TDI Fuel Pump Priming: How to Bleed It (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Troubleshooting & Guides
dieselschrauber Post29-09-2014, 12:58
The electric fuel pump can be activated in many Pump-Düse (PD) or Common-Rail (CR) TDIs using the selective actuator test. The diagnostic tool used in the Screenshot is VCDS.
Alternatively, it is often possible to control these functions via the engine control unit, using the basic settings (channel 35 or a similar function in the drop-down list).
The purpose of this procedure is to bleed the fuel system, for example, after installing a new diesel filter or performing repairs on the fuel injection system.
 Elektrische Kraftstoffpumpe zum Dieselfilterwechsel per VCDS Ansteuern (selektive Stellglieddiagnose).
 File size:  56.69 KB
 Viewed:  52892 times
Translated on 08-09-2026, 15:53.
Ratings - TDI Fuel Pump Priming: How to Bleed It
Average rating: 3.50 - worst rating: 2 - best rating: 5 - number of ratings: 2 - View ratings
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Audi A2 to A6 Good Will Policy, Electrical System Area Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Electric Windows for 35i Models Transmission, Chassis, Body & Interior
No new posts A4 B6 1.8T BFB Fuel Pump Gasoline Engine Technology
No new posts Audi A3 accidentally filled with E10 fuel, fuel pump failure Gasoline Engine Technology
No new posts Bleed brakes with ABS, Bosch version 5.3 Diesel Engine Technology
