DPF Light On Audi A3 (2011)? Fix It Now!
Go to page: 1, 2  Next
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post07-07-2012, 5:51    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
Hello everyone,
Just a quick question for the community. I recently discovered, to my surprise, that my A3 (manufactured in 2011), as listed in my profile, does not have a DPF warning light.
I've always assumed that everyone has one. But I can't seem to access it in the control panel, and there's no corresponding icon visible on the dashboard. So my question is: How does it indicate when its capacity is full?
I only have the glow plug symbol and this engine block pictogram...
Dirk.
Translated on 20-08-2026, 23:53.
Georg-TDI
Post09-07-2012, 15:40    Subject: DPF Light Off Audi A3 (2011): Troubleshooting Quote
'...Until now, I always assumed that everyone had one.'
Dirk.
Almost no one has it!
Only a few vehicles from the DHL fleet (and others) have these 'DPF cleaning' lights.
Translated on 20-08-2026, 23:54.
brezelmann01
Post09-07-2012, 20:32    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
To my knowledge, almost everyone has one...
I mean the LED that indicates when the engine needs to be turned off for a certain amount of time on the Autobahn (highway).
NOT the one that is currently in an active regeneration phase.
Translated on 20-08-2026, 23:55.
Georg-TDI
Post10-07-2012, 7:07    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
Okay.
Then you mean the light that indicates...?
that several consecutive active regenerations could not be completed successfully.
Translated on 20-08-2026, 23:56.
brezelmann01
Post10-07-2012, 7:59    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
Yep. Exactly.
Translated on 20-08-2026, 23:57.
Benni
Post10-07-2012, 15:13    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
Does the car have a FIS (fahrzeugintegrierter System)?
Then that would be the answer.
An arbitrary pictogram can be displayed there.
My Passat 3BG also didn't have a warning light either, only possibly an indicator in the FIS (which I never actually saw).
Georg-TDI
Post10-07-2012, 16:08    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
I used to have 3 cars with DPFs (Diesel Particulate Filters).
Volkswagen Golf 5, 1.9 liter TDI, first registration: March 2009, mileage: 84,000 km.
The new Passat B7 2.0 with 140 horsepower and common rail technology, first registered in December 2011, has been driven for 23,000 kilometers.
and current Passat B6 2.0 140hp CR, first registration: 02/2009, mileage: 60,000 km.
Everyone has a FIS account, and I've never seen anything suspicious either.
It was probably due to the good driving style icon_wink.gif.
Translated on 20-08-2026, 23:59.
brezelmann01
Post10-07-2012, 18:24    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
Yes, it has a FIS (Fault Information System). That would be an idea. You could essentially initiate a "self-check" that displays all available (?!?) FIS messages. It has the oil sensor and everything, but no DPF (Diesel Particulate Filter).
Then it would be interesting to know if anyone has ever seen a "dog walking" note in the FIS system, regardless of the vehicle model!
Translated on 21-08-2026, 0:00.
DieselBär30x
Avatar-DieselBär30x
Post10-07-2012, 18:41    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
If you initiate a forced regeneration using VCDS, the DPF MIL (Malfunction Indicator Lamp) or FIS (Fault Information System) message should appear during the process.
Best regards from Munich!
Translated on 21-08-2026, 0:01.
mullemaus
Post10-07-2012, 19:08    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
Post25-07-2012, 9:39    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
From Google searches, I know that Audi at least displays the DPF status with an icon in the color head-up display (HUD).
http://data.motor-talk.de/data/galleries/0/90/9167/38678185/203928151-w40-h40.jpg
The monochrome VWs do have the LEDs.
That could be the explanation (as mentioned before).
Translated on 21-08-2026, 0:02.
brezelmann01
Post25-07-2012, 20:36    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
Hmm. I don't have a color FIS. :-/
Post26-07-2012, 10:07    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
But you have VCDS, right?
Then try starting a regeneration cycle – the light will come on until it's finished.
And then you'll know where she lives.
Encode them, but only after you've left the city and are heading towards Adelheide or somewhere like that.
I always think it's annoying to wander around aimlessly in the city.
Translated on 21-08-2026, 0:03.
brezelmann01
Post26-07-2012, 16:07    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
Okay, I'll try that out sometime this week. By the way, I made a mistake above. The pictograms are actually in color, and he can display them on the FIS (presumably a car's information system). So...I'll post an update here as soon as I know more. Thanks for your help so far!!
Dirk.
Translated on 21-08-2026, 0:04.
brezelmann01
Post06-08-2012, 13:01    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
Sooo. Wollte heute mal ne manuelle Regeneration per VCDS starten. Leider wird bei mir von VCDS kein Zugriffs-Berechtigungscode angezeigt...Wie kommt man zu dem?! Rainer?!
Best regards.
Dirk.
Translated on 21-08-2026, 0:05.
Karma: +807 / -0   Thank you, like it!
Post07-08-2012, 16:05    Subject: DPF Light On Audi A3 (2011)? Fix It Now! Quote
Best regards.
Dirk
No new posts Taillight for trunk lid is dim Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Passat: ESP Light On - What to Do? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2002, No Power Steering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Light VW Golf III: Fix It Now! On-Board Diagnostics (OBD)
No new posts WFS light fixture LT35 is burning Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf 4 Glove Box Light: Installation Guide Transmission, Chassis, Body & Interior
No new posts EFB parking brake warning light flashing on the instrumen... Transmission, Chassis, Body & Interior
