Reprogramming the AGR control?
Go to page: 1, 2  Next
wuze60
Post16-04-2003, 12:45    Subject: Reprogramming the AGR control? Quote
Hello everyone.
What do you think?
Can the control of the AGR (Abgasrückführung) magnetic valve be reprogrammed so that the AGR only activates at 0% throttle pedal position and fully closes at approximately 10% throttle pedal position?
Do you think a tuner can reprogram it like that?
Or is that even possible with VCDS (Vag Com)?
Mario
Translated on 07-07-2026, 20:23.
wuze60
Post17-04-2003, 10:25    Subject: Reprogramming the AGR control? Quote
nothing???
Does anyone have a clue?
Translated on 07-07-2026, 20:24.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post17-04-2003, 10:40    Subject: Reprogramming the AGR control? Quote
I don't believe that's possible. If it were, it would definitely be included with a tuning chip. But I think the EGR valve should always be faulty.
Post17-04-2003, 10:43    Subject: Reprogramming the AGR control? Quote
If you increase the 'target mass airflow' value through engine control unit adaptation, the EGR rate should decrease (which can be observed by the duty cycle of the EGR solenoid valve). -> Try it out.
It seems like the soot limit curve is being adjusted here, but this action has no effect on the power output, which I've already tested.
Translated on 07-07-2026, 20:25.
wuze60
Post17-04-2003, 10:49    Subject: Reprogramming the AGR control? Quote
Thank you, Rainer!
Let's test that right away icon_smile.gif.
kenny
Post17-04-2003, 12:32    Subject: Reprogramming the AGR control? Quote
It's not a given that the tuners would include that feature! After all, the vehicles still need to pass the technical inspection (TÜV), and they might fail if that feature is present.
Translated on 07-07-2026, 20:26.
Tagessuppe
Post17-04-2003, 12:56    Subject: Reprogramming the AGR control? Quote
kenny wrote:
It's not a given that the tuners would include that! After all, the vehicles still need to pass the TÜV inspection, and they might fail because of it...
Okay, so, with my chip, let's just say, someone messed with the TÜV certification.
"No one will believe you if you claim 125 horsepower from a 90 horsepower engine. Furthermore, all values improve except for NOx when the EGR system is broken. You get less CO and less unburned HC, and incidentally, the exhaust gases are diluted by the EGR system because more fresh gases are blown through the engine. And during the emissions test, only the percentage of the exhaust values is determined, not the total amount. As far as I know, in Germany, only the smoke number and the CO percentage are evaluated."
Translated on 07-07-2026, 20:27.
wuze60
Post17-04-2003, 13:34    Subject: Reprogramming the AGR control? Quote
So, in Austria, they usually only measure the CO (carbon monoxide) levels and the smoke number.
However, not all workshops do this, because some have already damaged engines due to high RPMs, as one workshop manager told me.
My personal TÜV inspector doesn't measure anything at all icon_twisted.gif.
Translated on 07-07-2026, 20:28.
Tagessuppe
Post17-04-2003, 14:07    Subject: Reprogramming the AGR control? Quote
Seas Wuze(lla).
Where in Carinthia are you from?
I'm from Feistritz/Ros.
My mechanic always writes down some random number without checking anything *g*.
Sure, here's the translation:
"Best regards."
Translated on 07-07-2026, 20:29.
wuze60
Post17-04-2003, 16:37    Subject: Reprogramming the AGR control? Quote
I'm from Feldkirchen (unfortunately).
Translated on 07-07-2026, 20:30.
diesel.gustav
Post19-04-2003, 21:58    Subject: Reprogramming the AGR control? Quote
Deleted as requested.
Tagessuppe
Post22-04-2003, 7:44    Subject: Reprogramming the AGR control? Quote
"I agree, Felkirchen seems like a nice place. I know a few people from there. I actually thought you were from the Rosental area, because we have so many people from there here *g*."
Best regards.
Stefan
Post25-04-2003, 7:10    Subject: Reprogramming the AGR control? Quote
'In the software, there's a setting for the exhaust gas recirculation (EGR) system. Any competent tuner can adjust this. Whether they will is another matter. The effect is the same as disconnecting the EGR. If you're caught, you could face charges for tax evasion.'
I think a reputable tuning company wouldn't bother with that (and the less reputable ones probably wouldn't even be able to find the engine map...).
Translated on 07-07-2026, 20:31.
Tagessuppe
Post25-04-2003, 7:43    Subject: Reprogramming the AGR control? Quote
Stefan wrote:
In the software, there is a field for exhaust gas recirculation. Any competent tuner can adjust this. Whether they will do it is another matter. The effect is the same as disconnecting the EGR. If you are caught, you may face charges of tax evasion.
Thankfully, chip tuning is legal. *g*
Translated on 07-07-2026, 20:32.
Stefan
Post25-04-2003, 7:52    Subject: Reprogramming the AGR control? Quote
Translated on 07-07-2026, 20:33.
Tagessuppe
Post25-04-2003, 8:14    Subject: Reprogramming the AGR control? Quote
I am aware of that.
Only the majority of the chipmakers are ignoring it.
I'm included.
No new posts CD control radio Gamma 4 Diesel Engine Technology
No new posts Reprogramming AFN MSG for 1Z On-Board Diagnostics (OBD)
No new posts Reprogramming Audi A3 81kW AHF / Central Locking System Diesel Engine Technology
No new posts Reprogram ECU for More Power On-Board Diagnostics (OBD)
