DAB Antenna Mast with M5 Thread Found
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +1099 / -0   Thank you, like it!
Post10-03-2014, 7:11    Subject: DAB Antenna Mast with M5 Thread Found Quote
I am looking for an antenna rod for the roof antenna that is specifically designed for DAB digital radio (174 - 230 MHz = VHF Band III). To that end, I need someone who can check the spare parts lists and find a part number for me, or I would also be happy to receive a used antenna rod (with M5 thread) that is no longer needed.
EDIT by Guste: Title changed at Hütchen's request.
Translated on 24-09-2026, 6:37.
Post10-03-2014, 15:55    Subject: DAB Antenna Mast with M5 Thread Found Quote
The part number 6R0035849A is explicitly designed for (1) and should have (2) M5 threads.
(1) Index "A" is important so that it is the DAB sausage.
(2) The previous antennas, for example, those on the shark fins, have an M5 thread.
EDIT:
Persistent searching on Google suggests that it is likely an M6 thread.
Probably to distinguish the DAB antenna from the FM antenna.
http://www.briskoda.net/forums/topic/292334-genuine-vw-stubby-aerials/
http://www.vw-audi-shop.com/Original-VW-Dachantenne-Kurzstabantenne-6mm-Gewinde
It is the Polo sausage that has also found its way into Skoda.
Translated on 24-09-2026, 6:38.
Post10-03-2014, 22:05    Subject: DAB Antenna Mast with M5 Thread Found Quote
So, M6 instead of M5? Then the only option is to build it yourself. Thanks for your help so far!
Translated on 24-09-2026, 6:39.
Post10-03-2014, 23:26    Subject: DAB Antenna Mast with M5 Thread Found Quote
"6R0 035 849 A has a 100% M6 thread; I use those myself."
Post11-03-2014, 7:04    Subject: DAB Antenna Mast with M5 Thread Found Quote
Darn it. icon_cry.gif Then I'll have to look across different brands, or maybe build it myself in the end.
Translated on 24-09-2026, 6:40.
Post11-03-2014, 9:24    Subject: DAB Antenna Mast with M5 Thread Found Quote
TDI-GTI-4-Motion wrote:
6R0 035 849 A has a 100% M6 thread, which I use myself at my place.
Counter question:
The part number 6R0 035 849 (without the index) has an M5 thread, just like the older FM antennas (1J0 035 849 A, for example, in the Golf 5), correct?
Eben genau dieser Unterschied (im 2. Image)
Post11-03-2014, 9:54    Subject: DAB Antenna Mast with M5 Thread Found Quote
Okay.
6R0 035 849 - for vehicles without digital radio reception - M5.
6R0 035 849 A - for vehicles with digital radio reception - M6
Translated on 24-09-2026, 6:41.
Styrian
Post11-03-2014, 9:58    Subject: DAB Antenna Mast with M5 Thread Found Quote
...maybe this is a silly question, but: Doesn't the roof antenna have a built-in antenna amplifier in its base? So, while you could theoretically screw on a new "thingy," the amplifier is designed for a completely different frequency. Also, the impedance of the new antenna probably won't match.
Best regards, Styrian.
Translated on 24-09-2026, 6:42.
Post11-03-2014, 10:01    Subject: DAB Antenna Mast with M5 Thread Found Quote
Found:
AIV (Article 194.03.11) - Antenna rod with M5 thread, suitable for LW, MW, FM, and DAB, length 26.5 cm.
"@ Styrian: The antenna base is practically homemade. It's from a Peugeot/Citroen, but the base is slightly larger, which provided more space. I received it as a gift, and the built-in amplifier was corroded due to water damage. I removed it and replaced it with the circuit board from a DAB windshield antenna amplifier. The rod that is screwed onto the base now works with it. The housing was then sealed. After disappointing attempts with a rod that was obviously completely unsuitable for DAB, I accidentally found one that still worked well from up to 70 km away from Berlin. I can't say for sure whether it was specifically designed for DAB. However, it's no longer aesthetically pleasing, which is why I'm looking for a replacement."
Translated on 24-09-2026, 6:43.
Post11-03-2014, 11:53    Subject: DAB Antenna Mast with M5 Thread Found Quote
However, it's no longer aesthetically pleasing, and therefore I was looking for a replacement.
Then just get the complete VW footwell with DAB.
Translated on 24-09-2026, 6:45.
Post11-03-2014, 12:26    Subject: DAB Antenna Mast with M5 Thread Found Quote
My Peugeot foot is still attached; the headliner, which I painstakingly but non-destructively removed and reattached, is back in place. icon_eek.gif Consequently: No! So the foot remains attached, especially since my makeshift solution is well-received. I just need a stylish antenna that also supports DAB.
Styrian
Post12-03-2014, 8:34    Subject: DAB Antenna Mast with M5 Thread Found Quote
@HutfahrerViewing profile: Hutfahrer: Okay... I didn't know about the swapped internals... sorry for bugging you icon_biggrin.gif icon_biggrin.gif.
Translated on 24-09-2026, 6:46.
Post12-03-2014, 9:06    Subject: DAB Antenna Mast with M5 Thread Found Quote
No problem! I had only made the description of the antenna modification available to a few people in the forum and didn't write it out again here. From what I can see, this idea seems to be working quite well, and the relatively low effort involved with the modified antenna base has been worth it.
A pleasant side effect is that I know exactly which technology I'm using for the reception and can therefore assess it quite well myself. I already had the DAB-compatible radio in my previous car and had already gained my first experiences with it. Here there was something to read about it.
Post16-03-2014, 14:31    Subject: DAB Antenna Mast with M5 Thread Found Quote
I didn't want to withhold these pictures from you. The antenna looks like it belongs there. Of course, no one needs to know that this vehicle never originally had a roof antenna. For FM, longwave, and mediumwave radio, the standard window antenna on the A-pillar (visible in the pictures) is still used.
Update: I have now found a suitable antenna rod with DAB functionality and an M5 thread. However, it doesn't perform any better than the one that, purely by chance, also received DAB signals.
If anyone with the appropriate permissions would like to take over the search request from the topic heading...
 File size:  28.46 KB
 Viewed:  1336 times
 File size:  233.53 KB
 Viewed:  1256 times
 File size:  299.93 KB
 Viewed:  1260 times
 File size:  199.79 KB
 Viewed:  2080 times
Translated on 24-09-2026, 6:48.
No new posts Audi A1, A4, Q3, A5, A6, Q5, A7, Q7, A8 (Digital Radio Re... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Bubbles: Find the Root Cause & Fix It! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EDS Regulation flawed! Found the mistake! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts August 1, 2011 - Nationwide launch of digital radio DAB+ Electrical Systems, Vehicle Electronics, Multimedia
No new posts Thread for oil pressure gauge? Diesel Engine Technology
No new posts Injector Threads for VW/Audi AFN/1Z Engines Diesel Engine Technology
No new posts Oil Pan Threads Stripped: Repair & Solutions Diesel Engine Technology
