Polo 9N3: Check fuel pump after timing belt change
Go to page: 1, 2  Next
New Topic 🔒 Locked 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
stolley
Karma: +38 / -1   Thank you, like it!
Post05-10-2013, 20:36    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
Hello everyone!
My Polo 9N3 (3-cylinder diesel engine with DPF and BWB) has a faulty hydraulic lifter. Consequently, the camshaft also needs to be replaced.
I had the head unit serviced by a specialist who, at the same time, replaced all the wear parts and adjusted the PD elements.
I once read somewhere that after a re-installation, you might need to re-check or readjust the start of the pumping process?
Geht das mit VCDS? If so: how?
Thank you all!
Translated on 21-09-2026, 19:29.
Karma: +1353 / -0   Thank you, like it!
Post05-10-2013, 20:50    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
Look over there.
/viewtopic.php?t=10515&highlight=synchronization angle
Otherwise, you could take a look at the synchronization angle.
Translated on 21-09-2026, 19:30.
stolley
Post05-10-2013, 20:55    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
Hello Herbert!
Thank you very much for the link!
It's very useful, and this "synchronization angle" is exactly what I was looking for.
I suppose I need to check measurement block 4 in the STG 1.
VG
Volker.
Translated on 21-09-2026, 19:31.
Post05-10-2013, 21:07    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
Okay, in the image, the value 4 refers to the "rotation angle."
Ideally, the value should be between 0° and -0.5°. +/-2° is acceptable if the engine is running well.
Translated on 21-09-2026, 19:32.
stolley
Post12-11-2013, 8:05    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
Hello everyone!
Regarding this, I'd like to ask all Polo 9N3 drivers one more question:
Is this measurement block located in control unit 1, block 4?
Or do I need to look for it in a different control unit?
Translated on 21-09-2026, 19:33.
Post12-11-2013, 8:41    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
Or do I need to look in a different control unit?
In which engine control unit, other than the engine control unit, should the camshaft angle relative to the crankshaft be stored, in your opinion? icon_cool.gif
stolley
Post12-11-2013, 22:07    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
That's also true!
I'm just asking because the MSG hasn't responded since the last time the error memory was cleared...
What could be the reason for that?
The engine is otherwise in perfect working order!
Translated on 21-09-2026, 19:34.
Post12-11-2013, 22:28    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
Okay, please upload the Autoscan file first and make sure to disable the radio during the diagnostic process.
Translated on 21-09-2026, 19:35.
stolley
Post12-11-2013, 22:35    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
Hmm, I can't say for sure whether the car radio was turned off.
I'll try it again, making absolutely sure the radio is turned off this time!
Disconnecting and reconnecting the battery might not hurt, right?
Here's the automatic scan, just for the record:
Tuesday, November 12, 2013, 9:50:27 PM.
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: 12.12.0.0
Data as of: 20131006
Vehicle Identification Number: WVWZZZ9NZ8B0xxxxx License Plate:
Mileage: 207,130 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 9N (9N3 - Polo)
Scan: 01 03 08 09 15 17 19 25 44 46 76
Vehicle Identification Number: WVWZZZ9NZ8B031810
Mileage: 207,130 km
Address 01: Engine Control Module
Label file: RKS\045-906-013-BMS.clb
Part number SW: 045 906 013 E Hardware number: 045 906 013 E
Part: R3 1.4L EDC G000SG 4271
Revision: --H03--- Serial number: VWZ7Z0G5933092
Coding: 0003071
Operating number: WSC 49000 143 80495
VCID: 112F82EC0B0893960BD
No error codes found.
or error codes are not supported by the control unit.
or communication errors occurred.
Address 03: Brake Electronics
Label file: RKS\6R0-907-37x-ESP80.lbl
Part number SW: 6Q0 907 379 AS, Hardware: 6Q0 907 379 AS.
Component: ESP 8.0 front panel
H05 0003
Revision: 00000000 Serial number: 00000000000000
Coding: 0002365
Operating number: WSC 00046 412 00000
VCID: 8E1519909A360C6E96F-515A
Address 08: Climate Control/Heating. Label file: RKS\6Q0-820-045.lbl
Part number: 6Q0 820 045.
Component: Air conditioner X0850
VCID: EADD7500961E804EAA7-515A
Address 09: Central Electronics
Label file: RKS\6Qx-937-049-C.lbl
Part number: 6Q1 937 049 F
Component: 0009 BN-SG. 2S36
Encoding: 09646
VCID: 3E7509503A165CEEA6F-515A
Address 15: Airbag
Label file: RKS\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 K
Part number: 19 AIRBAG VW51 0P 0010.
Encoding: 12601
VCID: 2C513318DC6ADE7E18B-515A
Address 17: Control unit insert
Label file: RKS\6Q0-920-xxx-17.lbl
Part number: 6Q0 920 825 F
Component: VDO V06 COMBINATION INSTRUMENT.
Coding: 01132
Operating number: WSC 00000
VCID: 377B1C74152C6DA6659-515A
Address 19: Diagnostic interface
Label file: RKS\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: 01K1 GATEWAY CAN 2S36
Encoding: 00014
VCID: F0E96768B0C27A9EE43-515A
Address 25: Immobilizer
Label file: RKS\5J0-920-xxx-25.clb
Component: VDO V06 IMMOBILIZER.
Coding: 01132
WVWZZZ9NZ8B031810 VWZ7Z0G5933092
Address 44: Steering Assist
Label file: RKS\6Q0-423-156.clb
Part number: 6Q0 423 156 AB
Component: Power Steering Unit - TRW - V270.
Encoding: 10110
VCID: 6FEBE4142DFCE5667D9-515A
Address 46: Comfort System
Label file: RKS\6Q0-959-433.lbl
Part number: 6Q0 959 433 E
Component: 3F Comfort Device 0002
Coding: 00019
VCID: 3D770E5C371047F6BF5-4B18
Address 76: Parking Assist
Label file: RKS\7H0-919-283.lbl
Part number: 7H0 919 283 A
Component: Parking system 24 KUH 402.
Encoding: 00102
VCID: 30692768F042BA9E243-515A
End.
Translated on 21-09-2026, 19:47.
Post13-11-2013, 10:21    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
Translated on 21-09-2026, 19:59.
stolley
Post13-11-2013, 11:48    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
Another "beginner's question":
Can I also log the measurement of the synchronization angle somehow?
Post13-11-2013, 11:57    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
You can log the measurement data to a file.
Please note, due to the extreme cold outside: The synchronization angle is relatively uncritical within a certain range; it is sufficient if it falls within the tolerance range specified in the tooltip.
However, it should be noted that the values a) may change slightly after the first few kilometers with a new timing belt, and b) the values are different when the engine is warm compared to when it is cold. The reason is that the warm engine block is slightly larger than a cold one, and because the tensioner only allows a slight shift in the rotational axis of the shaft on one side, one shaft rotates slightly relative to the other.
The values should therefore be checked with the engine at operating temperature, as a reading that is close to the limit when the engine is cold may become even worse when the engine is warm.
Translated on 21-09-2026, 20:00.
stolley
Post13-11-2013, 22:22    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
As promised, here's the feedback from the evening's experiment:
At first, I thought everything was fine.
The radio was turned off, and the MSG (Modular Signaling Gateway) responded immediately during the error scan.
However, STG 03 did not respond again.
In the control unit selection process, the MSG did not respond again.
I haven't disconnected the battery yet.
Could it also be related to the fact that I'm running Windows on my MacBook using VMware Fusion?
I could also try it again using Bootcamp.
Translated on 21-09-2026, 20:02.
Post14-11-2013, 10:18    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
yet.
It would also be completely pointless, at least as far as the engine control unit is concerned, since it wouldn't have any power anyway without ignition.
Okay. Perhaps check if any background programs are running that might temporarily interrupt VCDS.
Translated on 21-09-2026, 20:03.
stolley
Post20-11-2013, 16:34    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
Okay, now the measurement is working!
However, I recently acquired an old Windows laptop.
Now it works.
According to the data, the twist angle at the operating temperature of the engine is -2.3°.
Is it still within the acceptable range, or what?
The engine is running smoothly, like a purring kitten. And the fuel consumption was 4.6 liters according to the display after a highway drive today. Yes, I was driving slowly! icon_razz.gif
I'd also be interested to know: Does this suggest a later or earlier start of the boost? And what are the theoretical implications? I would prefer the engine to be optimized for longevity.
Best regards!
Translated on 21-09-2026, 20:05.
Post20-11-2013, 18:56    Subject: Polo 9N3: Check fuel pump after timing belt change Quote
The start of the boost is not affected by the NW setting, but the timing of pressure buildup in the pre-combustion chambers and the valve timing. Currently, the NW setting is slightly too early.
Translated on 21-09-2026, 20:06.
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ABC: Engine Start Issues After MSG Replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Electric Window Regulator for Polo 6N2 (Solved) Transmission, Chassis, Body & Interior
No new posts ZR Seal Replacement: Performance Loss Troubleshooting On-Board Diagnostics (OBD)
No new posts Rotation Angle After Z-R Transformation Diesel Engine Technology
No new posts BMR Issues After PPD Switch Diesel Engine Technology
