a lot in quickly. I also tried using a Kärcher pressure washer once, but you have to be careful with the distance, and the flow rate and speed within the catalytic converter aren't ideal. A garden hose nozzle works just as well."
Using the Gardenamethode, I achieve the same differential pressure values as new, or as the original equipment manufacturer (OEM) automatic transmission (AT) filters, even with the same rotational speeds/mass airflow rates and air temperatures.
My second filter was also just an AT filter. Now, with the pre-cat in another vehicle, it's likely seen an estimated 400,000 km since its first service (120,000 km, where the service is officially taken over), and the exhaust is either spotless or, more likely, has rust deposits from the system in the stainless steel end pipes. I flush it out every 60,000 km. That way, you can save the 400€ for an AT filter or the 800€ for a new OEM one.
Experiences will show how long filter elements without additives should last, but I can only provide information for a filter that cleans at an ignition temperature of approximately 500°C.
Translated on 22-10-2026, 4:59.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 3.0 TDI CDYA - AGR valve stuck open at 99.6% + RPM fluctu... On-Board Diagnostics (OBD)
No new posts Audi A6 Engine Regeneration: CDYA Model Diesel Engine Technology
No new posts DPF full Diesel Engine Technology
No new posts CRMB 2.0 TDI Euro 6 DPF, approximately 242,000 km, fully ... Diesel Engine Technology
