Gearbox Crack: Causes and Solutions
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Post31-08-2013, 9:21    Subject: Gearbox Crack: Causes and Solutions Quote
Hello.
I have a T4 gearbox (DQR) here with a crack in the housing.
The seller doesn't know (or perhaps prefers not to know...) how the crack occurred.
There are marks on the transmission that suggest external mechanical damage caused by an accident, but these marks could also be due to improper storage or similar issues.
Now the question for me is whether disassembling it would be a good idea or not. What could have happened inside if the damage originated from there? Could something have become stuck and rotated within the housing?
I know that you can never be 100% certain what the problem was without disassembling something, but I hope someone with experience might be able to offer a pretty good suggestion. icon_wink.gif
 Getriebe DQR fĂŒr T4.
 File size:  160.63 KB
 Viewed:  5865 times
Translated on 25-08-2026, 6:00.
Post31-08-2013, 9:34    Subject: Gearbox Crack: Causes and Solutions Quote
Upon close inspection of the grinding and pressure marks near the crack, it is likely that the transmission, without the engine being moved forward approximately 10 cm, was forcibly jammed against the left chassis rail.
Or, in a mishap, the drive shaft struck the housing.
It could also be a faulty bearing.
It's difficult to say exactly what the problem is, as you mentioned, without disassembling the transmission. icon_confused.gif
Aunt Edith: It could also be a problem with the constant velocity joint boot needing to be replaced; forcing the outer joint forward can put pressure on the transmission housing. icon_rolleyes.gif
Translated on 25-08-2026, 6:02.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post31-08-2013, 17:41    Subject: Gearbox Crack: Causes and Solutions Quote
Sieht wie ein Treffer von außen aus. Eine BeschĂ€digung von innen ist unwahrscheinlich da ich keine Haarrisse oder Erhebungen nach außen erkenne. SpĂ€ne im Öl? Funktioniert alles noch? GerĂ€Sure?
Behind the position is the relatively large gear for reverse.
Beim Wechseln des GetriebegehĂ€uses mĂŒssen Antriebs-, Abtriebswelle und das Differenzial neu eingestellt werden. IIt's a huge amount of work.
We've had something like this welded before, and it can be done using AC TIG welding with a high amperage setting (which requires an expensive machine). It might even be possible to do it from the outside.
I'm looking for a company that welds aluminum. I can recommend one near me.
Simplest solution: Liquid metal adhesive icon_rolleyes.gif.
reflexsilber met.
Translated on 25-08-2026, 6:03.
Post31-08-2013, 19:33    Subject: Gearbox Crack: Causes and Solutions Quote
The simplest solution: liquid metal adhesive
It might not last very long due to thermal expansion. Additionally, the adjacent bearing (if it's a tapered roller bearing) will be under pre-tension, which can disrupt sleep.
Welding would be the best solution.
The seller doesn't know (or perhaps he doesn't want to know...) how the crack occurred.
The issue is unknown – it might be defective. Is there an alternative to the current transmission?
If not, disassemble, overhaul, and have it welded.
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 25-08-2026, 6:05.
Post02-09-2013, 8:01    Subject: Gearbox Crack: Causes and Solutions Quote
Right off the bat: Any kind of liquid metal solutions or similar are out of the question; this part is intended for personal use only. icon_wink.gif
Unfortunately, there is no oil left in it anymore, as it was purchased by a recycling company.
So far, everything seems to be working normally when it comes to switching and rotating.
The thing is, I bought it either to have a replacement part on hand, or because I actually wanted to build something custom out of it. The latter would be my preference, as even the standard DQR feels a bit too short for me.
"I spoke with the gearbox company; in case I can't fix it myself, but only after I've made sure everything is okay beforehand, they will accept it as a core even if it has cracks, but it must be assembled. Therefore, the motivation to disassemble it for 4 hours isn't very high, because there's a risk that everything could be scrap, and then it would take another 4 hours to reassemble it so it can be used as a replacement part."
Translated on 25-08-2026, 6:07.
Post16-12-2013, 12:32    Subject: Gearbox Crack: Causes and Solutions Quote
I finally had the time and motivation to finish it today.
The cause is now clear: The bearing of the driveshaft has failed, which caused grinding noises within the housing even when shifting into reverse.
 File size:  133.2 KB
 Viewed:  2730 times
Translated on 25-08-2026, 6:08.
No new posts Air Bubbles: Find the Root Cause & Fix It! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia II: Scratches on Gearbox Housing Transmission, Chassis, Body & Interior
No new posts Windshield crack Transmission, Chassis, Body & Interior
No new posts Hose with a tear Upload
No new posts Cracked Cylinder Head: Symptoms & Repair Diesel Engine Technology
