chriskross Blaumann
Joined: 04/19/2006 Posts: 304 Karma: +3 / -0 Location: Österreich
05-04-2011, 8:49 Subject: Golf V MFA: Specs, Problems & Review |
Hello.
I have a Golf V (year 2005) and I want to retrofit an instrument cluster with MFA (Multi-Function Display). I might be able to get one from a 2008 vehicle, part number 1K0920874B, which includes a PIN code. Is this instrument cluster compatible with the WFS (likely referring to a specific control unit or system)?
Can someone tell me which pins I can connect to for a quick setup to check if the AI is selling me a good product (without pixel errors)?
Thank you very much.
Chris.
| Description: |
 Download |
| File name: |
Log Golf PlusI-WVWZZZ1KZ6W531xxx-66930km.txt |
| File size: |
7.33 KB |
| Downloaded: |
828 times |
A6 AFB
A6 BRE DPF
Translated on 27-07-2026, 8:37.
Deus Violentia Schrauber
05-04-2011, 11:07 Subject: Golf V MFA: Specs, Problems & Review |
1 - KL 15
2 - KL 30
19 - KL 31
Connector housing: 1K0972977A
The entire system should be WFS-compatible, but you also need the login credentials for the CURRENT tachograph. If you need someone to determine the login credentials, please send me a private message!
If the new AI system has a range of more than 100 kilometers, setting your mileage will become difficult. Please keep this in mind, as Volkswagen can only support this function up to 100 kilometers, and only once, with an increase.
I recommend using a system from before 2006, as it will be much easier to deal with.
BKD GRF
AHF EBF
Translated on 27-07-2026, 8:39.
mullemaus Guest
07-04-2011, 20:42 Subject: Golf V MFA: Specs, Problems & Review |
I recommend a cut-off date of 2006, as making the whole process easier is much more feasible by then.
Why is that?
1 - Terminal 15 / 12V
2 - Terminal 30 / 12V
19 - Terminal 31 / Ground.
12 - CAN Low Combination.
13 - CAN High Combination
Translated on 27-07-2026, 8:41.
chriskross Blaumann
08-04-2011, 12:29 Subject: Golf V MFA: Specs, Problems & Review |
Hello!
Weil ab 2006 die Wfs geändert wurde, und man zum Loginauslesen den passenden Schlüssel braucht bzw. wenn man den nicht hat gehts nur per Programmer. Xprog
"Regarding the pin configuration: If I connect the pins directly to the VCDS interface, can I then directly read data from the instrument cluster?"
Best regards, Chris.
A6 AFB
A6 BRE DPF
Translated on 27-07-2026, 8:42.
08-04-2011, 15:28 Subject: Golf V MFA: Specs, Problems & Review |
As far as I know, a CAN gateway module is required in between.
BKD GRF
AHF EBF
mullemaus Guest
08-04-2011, 21:03 Subject: Golf V MFA: Specs, Problems & Review |
As far as I know, a CAN gateway module is needed in between.
Nein. Sure.
Also nein.  The WFS is the same as always. Only a specific byte is different. If you patch the dataset, it works without a key.  It's similar with WFS V.  Don't believe everything that various self-proclaimed GURUs spread.
Translated on 27-07-2026, 8:43.
chriskross Blaumann
14-04-2011, 10:45 Subject: Golf V MFA: Specs, Problems & Review |
A6 AFB
A6 BRE DPF
Translated on 27-07-2026, 8:45.
Frankbe Blaumann
Joined: 12/07/2012 Posts: 51 Karma: +9 / -0 Location: Söhrewald 2015 Seat Leon Premium Support
21-12-2014, 11:48 Subject: Golf V MFA: Specs, Problems & Review |
Deus Violentia wrote: | 1 - KL 15
2 - KL 30
19 - KL 31
If the new AI system has a range of more than 100 kilometers, setting your mileage will become difficult. Please keep this in mind, as Volkswagen can only support this up to 100 kilometers, and only once, with an increase.
I recommend a deadline of 2006, as it makes the whole process much less painful. |
I also want to install a different keyless entry system with MFA in my car, but I don't have the login credentials for the old one. I already have a new keyless entry system with a login code.
Seat Leon 3 ST (5F)
2,0 TDI MKB:CUNA
Translated on 27-07-2026, 8:47.
Profile PM Garage |
Steffen W Profi-Schrauber
Joined: 07/05/2008 Posts: 1276 Karma: +104 / -0 Location: Altenburg
21-12-2014, 14:17 Subject: Golf V MFA: Specs, Problems & Review |
You could have the AI specialists at Volkswagen handle the switchover. They can train you on the new combination instrument with the connected tester, and that would probably be the easiest way to do it.
The car dealership cannot tell you your PIN directly.
You could also download the dump and upload it. Then I would tell you your PIN. But of course, that's nonsense. Because if you can do that, then you can also read your own PIN yourself.  .
Passat Variant BGW 2005
Translated on 27-07-2026, 8:49.
mullemaus Guest
21-12-2014, 15:44 Subject: Golf V MFA: Specs, Problems & Review |
Can you read the pin from a Golf5 dataset?
21-12-2014, 18:02 Subject: Golf V MFA: Specs, Problems & Review |
Nein,natürlich nicht. Only via OBD.
I already wrote that it's nonsense.
Translated on 27-07-2026, 8:50.
mullemaus Guest
21-12-2014, 20:03 Subject: Golf V MFA: Specs, Problems & Review |
I did write that it's nonsense.
I had read that differently  .
You could also download the dump and upload it. Then I would tell you your PIN. But of course, that's nonsense. Because if you can do that, then you can also read your own PIN yourself. icon_smile.gif
You can also manually download the dump file. That's why I'm asking this question.
Finding the PIN in that way is possible, I just didn't know that someone here in the forum could do it  .
Translated on 27-07-2026, 8:51.
21-12-2014, 22:38 Subject: Golf V MFA: Specs, Problems & Review |
"I'm sorry, I completely missed that it was about a G5 AI. It's easy to get distracted when the gingerbread is delicious and the coffee is good. Don't always be so strict. I'm also sorry."
I can extract it manually from the dump for the 3B0 and 1J0 control units. I can also do it for the standard 501 unit and the shifted 503 unit.
The easiest option for the original poster would be to either extract the PIN code using specialized equipment connected via OBD, or have it retrieved and programmed by a Volkswagen dealership.
Furthermore, you could overwrite the existing "Immo Block" data with data from the old keyless entry system. This would eliminate the need for pairing. However, to do this, you need to know the offsets of the 1K0 module and have the same equipment.
The person asking the question probably can't do that either.
Do you happen to have a 1K0 dump available for quick access, perhaps for expanding my horizons?
Translated on 27-07-2026, 8:53.
mullemaus Guest
21-12-2014, 22:57 Subject: Golf V MFA: Specs, Problems & Review |
That could be good.
| Description: |
 Download |
| File name: |
1K0920873BX_Eeprom_VIRGIN_orig.rar |
| File size: |
1.42 KB |
| Downloaded: |
367 times |
Translated on 27-07-2026, 8:54.
22-12-2014, 7:04 Subject: Golf V MFA: Specs, Problems & Review |
Frankbe Blaumann
13-01-2015, 16:33 Subject: Golf V MFA: Specs, Problems & Review |
Steffen W wrote: |
You could also download the dump and upload it. Then I would tell you your PIN. But of course, that's nonsense. Because if you can do that, then you can also read your own PIN yourself. . | And how do I do that with the dump? Also, I can't access channel 50 in the WFS.
Seat Leon 3 ST (5F)
2,0 TDI MKB:CUNA
Profile PM Garage |
