LCode Errors: Troubleshooting and Solutions
Post12-06-2013, 22:56    Subject: LCode Errors: Troubleshooting and Solutions Quote
Hi.
In my 11.11.3 and 11.11.5 versions, LCode (1.3.0.9 and 1.0.5.3) reads the RKS/...LBL files instead of using my USER/...LBL files.
VCDS successfully accesses the USER data. However, when I click on "Coding" etc., I see the original, default information again, instead of my personalized, enhanced LBL data.
Is this happening to you too?
Translated on 18-10-2026, 12:22.
Post13-06-2013, 19:06    Subject: LCode Errors: Troubleshooting and Solutions Quote
Simple solution for your case: Just copy and paste.
Translated on 18-10-2026, 12:23.
Post13-06-2013, 21:52    Subject: LCode Errors: Troubleshooting and Solutions Quote
However, when I click on "Coding" etc., I see the original content again, instead of my personal, enhanced LBL.
...which makes sense in case of potentially corrupted files in the user folder...
Translated on 18-10-2026, 12:24.
Post16-06-2013, 15:54    Subject: LCode Errors: Troubleshooting and Solutions Quote
No, nothing is ruined there icon_wink.gif.
And if I start LCode in "standalone" mode, it readily accepts my LBL.
It doesn't even search in the USER folder at all, which can be verified using ProcMon.
And yes, copying is always an option, but that would essentially render the USER folder pointless.
Translated on 18-10-2026, 12:25.
Post16-06-2013, 16:17    Subject: LCode Errors: Troubleshooting and Solutions Quote
Hello Martin,
The LCode.ini file specifies where LCode searches for files. However, if nothing is entered there, there's a small drawback: The structure of the label folders must be such that the files for each language are located in the main directory. This prevents a fallback to English versions if a German file doesn't exist for a particular control unit.
Since most users don't modify their LBL files themselves, and these files are encrypted for newer vehicles anyway, I believe the best solution is to provide as much information as possible to 99% of customers, rather than saving 1% of enthusiasts the trouble of copying it.
If the modified special LBL file proves useful, it makes more sense to include it instead of the original file, or to expand the original file accordingly. -> Simply email the file.
LCode is by Niels Ezerman. You could, of course, simply ask him if he would like to adjust the search order, as his contact information is available in the program.
Translated on 18-10-2026, 12:26.
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LCode doesn't display all checkboxes On-Board Diagnostics (OBD)
No new posts G28 Error: Find the Mistake! Diesel Engine Technology
No new posts ABS error On-Board Diagnostics (OBD)
No new posts WFS Errors: Troubleshooting and Solutions Diesel Engine Technology
