Timing belt replacement for Renault F9Q 1.9 dti
Karma: +643 / -0   Thank you, like it!
Post15-04-2013, 11:37    Subject: Timing belt replacement for Renault F9Q 1.9 dti Quote
Hi.
Here's the translation:
It concerns a 2001 Renault Megane Grandtour 1.9 dti with 79 kW and engine code F9Q 736.
Due to a timing belt failure, a different engine needs to be installed. The focus is now on the timing belt and the adjustment of individual components to top dead center (TDC). I have transferred the fuel injection pump from the defective engine to the "new" engine, along with its mounting bracket.
"I secured the crankshaft with the appropriate dowel pin. There's also a corresponding mark on the camshaft, and you can find a point on the injection pump rotor as well. However, I haven't been able to find a matching mark anywhere, neither on the mounting block nor on the timing cover. I've already searched extensively and only found this [referring to an image or object]."
http://update.carat-gruppe.de/TP_alt/motor/megan.html
"But they're assuming that the old timing belt is still there, which unfortunately isn't the case for me."
Can someone help me with this?
Best regards, Rüdi.
Translated on 11-07-2026, 19:07.
Post15-04-2013, 16:06    Subject: Timing belt replacement for Renault F9Q 1.9 dti Quote
You should find the corresponding markings on the new timing belt. Pay attention to the direction of rotation of the timing belt. The marking for the crankshaft (KW) should be distinct from the other markings.
Translated on 11-07-2026, 19:08.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 ab MJ 98, Zahnriemen läuft auf ESP nicht mittig Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts vp37 - riemen auflegen Diesel Engine Technology
No new posts Kurbelwelle Renault 1,9 dci Diesel Engine Technology
No new posts Renault Software? Diesel Engine Technology
No new posts Renault Kangoo Kurbelwelle? Diesel Engine Technology
