vwSchrauber Profi-Schrauber
10-12-2012, 12:21 Subject: Triangle nut f. VP37 turnout frame |
I posted the Bosch part number for this specific nut in this forum a long time ago (around 2009?), but unfortunately, I can't find the thread anymore.
I once had a triangular file from Bosch, but unfortunately, it has already been stolen from my toolbox  .
Does anyone know the Bosch part number?
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
10-12-2012, 13:54 Subject: Triangle nut f. VP37 turnout frame |
Bosch 0986612605?
I am sorry, but I cannot access external websites or specific files online. Therefore, I am unable to translate the text from the provided URL.
or
I am sorry, but I am unable to access external websites, including the one you provided. Therefore, I cannot translate the text from the given URL.
tdi-erwin Blaumann
Joined: 09/30/2005 Posts: 39 Karma: +4 / -0 Location: östlich v. WIEN
10-12-2012, 13:56 Subject: Triangle nut f. VP37 turnout frame |
Hello!
I used a Dremel tool to remove the triangular section from a 24-sided nut, following these instructions:
I am sorry, but I am unable to access external websites, including the one you provided. Therefore, I cannot translate the text from the German website into English.
Or, during my search, I found the following source:
Unfortunately, I cannot access external websites, including the one you provided from dieselkontor.de. Therefore, I am unable to translate the text from that page.
I've already replaced this gasket twice, once with an MKB AHU gasket, and it's been leak-free for 2 years!
1* Myocardial bridging, acute heart failure, 1 month ago.
Wishing you all the best.
tdi-erwin
10-12-2012, 18:19 Subject: Triangle nut f. VP37 turnout frame |
Thank you very much  .
roorback Blaumann
Joined: 12/22/2003 Posts: 374 Karma: +1 / -2 Location: kärnten/österreich
11-12-2012, 10:08 Subject: Triangle nut f. VP37 turnout frame |
Hey.
While not the most elegant or precise method, my approach (see attachment) involves using a Dremel.
Should it be replaced with a "standard" one?
| Description: |
| File size: |
61.94 KB |
| Viewed: |
6460 times |
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
11-12-2012, 10:49 Subject: Triangle nut f. VP37 turnout frame |
It also works with a good, sharp wire-cutting pliers.
To my uttermost dismay, I have even tried it with a hammer and chisel  .
Profile PM Garage |
11-12-2012, 13:39 Subject: Triangle nut f. VP37 turnout frame |
If necessary, I can also do it with an 8mm Allen key that I hit with a hammer. However, such repair and correction methods do not look very professional to the customer  .
alevuz Schrauber
Joined: 11/27/2011 Posts: 113 Karma: +32 / -0 Location: Tirol
11-12-2012, 21:22 Subject: Triangle nut f. VP37 turnout frame |
Hello, and good evening.
Okay, here's a really silly question:
Is anyone going to Dieselkontor? "Do they only supply to companies?"
SG
Alevuz.
Touareg V10 TDI (AYH)
12-12-2012, 14:33 Subject: Triangle nut f. VP37 turnout frame |
Sure,
alevuz Schrauber
14-12-2012, 11:33 Subject: Triangle nut f. VP37 turnout frame |
I already understand that they only supply businesses.
I was just thinking/hoping that they might also deliver to users registered here, perhaps with a special arrangement.
SG
Alevuz.
17-12-2012, 14:42 Subject: Triangle nut f. VP37 turnout frame |
For your own vehicle, a slightly oversized 8mm hex key will also work. However, if you're doing this for customers, I would definitely recommend registering a business. It costs very little and makes many things easier or brings many things into a legal framework  .
alevuz Schrauber
roorback likes this. |
18-12-2012, 15:48 Subject: Triangle nut f. VP37 turnout frame |
No way, I definitely won't do anything for others! My two boxes are enough for me!
As you can probably tell from my previous messages, I need a lot of specialized parts and tools, even for relatively minor tasks, especially when it comes to my V10 engine.
Unfortunately, there's not much room for improvisation.
The good thing about Dieselkontor was that they could supply everything, so it wasn't necessary to order from four different suppliers.
That's why I'm asking!
"Still, THANK YOU for the information..."
SG
ALevuz
18-12-2012, 22:18 Subject: Triangle nut f. VP37 turnout frame |
Just go to a reputable independent workshop and have them order it for you.
I've been doing that for years whenever I encounter this problem.
"I'll also lend them things sometimes if they don't have them, and I get everything I need in return."
Profile PM Garage |
