07-04-2013, 18:12 Subject: Windshield washer pump leaking: Tips for sealing it? |
The windshield washer pump on our Polo is leaking when activated. The washing water seems to be escaping from the area where the outer hose connector cover sits on the horizontal distribution cylinder (where the hoses leading to the front and rear windshields are connected), as shown in the picture, specifically at the left fitting.
Has anyone ever disassembled a pump like this (which is used as a universal part with the code 1K6 955 651 in many VAG models, such as Golf and Passat from 2003 onwards, Touran, Sharan, Ibiza from 1993, Leon from 2000, etc.) and sealed it at that specific location?
I'd really like to avoid spending around €40 to buy a replacement for that tiny thing...
| Description: |
| File size: |
48.69 KB |
| Viewed: |
2939 times |
Translated on 20-07-2026, 7:26.
Profile PM Garage |
Autoservice Profi-Schrauber
07-04-2013, 18:32 Subject: Windshield washer pump leaking: Tips for sealing it? |
Mach den Deckel mal runter. Evt. ist da Ein O-ring oder ähnliches vorhanden. Glue works wonders.
But honestly... does that even make sense?
Translated on 20-07-2026, 7:28.
07-04-2013, 19:10 Subject: Windshield washer pump leaking: Tips for sealing it? |
Autoservice wrote: | | But honestly... does that make sense? | Applying a little bit of glue, silicone, or something similar around a lid definitely makes sense if it can save you about 40€.
The question is simply whether the pump can be disassembled and reassembled without any damage.
If not, and a new pump would have taken several days to arrive, we would have been in serious trouble because Christel would have had to drive every day completely without windshield wipers.
Profile PM Garage |
07-04-2013, 20:06 Subject: Windshield washer pump leaking: Tips for sealing it? |
To be honest, I haven't used my windshield washer system in weeks, so it will probably take about 2-3 days...
Take it apart and have a look. It's already broken anyway.
Translated on 20-07-2026, 7:29.
Profile PM Garage |
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7830 Karma: +1102 / -0 Location: BAR
07-04-2013, 20:48 Subject: Windshield washer pump leaking: Tips for sealing it? |
Given the miserable weather we've had in recent weeks and my daily commute on the highway, I have to disagree. It's always needed whenever it doesn't work – when it's frozen or empty.
I would first try to open the pump. If that's impossible or if opening it risks causing total damage, just leave it alone! You can only seal something with silicone if you can disassemble it. Furthermore, silicone has a limited lifespan and isn't necessarily frost-resistant. It's also unknown how the antifreeze additives in the washing water will react with silicone.
Das bringt mich zur Empfehlung von "Pronova Bitumendicht". Das Zeug klebt wie  und laesst sich aus der Kartusche mit einer Silikonpresse in Raupen auf die Klebeflaechen aufbringen. Man kann es bei Bedarf auch aufspachteln. Beim Verarbeiten darf man sich etwas Zeit lassen, das Zeug bindet nicht sofort ab oder wird hart. Nach dem Aufbringen drueckt man die Flaechen nur etwas an, die Dichtmasse sollte nicht komplett zwischen den Flaechen herausgedrueckt werden. Herausquellende Dichtmasse kann man wegwischen oder stehen lassen, wenn sie nicht stoert. Surface imperfections, scratches, or cracks are not a problem – they can be easily corrected.
Die Verarbeitung auf nassen Oberflaechen ist moeglich, man koennte also auch im Regen damit arbeiten. Die in Kartuschen angebotene schwarze Masse ist glasfaserverstaerkt, hitze- wie frostfest und bleibt dauerelastisch. Man sollte sie zum besseren Verarbeiten definitiv anwaermen. Gedacht ist diese Klebe- und Dichtmasse eigentlich fuer Reparaturen im Dachbereich. Man kann damit Bleche auf Kunststoffe oder Glasfaserteile verkleben, Risse abdichten oder Stosskanten versiegeln. Nach dem Abbinden sind Temperaturen zwischen -40 und +110 Grad kein Problem mehr, die UV-Bestaendigkeit ist laut Datenblatt fuer 15 Jahre garantiert. Slight fading after the first summer is normal; the material will then have a slightly grayish hue. A single item costs €3.99.You can find the cartridge at a discount store ("Schnaeppchenbaumarkt" - it's really called that!) or at a B1 hardware store. Opened cartridges are usually sealed and have a shelf life of about 4 weeks. If they have been warmed up, they will last for approximately another 2 weeks.
You could also try using body adhesive or windshield sealant. This type of product generally doesn't have any issues with the antifreeze additive.
Translated on 20-07-2026, 7:31.
08-04-2013, 6:31 Subject: Windshield washer pump leaking: Tips for sealing it? |
Hutfahrer wrote: | | It is always needed whenever it doesn't work - when it is frozen or empty. | Or when someone only feels comfortable behind a perfectly clean pane of glass, which therefore has to be wiped every few days, even during dry periods.
"In the winter, the 2-liter reservoir is empty every few weeks, even though we usually only drive about 40 km of lightly trafficked country road each day. My partner has always complained about this in our Polo, and yesterday she happened to find out that there's also a 4.5-liter reservoir available for Polos with SRA (selective catalytic reduction). Ours doesn't have SRA, but VAG offers suitable blind plugs for the holes where the SRA pump and warning contact would be."The conversion to the 4.5-liter tank is now finalized.
The pump will probably need to be replaced as well, because the car wash froze during one of the past winters (I completely forgot about that), and the water likely leaked out through cracks in the casing that opened under pressure.
Translated on 20-07-2026, 7:33.
Profile PM Garage |
Hutfahrer Schrauber
08-04-2013, 6:52 Subject: Windshield washer pump leaking: Tips for sealing it? |
Okay, das ist ein Argument. Ich hab' in meinem 206 nur 1,7 l Scheibenwaschwasser - und das reicht fuer drei Autobahnfahrten mit je 93 km zwischen Wohn- und Dienstort bei winterlichem Schmuddelwetter. Vor dem Abparken habe ich im Winter taeglich (!) die Scheiben und Scheinwerfer gewaschen und eigentlich auch taeglich die Scheibenwaschanlage vollgetankt. Da merkt man, dass der 206 nicht als Langstreckenfahrzeug geplant war. Damit ich keinen Frostschutzkanister spazierenfahren muss habe ich einen mit dem -60 Grad-Konzentrat (von Lidl, absolut empfehlenswert!) im Buero deponiert. Mit 50/50-Mischung noch gut fuer -20 Grad, ich hab' den Tagesverbrauch den zu erwartenden Temperaturen angepasst und meist 70/30 gemischt. Dann hielt das Zeug laenger. A splash of Gesc.Adding the cleaning agent to the container *before* mixing it increases its cleaning effectiveness noticeably.
Translated on 20-07-2026, 7:35.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
06-05-2013, 19:51 Subject: Windshield washer pump leaking: Tips for sealing it? |
Here's how I repair a leaky pump  . First, roughen the surface with sandpaper, then degrease it with brake cleaner, and warm it up with a hairdryer. After that, seal the crack or gap with hot glue! In this case, I don't disassemble the pump because it's too risky, as plastic parts could break. I would only disassemble it if the pump doesn't rotate, is stuck, or completely stops working.
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
07-05-2013, 6:04 Subject: Windshield washer pump leaking: Tips for sealing it? |
T3Surfer wrote: | | This is how I repair a leaky pump with hot glue... | I'll try it on the old pump once the new one is installed.
If it works out, the old part that has been glued will go into the spare parts pool  .
Translated on 20-07-2026, 7:36.
Profile PM Garage |
07-05-2013, 8:31 Subject: Windshield washer pump leaking: Tips for sealing it? |
ulf wrote: | T3Surfer wrote: | | This is how I repair a leaky pump with hot glue... | I'll try it on the old pump once the new one is installed.
If it works out, the old part that has been glued will go into the spare parts pool  | .
I hope you find the pump again after all these years  .
Translated on 20-07-2026, 7:37.
