2.0 TDI CR (CAGA): Cold Start Issues & Fixes
Go to page: 1, 2  Next
Mike3BG
Post09-09-2013, 12:06    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
Hello!
I have an A4 (2010) with a CAGA 2.0 TDI CR engine. The problems started with a slightly rough idle immediately after a cold start (even in the summer). Unfortunately, it's all very sporadic. For example, there are no problems for two weeks, then it happens once.
"Interestingly, the tachometer needle would briefly jump at exactly 4 seconds after the engine started. Afterward, the car would run normally. Sometimes the needle would only dip briefly, while other times it would stay low for a few seconds, and the engine would run very unevenly, as if it wasn't getting fuel. I thought it might be 'air in the system,' because it always happened exactly 4 seconds after starting. However, I couldn't find any leaks."
Unfortunately, there has never been a memory error.
"But today, something completely strange happened, which rules out the possibility of 'air in the system' again. The cold start was as usual, no rough idle immediately after starting, I drove out of the garage, everything normal (still no problem, logically, the problem only occurs immediately after the cold start). I stopped in front of the garage door to let my son get in. The engine then idled for about 20 seconds. After that, I drove off, accelerated, shifted into second gear, and suddenly the engine started sputtering and jerking, it wouldn't accelerate (no power), and it could barely maintain its speed (about 30 km/h). This lasted for about 3-4 seconds, then the engine ran normally again. And this time, I thought that with such a 'complete failure,' there *must* be something stored in the memory. But unfortunately, there was NOTHING again!"
Here's my question for the experts: What could be causing the engine to run so poorly without any error codes being stored? Could it be a "stuck" or clogged EGR valve? What component "activates" exactly 4 seconds after a cold start, causing an unstable idle?
The fact is that the two problems must have the same underlying cause. My suspicion lies with the AGR (Abgasrückführung - exhaust gas recirculation system), but that's just my assumption. However, one should be able to rule out an electrical problem, since connection errors would normally be immediately recorded in the memory. Perhaps a professional could explain this.
Mein Freundlicher sagt daß das schwer wird zu finden, da es Audi ihnen auch immer schwerer macht. Keine Sollwerte mehr und geführte Fehlersuche nur mehr bei Fehleintrag. Na super! Ich habe mich dann angeboten jeden Kaltstart mit VCDS mitzuloggen. Die Frage ist nur WAS soll ich mitloggen? II was thinking about:
Air mass (AGR rate).
Fuel pressure.
Fuel temperature.
Coolant temperature.
Intake air temperature.
"Does anyone have any suggestions on where to look for the problem? What exactly happens 4 seconds after a cold start? Something is being triggered, but what?"
Thank you for your help!
Greetings.
Translated on 14-09-2026, 18:49.
Post09-09-2013, 14:54    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
You can log the fuel pressure in the advanced measurement data blocks.
Translated on 14-09-2026, 18:53.
Mike3BG
Post09-09-2013, 16:11    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
Best regards, Rainer
Hello Rainer!
Okay, thank you, I will. But one question: Isn't the fuel pressure "monitored"? I mean, doesn't the engine control unit (ECU) throw an error if the pressure drops below a minimum level? Does only the common rail high-pressure pump (CR-HDP) build up the pressure, or is there an additional pre-lift pump in the tank for the common rail system (CR)?
Greetings.
Mike3BG
Post10-09-2013, 14:06    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
Hi, it's me again.
Today, I did a logging run. No errors occurred yet, which would have been too good to be true. However, I need some baseline values so I can compare them if an error does occur. Unfortunately, the CSV converter isn't working correctly, so I still have to manually edit the data.
Unfortunately, I don't understand the following:
Why are the target and actual values for air mass specified in different units? Sometimes it's g/s, and sometimes it's mg/stroke. How is one supposed to compare them?
Furthermore, I'm unsure which specific blocks I should actually log.
Currently, I have:
Throttle position.
Main injection start timing.
Fuel pressure.
Fuel pressure setpoint.
Fuel temperature.
Boost pressure, actual value.
Target boost pressure.
Air mass value.
Air mass setpoint.
Engine start, initial amount.
I want to replace the blocks "Main injection start timing" and "Engine start injection quantity" with something more useful, because the engine always starts normally; the problems only occur sporadically after the start.
Welche Werte sind sinnvoll? Motordrehzahl? Irgendwas bzgl. AGR? What would that be?
Sure, here's the translation:
"thx"
Greetings.
Translated on 14-09-2026, 18:56.
Post10-09-2013, 14:09    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
Why are the target and actual values for air mass specified in different units? Sometimes in g/s and sometimes in mg/stroke. How is one supposed to compare them?
There are likely more entries to be found, specifically for "air mass setpoint/actual value," where the appropriate unit will appear. Just do a little searching.
It's not important to log as many different measurements as possible, but rather to log the right ones at the highest possible sampling rate.
The throttle valve position might also be an interesting parameter to consider, in addition to engine speed and fuel pressure.
Possibly, an additional log could be included, showing the injection amount in case of an error.
Translated on 14-09-2026, 18:59.
Post10-09-2013, 15:48    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
I was just at the icon_lol.gif and asked the electrician about this issue.
He said that they had already encountered several cases of faulty injectors causing rough running, even without any error messages being stored.
Translated on 14-09-2026, 19:00.
Mike3BG
Post10-09-2013, 15:58    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
@Rainer
Since the error occurs very rarely and only for a short time, I need to include as much as possible. A maximum of 12 items can be included.
I already have the throttle body adjusters. But what do you mean by "fuel injection amount"? Are you referring to the values for the 4 injectors that also control the idle stabilization? If I install those 4, then 4 other things need to be removed icon_rolleyes.gif.
Thanks "Autoservice" for the tip. Would you also see it reflected in the values of the four fuel injectors? I'm not currently running those, as they would take up four slots.
Greetings.
Translated on 14-09-2026, 19:01.
Post10-09-2013, 16:56    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
Do I need to include as much as possible
No.
Logging unnecessary data is not only superfluous, but it also results in a lower sampling rate for the interesting measurements. If the sampling rate is too low to meaningfully track changes in the interesting measurements, the entire process is useless. icon_idea.gif
You're doing it because you want to see something, not because you want to have a huge number of values in a file that then don't mean anything, right?
Regarding the injectors:
You can also find these test values in the extended measurement data blocks. Reading these test values is not critical and can always be done. It would be advisable to do so, following the suggestion from Autoservice.
Translated on 14-09-2026, 19:02.
Mike3BG
Post10-09-2013, 17:13    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
"In principle, I agree with you, but I think all 12 selected blocks are useful. Do you really think the sampling rate is too low? Keep in mind that I don't have many opportunities to capture it, as it's very rare and only occurs briefly."
The thing about the injectors sounds plausible, but what surprises me is that I never had any problems after the first minute. Even if I turn the engine off again, like with the start/stop function, for example.
Ein Injektorproblem könne doch auch im warmen Zustand auftreten und außerdem, ein Injektorproblem läßt den Wagen im 2.Gang überhaupt nicht mehr beschleunigen? Es war eigentlich kein Ruckeln, er beschleunigte nicht, keine Power. Nach 3 sek. 0-Power war alles wieder normal, ohne Fehler im Speicher. Und das mehr als 1 Injektor gleichzeitig def. ist? Hmmmmm.
I find it disgusting. Such a complete failure, and NOTHING is in the memory. icon_sad.gif
Greetings.
Translated on 14-09-2026, 19:04.
Post10-09-2013, 18:05    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
Here are the calibration points for the injectors at different pressures for comparison, as seen on my CFFB.
Here's another VCDS configuration file for the relevant advanced measurement values.
 Injektor Kalibrierpunkte mit VCDS auslesen.
 File size:  163.33 KB
 Viewed:  10786 times
CFFB-Injektor-Kalibrierpunkte.a01
 Injektor Kalibrierpunkte in erweiterten Messwertblöcken finden (CFFB Motor).
 File name:  CFFB-Injektor-Kalibrierpunkte.a01
 File size:  84 Bytes
 Downloaded:  404 times
Translated on 14-09-2026, 19:05.
Mike3BG
Post10-09-2013, 19:12    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
"Quick question:"
Why does my LOC 48, which displays "coolant temperature at the radiator outlet," ALWAYS show 90 degrees? Could the problem be hidden here? All other temperatures show approximately ambient temperature during a cold start, but this value is stuck at 90 degrees!
Greetings.
Mike3BG
Post11-09-2013, 8:18    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
Okay, Loc 48 is the target value. But why is the target value already 90 degrees during a cold start?
Greetings.
Translated on 14-09-2026, 19:06.
Post11-09-2013, 10:23    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
Greetings
Not all values in the extended measurement data blocks make sense or are correct.
VCDS displays the data that comes from the control unit. If the control unit sends values that are not actually used, VCDS will still display them.
This means that, compared to the "old" standard measurement blocks, it requires more careful consideration of what each value represents and whether it is even plausible.
The coolant temperature should be available in other places as well, possibly in different contexts.
Translated on 14-09-2026, 19:07.
Mike3BG
Post11-09-2013, 20:42    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
How can I create such a file (containing the same LOCs) and assign it, so that I don't have to re-select everything from scratch every time?
What does the "Turbo!" button mean in the advanced MWB (Material Workbench) settings?
I haven't found anything else about air mass except for the information mentioned above, unfortunately with different units.
Greetings.
Translated on 14-09-2026, 19:08.
Post11-09-2013, 21:16    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
Translated on 14-09-2026, 19:09.
Mike3BG
Post12-09-2013, 10:27    Subject: 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Quote
Okay, and where can I find these "instructions"?
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Relais-Klackern" nach Startphsae / Kaltstartprobl Diesel Engine Technology
No new posts "Airbag-Warnung" nach Sitzverstellung Transmission, Chassis, Body & Interior
No new posts Audi 100 2.5 TDI, engine code ABP, issues after chip tuning Diesel Engine Technology
No new posts Engine Noise After Timing Belt Replacement Diesel Engine Technology
