Passat 3c, front fog light, left, long-range light
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
chriskross
Post19-08-2013, 21:21    Subject: Passat 3c, front fog light, left, long-range light Quote
Hello!
Today, I noticed on a Passat 3c that when the long-range headlights are turned on, the left fog light also turns on and stays on as long as the long-range headlights are on.
I need to look into this further, perhaps someone has already encountered this before.
What could be the cause of the problem with the central control unit?
A6 AFB
A6 BRE DPF
Post20-08-2013, 8:26    Subject: Passat 3c, front fog light, left, long-range light Quote
If I remember correctly, you can program the control unit for the lighting system so that both lights are on when using long-distance lights.
chriskross
Post20-08-2013, 9:34    Subject: Passat 3c, front fog light, left, long-range light Quote
No, when the headlight switch is in the low beam position, both headlights turn on.
A6 AFB
A6 BRE DPF
Post20-08-2013, 9:39    Subject: Passat 3c, front fog light, left, long-range light Quote
Turn the steering wheel to the RE position and check if the corresponding RE-side headlight then turns on.
Post21-08-2013, 10:53    Subject: Passat 3c, front fog light, left, long-range light Quote
Autoservice wrote:
Turn the steering wheel to the right and check if the right-hand turn signal light then comes on.
My theory about the underlying theory:
Headlights are "on"
The turn signal lights are coded as fog lights.
Therefore, some people will honk their horn (i.e., use their horn as a warning signal) when using auxiliary lights (i.e., also known as a warning horn).
No new posts Front Wheel Bearing Noise (Golf 4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Avoid squeaking windshield wipers at the front General Tips
No new posts Octavia I 1999 - Front wipers only work when it's dry General Tips
No new posts Passat 3bg 1.9 TDI PD / Brake, front left, under pressure Transmission, Chassis, Body & Interior
No new posts Low beam, high beam, and headlight flash with xenon in th... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3C: Front Blinkers / Turn Signal Lights Transmission, Chassis, Body & Interior
No new posts Passat 3C left inner rear light, US version Upload
