bindpe Blaumann
Joined: 08/25/2006 Posts: 203 Karma: +5 / -2 Location: ingolstadt
15-09-2013, 13:32 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
Hello everyone,
"On my Golf III, the driver's side door always drops down a few millimeters when opened. According to the AKTE parts catalog, there are a total of 4 parts per door (2 separate hinge pieces). Do I need to replace all of them? Or is it only one half of the hinge that typically fails?"
THANK YOU. Golf III TDI AHU 402Tkm
Translated on 31-08-2026, 22:59.
Herbert Profi-Schrauber
15-09-2013, 15:53 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
How does the door drop? Is there excessive play in the hinges, or is the door with the lock simply too deep for the locking bolt?
Herbert. Horch A4 8K CJCD
Translated on 31-08-2026, 23:00.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
15-09-2013, 16:30 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
The parts on the door side (the ones with the hinge pin) need to be replaced.
First, check which hinge is affected and whether the set screws are properly tightened. These screws secure the hinge pins to the hinge half attached to the car body. LG, Onkel BM
Translated on 31-08-2026, 23:01.
bindpe Blaumann
15-09-2013, 18:19 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
Hello.
"If the door is open, you can get it to lift quite a bit. Then you can see that the lower hinge is mostly the one that's loose."
The set screws are tight. If I unscrew them, will the hinge fall apart into two pieces?
"Are the parts on the door frames the same for the 4-door model, right? Could I get some from a scrapyard then? The rear ones are usually in pretty good condition."
15-09-2013, 18:39 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
Quote: | | Could I get some from Schrotti, or what? |
It's not worth it - they cost 15.- each when  new. LG, Onkel BM
Translated on 31-08-2026, 23:02.
bindpe Blaumann
15-09-2013, 20:05 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
Are they already painted, or at least primed? Golf III TDI AHU 402Tkm
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
15-09-2013, 23:12 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
It is known that the hinges, especially in cars frequently used by grandparents (OMAs & OPAs), tend to wear out quickly, particularly those used for holding the door while getting in and out.
It is usually delivered primed and can be easily painted with a spray can in the desired color. Before installation, it is a good idea to lubricate the hinges properly for a longer lifespan. NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 31-08-2026, 23:03.
Profile PM Email Garage |
bindpe Blaumann
16-09-2013, 11:06 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
Okay, I've skipped over the part about grandma and grandpa for now. I've actually been driving like this for 9 years, but now it's gotten so bad that the TÜV (German technical inspection) is objecting to it.
How do I best do that? Should I unscrew the set screws and then be able to lower the door?
How can I disconnect the cable connection?
Translated on 31-08-2026, 23:04.
16-09-2013, 12:19 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
Quote: | How do I do that best? Should I unscrew the set screws, and then will I be able to lower the door?
How can I disconnect the cable connection? |
Actually, the door doesn't need to be installed for that.
First, replace the broken hinge.
Loosen the screw on the door, completely unscrew the set screw. An assistant holds the door firmly, replace the hinge, insert the set screw and tighten it properly, adjust the door alignment, and tighten the hinge.
The same applies to the upper hinge.
If necessary, adjustments may need to be made on the body to ensure the door is properly aligned, especially if it still sags. If the door is slightly too high when opening, it can be pressed down slightly in the rear area of the door frame. Ideally, the door should move slightly upwards when opening, as this allows the hinges to settle and prevents the door from sagging further due to its own weight. LG, Onkel BM
Translated on 31-08-2026, 23:05.
bindpe Blaumann
16-09-2013, 17:57 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
Thank you for your help. I ordered the hinges today. They cost 25 euros for 2 pieces.
I will report back after the installation.
vg Golf III TDI AHU 402Tkm
Translated on 31-08-2026, 23:07.
bindpe Blaumann
16-09-2013, 20:32 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
Do I need this tool? "Hazet 2597 Quick-Release Bit Holder" Golf III TDI AHU 402Tkm
16-09-2013, 21:37 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
Quote: | | Do I need this tool | ?
A better option would be to use a Torx bit, but it can also be done with a suitable Torx bit and two sturdy, flat ring wrenches.
It's not a problem on the door side.
It becomes problematic if you need to detach the body side halves. The front screw of the lower hinge is partially covered by the fender.
Overall, you need a bit of improvisational talent. LG, Onkel BM
Translated on 31-08-2026, 23:08.
bindpe Blaumann
18-09-2013, 21:35 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
Sure, here's the translation:
"Another question: Am I not allowed to paint the area where the door rests against the frame, specifically where the hinges are?"
Translated on 31-08-2026, 23:09.
18-09-2013, 22:01 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
No, you shouldn't do that, because the door might shift, or you might have to tighten the screws to their maximum load capacity.
A touch of color haze doesn't really hurt.
Then, apply some spray wax or spray lubricant around the edges of the hinge.
Okay, enough chatting --> now let's get to work  . LG, Onkel BM
bindpe Blaumann
19-09-2013, 21:05 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
"Okay, enough talk --> let's get to work."
Yes, the Meister  door hinges are already painted.
Thanks again for the tips. Golf III TDI AHU 402Tkm
Translated on 31-08-2026, 23:10.
bindpe Blaumann
24-09-2013, 17:24 Subject: Golf 3 Door Hinge: What to Replace? (Solved) |
Thank you again for your help.
The replacement went smoothly. It turned out that only the lower outer part was damaged.
"vg"
This is a common abbreviation for "very good" in German. It is often used in online forums and chat rooms.
Peter. Golf III TDI AHU 402Tkm
Translated on 31-08-2026, 23:11.
