A4 1.8T AEB - No boost / power
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post02-04-2014, 19:42    Subject: A4 1.8T AEB - No boost / power Quote
The A4 is from 1997 and has the engine code AEB. The customer identified a defect in the product's performance and reported increased consumption.
Troubleshooting with VCDS revealed that the mass airflow sensor (MAF) was defective.
A further diagnosis revealed a duty cycle of 99% at the N75 valve across all engine speeds and load conditions, except when the engine was idling. Since this engine does not have a turbocharger pressure sensor, the pressure was measured using an indicator, which showed 0 bar of boost pressure.
The cause of the error was a broken wastegate linkage.
Since I couldn't find a can, I simply welded everything together.
Perhaps some people have made similar mistakes before.
Sure, here's the translation:
"Best regards," or "Sincerely,"
klahaui
Avatar-klahaui
Post02-04-2014, 20:05    Subject: Re: A4 1.8T AEB - No boost / power loss Quote
 File name:  image.jpg
 File size:  1.27 MB
 Downloaded:  3400 times
mullemaus
Post02-04-2014, 20:27    Subject: A4 1.8T AEB - No boost / power Quote
Unfortunately, this has happened to me before. It often breaks cleanly at the beginning of the thread. icon_wink.gif
Karma: +591 / -0   Thank you, like it!
Post02-04-2014, 21:09    Subject: A4 1.8T AEB - No boost / power Quote
Hi!
I'm sorry, but you've really messed up badly.
I've also experienced issues with the 1.8 T engine before, but in that case, the wastegate valve was just very loose, not broken yet.
If I understand correctly, the bolts on the exhaust pipe have broken off.
I always get extremely scared of this kind of horror.
and that's why I will never give up my gas cylinders.
to drill out the bolts.
Then get some welding equipment to heat up the nuts that secure the exhaust manifold.
Don't you dare take the engine out!
And check the plan dimensions for any discrepancies, otherwise it will become even more expensive.
klahaui
Avatar-klahaui
Post03-04-2014, 5:22    Subject: A4 1.8T AEB - No boost / power Quote
Everything's fine, Steffen, nothing broken icon_lol.gif.
Take a look behind the bolt towards the wastegate rod.
I used a rust remover and soaked everything in it about an hour ago, hoping it would work, and it did.
It's running again now, after about 4 hours of work.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BMS Polo: No Boost Pressure Diesel Engine Technology
This topic is locked, you cannot edit or reply. AJM power loss, not turbo pressure Diesel Engine Technology
No new posts V70, no turbo boost, D5 engine, 163 hp Diesel Engine Technology
No new posts AJM Turbo: No Boost Pressure? Diesel Engine Technology
