Generator Set 81kW AFN
Manuel26
Post21-05-2013, 12:48    Subject: Generator Set 81kW AFN Quote
Hello everyone,
During the replacement of the viscous fan clutch, I disassembled the entire assembly (alternator, tensioner pulley for the ribbed belt, viscous fan, power steering pump) by removing four screws. Now I'm wondering where the gasket should be located between the assembly carrier and the engine block. According to the information I received from the dealer, there is no gasket in this area - is that really the case?
Best regards, Manuel.
Translated on 10-09-2026, 12:00.
Post21-05-2013, 14:26    Subject: Generator Set 81kW AFN Quote
Which interstellar spaceship is the AFN located in?
Depending on the "place of origin," the (especially the AFNs - Air Flow Nozzles) were installed in very different ways (e.g., Golf 4 vs. Passat 3B).
Translated on 10-09-2026, 12:01.
mdonau
1988 Audi 80
Post21-05-2013, 19:42    Subject: Generator Set 81kW AFN Quote
dieselmartin wrote:
Which interstellar spacecraft contains the AFN?
Da er was von Visco erwähnt, dürfte es sich um einen A4 oder Passat 3B handeln. ASo, it's a lengthwise installation.
To my knowledge, the Golf 4 did not have any of the older 827 TDI engines.
I still have a spare engine from a 3B lying around, but unfortunately, I haven't gotten that far yet icon_wink.gif.
..but my uncle whispers to me: "O-ring 50x4; part number 038 121 119 B (the same one as for the thermostat flange below)."
That makes sense, because that's where the standard water pump used to be mounted.
Best regards, Michael.
Passat 3B AFN Syncro, E46 330D, T3 1,7TDI, T3-Syncro TD
Translated on 10-09-2026, 12:03.
Manuel26
Post22-05-2013, 9:18    Subject: SEO: Best German Translation Services & Rates Quote
Thank you for the answers.
'This is a Passat 3B.'
Translated on 10-09-2026, 12:04.
Post22-05-2013, 18:04    Subject: Generator Set 81kW AFN Quote
Sure, there's a gasket. It's located where the water channel connects the carrier to the engine block.
No new posts Can injectors from an 81kW ASV engine be used in an 81kW ... Diesel Engine Technology
No new posts 6N2 Van: Aggregate Carrier in Doors? Transmission, Chassis, Body & Interior
No new posts Generator Supports: Installation & Removal Transmission, Chassis, Body & Interior
No new posts Engine Failure AFN 81kW: Causes & Solutions Diesel Engine Technology
