Boost Pressure Control: Limit Exceeded
Go to page: 1, 2, 3  Next
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
BM
Avatar-BM
Post26-09-2011, 20:30    Subject: Boost Pressure Control: Limit Exceeded Quote
Audi A4 2.0 TDI BPW with DPF.
Should I perform a test run here first, or should I start searching directly on the VTG linkage?
Which types of medical devices should be logged, or is it sufficient to only log medical device type 11?
Am I correct in assuming that the values in the error log represent pressures?
Does it refer to a deviation once from the target value (1754.4 mbar) and once from the actual value (2142.0 mbar)?
And what is the best way to trigger this error?
Thank you.
Code:
Adresse 01: Motor        Labeldatei: RKS\03G-906-016-BPW.lbl
   Teilenummer SW: 03G 906 016 KN    HW: 03G 906 016 KN
   Bauteil: R4 2,0L EDC G000SG  9748
   Revision: --H02---    Seriennummer:
   Codierung: 0000072
   Betriebsnr.: WSC 24953 150 85390
   VCID: 79FC6E3E4949
1 Fehler gefunden:
000564 - Ladedruckregelung: Regelgrenze überschritten
               P0234 - 000 -  -  - Sporadisch
             Umgebungsbedingungen:
                    Fehlerstatus: 00110000
                    Fehlerpriorität: 1
                    Fehlerhäufigkeit: 26
                    Kilometerstand: 140349 km
                    Zeitangabe: 0
                    Drehzahl: 2562 /min
                    Geschwindigkeit: 127.0 km/h
                    Last: 39.2 %
                    Spannung: 14.06 V
                    Binärwert: 00101000
                    Druck: 1754.4 mbar
                    Druck: 2142.0 mbar
Readiness: 0 1 0 0 0
3B5 AJM
Translated on 28-09-2026, 18:54.
Post26-09-2011, 20:56    Subject: Boost Pressure: Limit Exceeded - Troubleshooting Quote
Should I perform a test run here first, or should I start the search directly on the VTG linkage?
Good question icon_smile.gif. I will first check the adjustment range.
BM wrote:
Which type of material waste bin (MWB) is it reasonable to log, or is MWB 11 sufficient?
1 and 11 are enough.
Yes.
BM wrote:
And how can the error be best provoked?
I would suddenly floor the accelerator pedal (and keep it floored) while in 5th gear at 2500 rpm.
Here's a small consolation: The loader is working well. Please also check if the DPF is okay and not "too permeable." icon_wink.gif You can also check this beforehand by performing a diagnostic log and checking the differential pressure in the measurement blocks, starting from value 67.
Is the engine control unit (ECU) original?
Translated on 28-09-2026, 18:57.
BM
Avatar-BM
Post26-09-2011, 22:01    Subject: Boost Pressure Control: Limit Exceeded Quote
Okay, I'll get started on it. I have until Saturday to complete it.
Is the engine control unit original?
The vehicle is not modified, I think it's original. The customer is reliable.
I'm currently considering (assuming the VTG is stuck), whether I should disassemble the turbocharger for cleaning.
Or whether it's worth trying to just unscrew the lower part of the frame and, using a Gloria sprayer or, even better, a cavity gun (which sprays around corners), along with a cleaning solution (that dissolves soot), attempt to clean it, and then follow up with a generous application of WD40. I don't have much experience with this, so I'm not sure if it would be effective.
3B5 AJM
Translated on 28-09-2026, 18:59.
Post27-09-2011, 8:50    Subject: Boost Pressure Control: Limit Exceeded Quote
BM wrote:
I don't have much experience in that area, so I'm not sure if it makes sense.
If you have to guarantee your performance, then probably not icon_wink.gif.
Translated on 28-09-2026, 19:00.
Post27-09-2011, 8:54    Subject: Boost Pressure Control: Limit Exceeded Quote
BM wrote:
I'm currently considering (if VTG is involved), whether I should disassemble the turbo for cleaning.
or whether it's worth trying to just unscrew the lower part of the frame
and using a Gloria sprayer or, better yet, a cavity gun (which also sprays around corners) and a cleaning solution (that dissolves soot) to start a cleaning process, and then follow up with a dose of WD40. I have little experience with this, and I'm not sure if it makes sense. } Often, it's not soot that's the main problem, but severe rust on the back plate!
Just let it go.
Translated on 28-09-2026, 19:01.
BM
Avatar-BM
Post27-09-2011, 10:58    Subject: Boost Pressure Control: Limit Exceeded Quote
If you have to provide a guarantee for your performance, probably not icon_wink.gif.
No, I don't have to. Otherwise, only a new part would be considered.
Often, it's not the soot that's the main problem, but rather severe rust on the back plate!
Does it mean to disassemble or to renew?
3B5 AJM
Translated on 28-09-2026, 19:02.
Post27-09-2011, 11:00    Subject: Boost Pressure Control: Limit Exceeded Quote
or whether it's worth trying to just unscrew the lower part of the frame and, using a Gloria sprayer or, even better, a cavity gun (which sprays around corners), and a cleaning solution (that dissolves soot), attempt to clean it, and then apply a dose of WD40 afterwards. I have little experience with this, and I'm not sure if it would be effective.
I estimate the chances of success to be rather low. You can try unscrewing the VTG canister on the loader and see if the VTG moves easily from stop to stop. It should move super easily (click-clack).
The weight of the can hanging from the lever arm alone results in a force that is several times greater than the normal operating force.
Translated on 28-09-2026, 19:04.
Post27-09-2011, 11:05    Subject: Boost Pressure Control: Limit Exceeded Quote
BM wrote:
Does that mean to disassemble or to renew?
Disassemble and remove rust.
Translated on 28-09-2026, 19:05.
BM
Avatar-BM
Post27-09-2011, 13:53    Subject: Boost Pressure Control: Limit Exceeded Quote
Okay, chemical flushes don't really help with rust.
Then we have to put it on the table. It starts tomorrow. Let's see if the turbo kicks in.
allows for easy disassembly without much effort.
According to the documentation, just the installation and removal should take at least 3.6 hours.
3B5 AJM
Post27-09-2011, 16:54    Subject: Boost Pressure Control: Limit Exceeded Quote
Tip: For the rear bolt connecting the exhaust manifold to the turbocharger, you'll need a slim 13mm ring wrench. I simply modified one with a rotary tool to fit mine.
According to the documentation, just the installation or removal should take at least 3.6 hours.
If you're doing it for the first time, it's great. Compared to the transversely mounted engines, it's a dream icon_wink.gif.
Be careful with the exhaust temperature probe cable.
Translated on 28-09-2026, 19:06.
Deus Violentia
Post27-09-2011, 19:48    Subject: Boost Pressure Control: Limit Exceeded Quote
Here's another idea because the mileage seems right - take a look (and I'm serious this time, because I've seen it twice already!) at what the minimum flow screw looks like and the spot on the lever where it makes contact.
The screws or the lever wear down slightly, which causes the VTG (Variable Geometry Turbine) to close too much!
Half a turn and the error is gone.
BKD GRF
AHF EBF
Translated on 28-09-2026, 19:07.
BM
Avatar-BM
Post27-09-2011, 20:59    Subject: Boost Pressure Control: Limit Exceeded Quote
Thank you for your tips. I will definitely take them into consideration. Hopefully, nothing will interfere with my schedule tomorrow.
Compared to the horizontally mounted engines, it's a dream
I'm curious to see if I'll have to remove the entire DPF system or if it will work out okay as is.
3B5 AJM
Translated on 28-09-2026, 19:08.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post27-09-2011, 21:08    Subject: Boost Pressure Control: Limit Exceeded Quote
Pictures of the open turbo would be great!
reflexsilber met.
Translated on 28-09-2026, 19:09.
Post27-09-2011, 21:13    Subject: Boost Pressure Control: Limit Exceeded Quote
Before you wrench off a size 13, it might have been a size 12 wrench... so, check the easily accessible nuts first icon_wink.gif. I'm not sure about that right now.
It's enough to simply unscrew the DPF from the turbocharger (3 screws).
BM
Avatar-BM
Post29-09-2011, 15:22    Subject: Boost Pressure Control: Limit Exceeded Quote
Okay, finally found some time to tackle the thing with 20 interruptions. icon_wink.gif
Before you tear apart a size 13, maybe it was actually a size 12 wrench...
They are all size 12. I have size 13 in some variations, but not in size 12. Because of this, the expansion process turned out to be a bit more difficult than initially anticipated.
First, let me clarify: Neither soot nor rust were the problem, but rather material defects at the bottom of the casting housing, where the guide vanes rest.
The turbocharger would really be better off in the trash.
After removing the protective cover, you can already see in Image 1 where the dog is buried, even before cleaning. The same is visible in Image 2.
After cleaning with a commercial cleaner (spray, let it sit, rinse).
You can see it again very clearly in images 3 and 4. The advantage of this method is that it doesn't obscure any traces.
After further cleaning and reattaching the variable geometry turbocharger (VGT) adjustment mechanism, I discovered that it was still sticking.
Specifically, a guide vane (facing open towards the direction of rotation) was jammed at the location shown in images 1 and 2.
It only opened 50%, and then it got stuck, just like before.
Interestingly, even when in the closed position (with the adjustment mechanism engaged), it had the same amount of axial play as the others. However, when opened, it lost that space.
Okay, I re-monitored the Vtg system and searched for errors. I couldn't find anything on the guide vane itself that would explain the jamming.
After that, I took a piece of a body filler file and scraped it around the bottom of the housing. If everything is level, it should slide almost effortlessly over the material. If not, you can remove material from where it's too high, and you'll see what's going on.
In image 5, you can see a bright spot at the edge near the swirl channel, which indicates where the file was used. (The Edding marking was added later.)
To verify my assumption, I then checked the clearance (of the swirl channel) with a drill bit. As expected, the drill bit could not be inserted into the swirl channel without scraping against the bottom.
Afterwards, I painstakingly worked by hand to restore the area until the guide vane had the same amount of clearance in every position as all the others. I used a permanent marker as a tool. I could have also modified the guide vane itself, but I didn't want to. Instead, I simply smoothed it.
In image 6 and the video clip, you can see the working VTG. This shows how easily the VTG can be moved.
To cut a long story short -- I have to install this thing again now. Fun factor = 0. icon_wink.gif
PS: The connecting screw and lever were found to be in good condition.
Boost Pressure Control: Limit Exceeded - Clip.avi
 File size:  1.55 MB
 Viewed:  4283 times
 File size:  1.92 MB
 Viewed:  6539 times
 File size:  903.62 KB
 Viewed:  5871 times
 File size:  888.47 KB
 Viewed:  5537 times
 File size:  1023.07 KB
 Viewed:  5663 times
 File size:  963.69 KB
 Viewed:  5493 times
 File size:  986.39 KB
 Viewed:  5540 times
3B5 AJM
Translated on 28-09-2026, 19:13.
Deus Violentia
Post29-09-2011, 15:46    Subject: Boost Pressure Control: Limit Exceeded Quote
Thank you for the detailed feedback!
BKD GRF
AHF EBF
Translated on 28-09-2026, 19:16.
No new posts P0299 Error: Boost Control System Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty Load Pressure Control Engine Identifier BRE Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost Pressure Control: Limit Exceeded Diesel Engine Technology
No new posts 575 limit exceeded Diesel Engine Technology
No new posts A6 4B 2.5 TDI AGR limit exceeded On-Board Diagnostics (OBD)
No new posts TDI PD Turbo: Overboost Issue & Diagnostic Log Upload
