inf
23-05-2013, 20:12 Subject: DSG Problems Passat CC - Solved |
Today, I performed a diagnostic scan on my vehicle and found errors in the DSG (dual-clutch transmission) and DCC (dynamic chassis control) systems. I cleared both errors, and a few days later, I scanned the car again. The DCC error didn't reappear, but the DSG error did. I'm taking the car to the dealer next week. Can the dealer do anything about the DSG error?
I'm generally happy with the DSG, so this is a bit surprising.
Best regards, Stefan.
| Description: |
 Download |
| File name: |
Autoscan.txt |
| File size: |
14.7 KB |
| Downloaded: |
1990 times |
GruĂ, Stefan
Translated on 16-10-2026, 2:42.
Joined: 04/12/2002 Posts: 18139 Karma: +805 / -0 Location: St.Gallen 2018 Volkswagen T6
23-05-2013, 20:27 Subject: DSG Problems Passat CC - Solved |
Is the oil level correct in the DSG (Dual Clutch Gearbox)?
Translated on 16-10-2026, 2:43.
Profile PM WWW Garage |
inf
23-05-2013, 20:40 Subject: DSG Problems Passat CC - Solved |
Hello Rainer,
"I'll have it checked. Can I do that myself? I think it probably needs to be replaced anyway at 60,000 km."
GruĂ, Stefan
Translated on 16-10-2026, 2:44.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Dßsseldorf
23-05-2013, 21:48 Subject: DSG Problems Passat CC - Solved |
Look here: https://community.dieselschrauber.org/en/viewtopic.php?t=26396
If a change is already planned, I would go ahead and have it done.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
inf
31-05-2013, 19:53 Subject: DSG Problems Passat CC - Solved |
The vehicle is now at the VW dealership. The diagnosis is a faulty mechatronic unit. This rules out an oil change as the cause of the problem. Now I'm waiting for the replacement part... I'm curious to see how long it will take!
GruĂ, Stefan
31-05-2013, 22:14 Subject: DSG Problems Passat CC - Solved |
Thank you for the feedback! I was just about to ask about the mileage, but it says 47554 km in the log.
Translated on 16-10-2026, 2:45.
31-05-2013, 22:34 Subject: DSG Problems Passat CC - Solved |
Quote: | | but the log shows 47554 km. | icon_eek.gif:wink:
At least it's almost 48,000 km. And it's not the first one that hasn't made it past 50,000 km.
For that price, it's a real bargain at approximately 2000 EUR (excluding installation), compared to the entire transmission, which costs around 6000 EUR.
One should generally advise against buying used vehicles with DSG transmissions if there is no warranty - unfortunately. }
As far as I know, spare parts are practically unavailable.
Translated on 16-10-2026, 2:46.
inf
12-06-2013, 20:31 Subject: DSG Problems Passat CC - Solved |
The car is back, and thankfully, it was fixed a bit faster than expected. They replaced the DSG mechatronic with a new one, along with a new filter and oil. What can I say, it drives much better now! The DSG now downshifts occasionally and shifts very smoothly, almost without any interruption in power delivery. And the gear changes now work without any jerking in the transmission. So, I hope it stays this way!
GruĂ, Stefan
Translated on 16-10-2026, 2:47.
12-06-2013, 21:09 Subject: DSG Problems Passat CC - Solved |
Okay, good luck and thank you for the feedback  .
