Michi80 Guest
13-08-2009, 18:05 Subject: Fuel Injection for Hot Start |
Hi, I drive a Golf 4 TDI with a 90 HP ALH engine. Can someone possibly tell me how to modify the injection quantity for hot starting using VAG COM? Thanks in advance.
Translated on 18-08-2026, 20:02.
13-08-2009, 18:27 Subject: Fuel Injection for Hot Start |
You mean the initial guess/starting value. Answer: Yes. I assume you want to use this to solve warm-start problems. MfG. Michael
Profile PM Garage |
Michi80 Guest
13-08-2009, 18:30 Subject: Fuel Injection for Hot Start |
Sure...
Michi80 Guest
13-08-2009, 18:57 Subject: Fuel Injection for Hot Start |
Can we perhaps get some instructions there?
13-08-2009, 20:18 Subject: Fuel Injection for Hot Start |
Sure, here's the translation:
"Please use the search function or relevant articles. I found it in 10 seconds." MfG. Michael
Translated on 18-08-2026, 20:03.
Profile PM Garage |
chli1976 Profi-Schrauber
14-08-2009, 7:41 Subject: Fuel Injection for Hot Start |
Is there a login for EDC16 engine control units (ECUs) that allows increasing the starting fuel quantity, or do these ECUs no longer support this?
Volkswagen Golf V, manufactured in 2005, engine code BKD. VCDS
Translated on 18-08-2026, 20:04.
Tompalatina
Joined: 07/07/2010 Posts: 24 Karma: +2 / -1 Location: Pfalz
10-08-2010, 15:21 Subject: Fuel Injection for Hot Start |
Does anyone happen to know exactly what happens when you increase a value, for example, the initial amount? So, here's an example: If channel 5 is set to 32768 by default, and I want to increase the initial amount by 10%, what value should I try to set it to? Should it be 36045?
And what happens "behind the scenes"? Is the injection time extended while maintaining the same injection start point, or is it something else?
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
10-08-2010, 15:36 Subject: Fuel Injection for Hot Start |
The start of injection is essentially dependent on the coolant temperature and the amount of fuel injected. If the injection quantity (initial injection amount) is changed, the controlled start of injection also changes.
However, this is hardly relevant at the moment of starting, as no regulation can take place yet. Therefore, the static injection start setting (TDI timing checker in VCDS) must be correct.
Unfortunately, the modification mentioned does not play a role in warm start problems, as other factors are relevant here (including the starting speed and the coolant temperature seen by the engine control unit).
Translated on 18-08-2026, 20:06.
Profile PM WWW Garage |
Tompalatina
10-08-2010, 16:16 Subject: Fuel Injection for Hot Start |
Thank you, Rainer, for the quick response!
Do you also know what the values look like (regarding my other question)?
Translated on 18-08-2026, 20:07.
10-08-2010, 16:20 Subject: Fuel Injection for Hot Start |
Quote: | | Do you also know what it looks like from a values perspective (my other question)? |
No, I don't have to either. You can directly see the change in fuel injection amount when you modify the input value.
Tompalatina
10-08-2010, 16:29 Subject: Fuel Injection for Hot Start |
That sounds plausible - I hadn't even thought of that.
Translated on 18-08-2026, 20:08.
Tompalatina
10-08-2010, 22:01 Subject: Fuel Injection for Hot Start |
Okay, new problem. I can't change anything except the idle speed. Apparently, the login isn't working. Without logging in, I can only access channel 2 (idle speed).
Wenn ich einen Login mit 12233 versuche, reißt danach umgehend die Kommunikation ab, und ich werd' aus dem Steuergerät geworfen. Dasselbe passiert mit Logins 26281, 26282, 26252, 26232 und 22158. Ist das ein Zeichen dafür, dass der Login-Code falsch ist, oder hat das eine andere Ursache? EiDo you have any ideas?
By the way, this is the control unit for an automatic seat adjustment system.
10-08-2010, 22:27 Subject: Fuel Injection for Hot Start |
This is because the settings that apply to the ALH engine are not being sent to the ASZ control unit.
Translated on 18-08-2026, 20:09.
Tompalatina
10-08-2010, 22:42 Subject: Fuel Injection for Hot Start |
And with which login MIGHT it work?
11-08-2010, 7:34 Subject: Fuel Injection for Hot Start |
"With none of them, I said it's not about the ASZ."
Tompalatina
11-08-2010, 7:50 Subject: Fuel Injection for Hot Start |
Ah, okay, so I misunderstood that.
Translated on 18-08-2026, 20:10.
