stolley
22-01-2014, 8:31 Subject: Stuttering During Regeneration: Which MWB Logs? |
Good morning!
My Polo 9N3 (1.4 TDI, 3-cylinder BWB, mileage: 214,000 km, with a recently refurbished cylinder head) has been shaking more noticeably lately during the DPF regeneration process.
Ich möchte während der Fahrt mal die interessanten MWB loggen. WWhat would those be?
And where can I find information about when the next regeneration is scheduled?
Thank you and best regards.
Volker.
Translated on 15-09-2026, 12:46.
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
22-01-2014, 11:32 Subject: Stuttering During Regeneration: Which MWB Logs? |
Please always include an Autoscan report with such questions, because otherwise you either have to guess or do extensive research to find out which control units are installed, instead of simply seeing them.
Translated on 15-09-2026, 12:47.
Profile PM WWW Garage |
stolley
22-01-2014, 18:06 Subject: Stuttering During Regeneration: Which MWB Logs? |
dieselschrauber wrote: | Hello,
Please always include an Autoscan report when asking questions, because otherwise you either have to guess or do extensive research to find out which control units are installed, instead of simply seeing them.
Best regards, Rainer |
Oops, sorry!
Code: | Mittwoch,22,Januar,2014,17:03:08:25065
VCDS -- Windows-basierter VAG/VAS-Emulator
VCDS Version: 12.12.0.0
Datenstand: 20131116
Fahrzeug-Ident.-Nr.: WVWZZZ9NZ8Bxxxxxx KFZ-Kennzeichen:
Kilometerstand: 214500km Reparaturauftrag:
Fahrzeugtyp: 9N (9N - Polo())
Scan: 01 03 08 09 15 17 19 25 44 46 76
Fahrzeug-Ident.-Nr.: WVWZZZ9NZ8Bxxxxxx Kilometerstand: 214500km
Adresse 01: Motorelektronik Labeldatei: RKS\045-906-013-BMS.clb
Teilenummer SW: 045 906 013 E HW: 045 906 013 E
Bauteil: R3 1,4L EDC G000SG 4271
Revision: --H03--- Seriennummer: VWZ7Z0G5933092
Codierung: 0003071
Betriebsnr.: WSC 49000 143 80495
VCID: 112F82EC0B0893960BD-513C
Readiness: 0 0 0 0 1
Adresse 03: Bremsenelektronik Labeldatei: RKS\6R0-907-37x-ESP80.lbl
Teilenummer SW: 6Q0 907 379 AS HW: 6Q0 907 379 AS
Bauteil: ESP 8.0 front H05 0003
Revision: 00000000 Seriennummer: 00000000000000
Codierung: 0002365
Betriebsnr.: WSC 00046 412 00000
VCID: 8E1519909A360C6E96F-515A
Adresse 08: Klima-/Heizungsel. Labeldatei: RKS\6Q0-820-045.lbl
Teilenummer: 6Q0 820 045
Bauteil: Klimaanlage X0850
VCID: EADD7500961E804EAA7-5178
Adresse 09: Zentralelektrik Labeldatei: RKS\6Qx-937-049-C.lbl
Teilenummer: 6Q1 937 049 F
Bauteil: 0009 BN-SG. 2S36
Codierung: 09646
VCID: 3E7509503A165CEEA6F-515A
Adresse 15: Airbag Labeldatei: RKS\6Q0-909-605-VW5.lbl
Teilenummer: 1C0 909 605 K
Bauteil: 19 AIRBAG VW51 0P 0010
Codierung: 12601
VCID: 2C513318DC6ADE7E18B-515A
Adresse 17: Schalttafeleinsatz Labeldatei: RKS\6Q0-920-xxx-17.lbl
Teilenummer: 6Q0 920 825 F
Bauteil: KOMBIINSTRUMENT VDO V06
Codierung: 01132
Betriebsnr.: WSC 00000
VCID: 377B1C74152C6DA6659-515A
Adresse 19: Diagnoseinterface Labeldatei: RKS\6N0-909-901-19.lbl
Teilenummer: 6N0 909 901
Bauteil: 01K1 GATEWAY CAN 2S36
Codierung: 00014
VCID: F0E96768B0C27A9EE43-5178
Adresse 25: Wegfahrsperre Labeldatei: RKS\5J0-920-xxx-25.clb
Bauteil: IMMOBILIZER VDO V06
Codierung: 01132
VCID: 377B1C74152C6DA6659-5178
WVWZZZ9NZ8B031810 VWZ7Z0G5933092
Adresse 44: Lenkhilfe Labeldatei: RKS\6Q0-423-156.clb
Teilenummer: 6Q0 423 156 AB
Bauteil: LenkhilfeTRW V270
Codierung: 10110
VCID: 6FEBE4142DFCE5667D9-5178
Adresse 46: Komfortsystem Labeldatei: RKS\6Q0-959-433.lbl
Teilenummer: 6Q0 959 433 E
Bauteil: 3F Komfortgerát 0002
Codierung: 00019
VCID: 3D770E5C371047F6BF5-4B32
Adresse 76: Einparkhilfe Labeldatei: RKS\7H0-919-283.lbl
Teilenummer: 7H0 919 283 A
Bauteil: Parkingsyst. 24 KUH 402
Codierung: 00102
VCID: 30692768F042BA9E243-5178
Ende -------------------------------------------------------------------- |
Translated on 15-09-2026, 12:48.
22-01-2014, 19:25 Subject: Stuttering During Regeneration: Which MWB Logs? |
For those interested in the regeneration process itself, data blocks 67-70 are particularly relevant.
Jerking/Hesitation: Also, please also consider the engine mounts or the ash level in the DPF. At this mileage, the DPF should have already been replaced or cleaned.
If the "jerking" only occurs during regeneration, you can also log value 1 in measurement block 10. If there are "drops" in the values, the cause could be a clogged DPF, as this can sometimes trigger the turbocharger to pump in certain operating conditions.
Typically, this occurs at low engine speeds and low ambient air pressure, with a low air mass flow but a high boost pressure requirement.
See also:
Translated on 15-09-2026, 12:49.
stolley
22-01-2014, 21:52 Subject: Stuttering During Regeneration: Which MWB Logs? |
See also:
Hello Rainer,
Thank you for your feedback!
I would like to rule out engine mounts for now, as the jerking only occurs during regeneration.
And the DPF hasn't been replaced yet, I'm curious to see what the diagnostic readings say. However, I imagine that in my case, it's not yet at the point where it needs to be replaced, because I drive 55,000 km per year.
It could actually be something real... I think.
I will report!
Translated on 15-09-2026, 12:52.
stolley
18-03-2014, 8:55 Subject: Stuttering During Regeneration: Which MWB Logs? |
I have created the log and posted it under the link mentioned above.
Can you tell me something about the condition of the DPF, Rainer?
Volker
Translated on 15-09-2026, 12:54.
18-03-2014, 11:02 Subject: Stuttering During Regeneration: Which MWB Logs? |
Quote: | | up to 90 mbar differential pressure |
Regarding the condition of the DPF, the following can be said:
- Either the 1.4 TDI received the same DPF (Diesel Particulate Filter) as the 1.9/2.0 TDI engines, which results in lower exhaust emissions and less ash buildup due to reduced oil/fuel consumption, thus explaining the low differential pressure.
- Or, the DPF (Diesel Particulate Filter) is not in perfect condition, meaning the ceramic component has cracks.
Whether it's the former or the latter, for the engine's perspective, there is no need for action regarding the DPF. If the rear is black, the latter is likely to be the case.
Consequently, if the rear of the unit is not black and all openings on the DPF are properly screwed/sealed, including the lines to the differential pressure sensor, then everything is fine with the DPF.
Only in the event that the ash mass exceeds the limit, should this value be moderately reset (halved), so that the engine control unit does not solely rely on the programmed ash mass to initiate regeneration cycles, which could then lead to a visit to the workshop.
Translated on 15-09-2026, 12:55.
stolley
19-03-2014, 8:05 Subject: Stuttering During Regeneration: Which MWB Logs? |
Hello Rainer,
Thank you for your assessment!
The rear is completely free of soot, which is a relief!
Best regards, Volker.
Translated on 15-09-2026, 12:57.
