Windshield wipers not working, pump ok (SOLVED)
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
maendy
Post03-01-2013, 21:34    Subject: Windshield wipers not working, pump ok (SOLVED) Quote
Hello everyone,
My windshield wipers on my 2008 Passat have stopped working.
Tap on the wiper motor, but I'm not sure.
I deleted the errors, but they immediately reappear, even after I disconnected the motor. I have to admit that I'm a novice in this area.
Best regards, Maendy.
Saturday, December 22, 2012, 2:34:27:46857 PM.
VCDS version: RKS 11.11.4
Data as of: 20120807.
Address 09: Body Control Module
Label file: RKS\3C0-937-049-30-H.lbl
Control unit part number: 3C0 937 049 AJ. Hardware version: 3C0 937 049 AJ.
Component and/or version: On-board network module H54 2202.
Encoding: F5888F4701041A00450A00000F000000001955433C000100000000000000
Company number: WSC 05124 123 12345
Extended Information: Error LIN Slave 01, Part Number 1K0955559AF, RLS, 010208 046 0204.
VCID: 71EDBAAB681E1390DE9
"3 errors found:"
00906 - Horn/Double-tone horn (H1)
009 - Intermittent short circuit to ground.
Environmental conditions:
Error status: 00101001
Error priority: 2
Error frequency: 1.
Lost Count: 135
Mileage: 158,923 km
Time: 0.
Date: 2012.12.22
Time: 00:00:00
text
from
Voltage: 12.50 V
text
from
text
from
text
from
text
from
text
from
02071 - Local data bus.
004 - No signal/communication.
Error status: 01100100
Error priority: 2
Error frequency: 1.
Lost Count: 95
Mileage: 158,923 km
Time: 0.
Date: 2012.12.21
Time: 16:41:00
text
from
Voltage: 12.40 V
text
from
text
from
text
from
text
from
text
from
00153 - Wiper motor, driver's side (V216)
Error priority: 2
Error frequency: 1.
Lost Count: 95
Mileage: 158,923 km
Time: 0.
Date: 2012.12.21
Time: 16:41:00
text
from
Voltage: 12.40 V
text
from
text
from
text
from
text
from
text
aus
Translated on 05-08-2026, 11:13.
Post03-01-2013, 22:00    Subject: Windshield wipers not working, pump ok (SOLVED) Quote
Checked the fuses?
Translated on 05-08-2026, 11:20.
maendy
Post03-01-2013, 22:34    Subject: Windshield wipers not working, pump ok (SOLVED) Quote
Yes, the fuses are okay. The three-wire connector has positive and negative connected, and the thinner cable is the control cable. I once disconnected the linkage, and everything moves freely...
Translated on 05-08-2026, 11:21.
Post04-01-2013, 0:16    Subject: Windshield wipers not working, pump ok (SOLVED) Quote
maendy wrote:
The thinner cable is the control cable.
and
no signal/communication
It gives it away, doesn't it?
The cable and/or the motor are broken.
Do you have an engine for exchange?
maendy
Post04-01-2013, 9:02    Subject: Windshield wipers not working, pump ok (SOLVED) Quote
Unfortunately, I don't have one. I could get one from a Passat CC, but it has a 4-pin connector cable.
Is there a way to test the engine?
maendy
Translated on 05-08-2026, 11:22.
Post04-01-2013, 13:06    Subject: Windshield wipers not working, pump ok (SOLVED) Quote
There are known issues with leaky covers that can cause the wiper motor control unit (STG) to fail.
A request to the icon_wink.gif regarding possible leniency might be worthwhile.
Translated on 05-08-2026, 11:23.
Post04-01-2013, 13:24    Subject: Windshield wipers not working, pump ok (SOLVED) Quote
Yes, the recall information dates back to December 2006 - I had just placed an order and then there were two Passat recalls icon_eek.gif (wiper blades and diesel cooler).
Translated on 05-08-2026, 11:24.
maendy
Post04-01-2013, 20:00    Subject: Windshield wipers not working, pump ok (SOLVED) Quote
Hello everyone,
icon_lol.gif Thank you for your help; the wiper is working again.
During the engine swap from the Passat CC, the purple cable detached from the connector, which was corroded.
By the way, the windshield wiper motor with 4 terminals also works.
greetings maendy
Post04-01-2013, 20:15    Subject: Windshield wipers not working, pump ok (SOLVED) Quote
Translated on 05-08-2026, 11:25.
No new posts Avoid squeaking windshield wipers at the front General Tips
No new posts Windshield Wiper Regeneration General Tips
No new posts Octavia I 1999 - Front wipers only work when it's dry General Tips
No new posts The front windshield wipers are not working Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf 6 front windshield wipers not working, motor OK Electrical Systems, Vehicle Electronics, Multimedia
No new posts Outside temperature display malfunctioned On-Board Diagnostics (OBD)
No new posts Polo 9N Steering Wheel Removed -- On-Board Diagnostics (OBD)
