Weak battery, save with second
New Topic 🔒 Locked 🔗 ⭐ 🖹 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post28-11-2013, 17:52    Subject: Weak battery, save with second Quote
Hi there,
I overheard something recently, but I couldn't really understand or follow the speaker.
It was about a car battery that was no longer in top condition, which could be saved by connecting a second battery in parallel or series (?), and then recharging it.
Have you ever heard of or even tried this with success?
If so, is there a meaningful explanation for it?
Greetings
DieselBĂ€r30x
Avatar-DieselBĂ€r30x
Post28-11-2013, 18:20    Subject: Weak battery, save with second Quote
This is supposedly mainly intended to help with deep discharge and sulfated batteries.
Here, a brand new battery is connected in parallel to the old one, using cables with the maximum possible thickness, and then the two batteries are charged together.
The goal is that when the sulfate crystals are broken or when the battery is recharged, only a small amount of charging current is actually taken, but there are short and high current peaks that are not measurable by us (in a temporal) manner. A charger can handle these current peaks (in the ”s range)? I don't know...) however, if not delivered, a portion of the sulfate layer cannot be recovered, which might have worked if...
As I said, all theory and practice: nonsense, doesn't work! Discharged and sulfated batteries can never be obtained as new.
Furthermore, this approach is EXTREMELY counterproductive when intelligent charging technology is used.
Best regards from Munich!
1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
klahaui
Avatar-klahaui
Post28-11-2013, 18:45    Subject: Weak battery, save with second Quote
A small example where I could try it out,
I have a battery in my summer vehicle, which has been deeply discharged several times to avoid complete failure, and I would like to revive it with a second battery, but this battery fails under high starting currents.
A new one, of course, won't come out, but it might still be okay enough to accompany me for 2-3 more years if I regularly reload it.
Would it be appropriate here, or according to your statement, also "Schmarn"? icon_biggrin.gif
It's also possible that the urge to tinker and experiment is something that appeals to me here, but if it doesn't work out, I'll save on electricity.
DieselBĂ€r30x
Post28-11-2013, 18:54    Subject: Weak battery, save with second Quote
I have already answered that question above.
But let your imagination run wild and tell me what you came up with icon_wink.gif
Karma: +1090 / -0   Thank you, like it!
Post28-11-2013, 19:45    Subject: Weak battery, save with second Quote
Things to consider if you believe in them: There are pulsators that can be permanently installed in the vehicle and are supposed to prevent or at least slow down sulfation. However, they draw power directly from the vehicle's battery, thus accelerating the discharge. This, in turn, provides fuel for the sulfation process. If the self-discharge can be compensated for, then such a battery would be a consideration for vehicles that are not driven regularly.
Post28-11-2013, 21:13    Subject: Weak battery, save with second Quote
As I said, all of this is just theory, and to that I would add: nonsense, it doesn't do anything! Deeply discharged and sulfated batteries can never be restored to their original condition.
icon_smile_thumb_up.gif icon_wink.gif. Such actions are a waste of time with deeply discharged batteries older than 3 years - they fail in 90% of cases and are simply a waste of time. Experience has shown that the battery will eventually need to be replaced. Why not right away?
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
klahaui
Avatar-klahaui
Post28-11-2013, 21:49    Subject: Weak battery, save with second Quote
Had only half-grasped it, as mentioned before.
Then I'd probably rather save the money and buy a new one at the beginning of the session. icon_wink.gif
DieselBĂ€r30x
Post28-11-2013, 22:37    Subject: Weak battery, save with second Quote
Hello everyone!
@Klaui: Ich wĂŒrde sogar OpaAutoschrauBĂ€r's Quote von 90 auf 97% erhöhen. Und selbst wenn Sie mit Ihrem alten Akku unter den "glĂŒcklichen" 3% liegen, dann werden Sie feststellen, dass dieser Sie im ungĂŒnstigsten Moment plötzlich im Stich lĂ€sst; vorzugsweise um 3 Uhr morgens in der WĂŒste, ohne Funkkontakt. Phone is dead icon_wink.gif
As you know, I also enjoy playing and want to know. Therefore, I can easily understand that it interests you. So, just do it. Don't expect anything from it. icon_cool.gif
Post29-11-2013, 1:05    Subject: Weak battery, save with second Quote
Then I'd probably rather save the time and buy a new one at the beginning of the session. icon_wink.gif
Exactly - and we'll avoid further pointless discussions and close this here icon_wink.gif
No new posts Schwache Leistung==> nicht LLM! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0 MJ 2002, Batterie entladen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Batterie (Akkumulator): Tipps zu Check und Wartung Technical Articles
No new posts ot: abschied die zweite Diesel Engine Technology
No new posts Golf Window Lifter - Part 2! Transmission, Chassis, Body & Interior
No new posts Festgegammelte Schliesszylinder retten Transmission, Chassis, Body & Interior
No new posts VW Turbodiesel from Golf 2, salvageable or beyond repair??? Diesel Engine Technology
