25-03-2013, 9:15 Subject: SRA glued onto the Touran |
... and the adhesive is now loose.
Is that a double-sided adhesive pad, or is there real glue in between?
| Description: |
| Befestigung der Scheibenreinigungsanlage beim Touran. |
| File size: |
138.34 KB |
| Viewed: |
5635 times |
Translated on 10-07-2026, 14:06.
Profile PM Garage |
25-03-2013, 9:39 Subject: SRA glued onto the Touran |
On the Golf 6, this part is soldered in place. I had one just last week where it also broke off.
Make sure to apply the adhesive properly.
Profile PM Garage |
25-03-2013, 20:07 Subject: SRA glued onto the Touran |
Then I'll probably have to completely detach the part first, because it seems like there's an adhesive pad in between.
(Daylight is a great thing if you want to see something like that  ).
| Description: |
| File size: |
69.23 KB |
| Viewed: |
2872 times |
Translated on 10-07-2026, 14:07.
Profile PM Garage |
26-03-2013, 21:20 Subject: SRA glued onto the Touran |
Sure.
Sticky pad that no longer sticks.
I need a good adhesive for attaching front spoilers!
| Description: |
| File size: |
240.24 KB |
| Viewed: |
2534 times |
Profile PM Garage |
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7830 Karma: +1102 / -0 Location: BAR
26-03-2013, 21:52 Subject: SRA glued onto the Touran |
Should I apply undercoating and body sealant?
Translated on 10-07-2026, 14:08.
26-03-2013, 22:58 Subject: SRA glued onto the Touran |
I just realized that the parking sensors on the Passat are also only glued to the bumpers.
Unfortunately, these adhesive pads are a perfect fit, likely due to the perfectly round cutout.
The 1.6-liter gasoline engine has something stuck to the intake manifold with tape.
I could probably come up with something using that.
I don't have body adhesive in 5-gram portions, and a complete cartridge seems like a bit too much  .
At least I disassembled the SRA once.
Using a bicycle spoke to push the piston out, I snapped it back into place and disengaged the nozzle. Otherwise, you can't get the SRA (likely referring to a headlight or similar component) out of the front bumper bracket... It's solved differently than on the G5, where everything can be nicely disassembled.
Now I have the bracket separately and can glue it in place without applying too much force.
| Description: |
| File size: |
34.86 KB |
| Viewed: |
2054 times |
Translated on 10-07-2026, 14:09.
Profile PM Garage |
DieselBär30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: München & Passau
26-03-2013, 23:21 Subject: SRA glued onto the Touran |
Hi Martin!
First of all: *sorry*  .
Was macht'n da die Oral-B Aufsteckbürste nach Sonnenuntergang bei gleichzeitig u. obligatorisch eisigen Temperaturen da?
...planst Du Deine SRA gemäß ToolTime*grunz,grunz,grunz*-Manier aufzumotzen?
Und damit mein Beitrag nicht ganz umsonst war...
Ask a painter or a body shop technician at (D  ). They have very good and specifically suitable adhesives for the materials.
Furthermore, they will likely "sell" it to you in microliter amounts  .
Best regards from Munich!
Translated on 10-07-2026, 14:11.
27-03-2013, 8:44 Subject: SRA glued onto the Touran |
HI.
- after sunset: I won't be able to work on it before then.
- Brush: That completely filthy specimen had to be decontaminated first. Later, I'll add a speck of dust and it will be crookedly mounted.
Translated on 10-07-2026, 14:12.
Profile PM Garage |
02-04-2013, 15:21 Subject: SRA glued onto the Touran |
OK.
I got everything originally  .
Primer, 2K adhesive...
The current PDC sensors are no longer attached with pads, but rather with adhesive.
Tonight, we're going to have a wild time.
Translated on 10-07-2026, 14:13.
Profile PM Garage |
02-04-2013, 22:02 Subject: SRA glued onto the Touran |
Okay.
For the first attempt, it's not bad at all  .
| Description: |
| File size: |
70.92 KB |
| Viewed: |
1835 times |
| Description: |
| File size: |
43.74 KB |
| Viewed: |
1618 times |
Profile PM Garage |
