Mobile Navigation Problems: Troubleshooting Guide
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +591 / -0   Thank you, like it!
Post13-05-2014, 23:00    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
Hello!
I could use some advice.
I bought a mobile navigation device, specifically a Becker Ready 50 ICE, at the end of 2012.
For hiking trips, personal car rides, my company car, and for my side job as a truck driver.
That's why I chose this one specifically, because it has some truck-specific features, and it promised free map updates. There were no other options available in the store, which is why I went with this.
It meets my needs and is in the price range of under €200. So far, everything works well, and I use it a lot.
The problem is the map updates; I'm not sure if those updates are actually causing it.
I have my doubts because some new roads are not included.
and in the cities, it still displays 60 km/h on the old roads from the 60s, even though the speed limit has been 50 km/h for some time.
So, after purchasing the device, you had to use it first, and then register within one month to receive the updates.
Install the Becker content manager on a PC and register. It was a bit confusing, but I registered and can still log in. I did this within the deadline.
Today, I tried updating again.
The device is then also "updated," which is strange because, with my slow internet connection, it only takes a few minutes. Then, the message "Your system has been updated" appears.
Somewhere in between, months ago.
The content management system was updated, and users had to log in again.
In short, I'm completely lost.
It's probably technology geared towards a younger generation...
Perhaps someone who is familiar with this kind of thing can offer me some advice.
Translated on 10-10-2026, 8:04.
Karma: +1102 / -0   Thank you, like it!
Post14-05-2014, 2:54    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
It's not new that map data sold as "current" is actually outdated. Years after the AD Nuthetal was completed, my navigation system (Navigon) directs me to drive across a field from both directions (as of 10/2013). The same effect occurs with the newly built AD Barnim (formerly AD Schwanebeck), although it's not quite finished yet.
Although I've learned that it's not the navigation system but me who controls the vehicle, this is annoying, but not a catastrophe.
I remember the navigation functions of Nokia and iPhone mobile phones as being well-maintained. However, both require a data connection to function.
I don't know how the update process works on your device.
Translated on 10-10-2026, 8:07.
Post14-05-2014, 6:03    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
Hutfahrer wrote:
...remember the navigation functions of the Nokia...mobile phones. However, both require a data connection to function.
Nope...at least that's not true for the Nokia Lumia model (WP). I'm currently using a 1520 (okay, it's a bit big) and I'm very satisfied. Maps are downloaded to the device and are (so far) up-to-date; I haven't been anywhere in the middle of nowhere. There's no light without shadow; it knows about traffic jams and obstacles (an online connection is required; without it, everything is always free icon_smile.gif). Rerouting isn't really a strong point of Nokia Here+.
The thing about updates is complicated. A new map version from the manufacturer doesn't necessarily mean it's up-to-date in terms of the actual roads that exist. The manufacturer could, for example, buy map data from 2012 cheaply and offer it as the "latest" version of their navigation system.
I know it's all useless advice. I just think that things like changing speed limits always lag behind. Personally, I prefer to rely on what's posted on the road. What's really annoying are the non-existent and brand-new bypasses.
Translated on 10-10-2026, 8:09.
Styrian
Post14-05-2014, 13:44    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
...Be careful with "free map updates." Always read carefully between the lines. With some manufacturers, this free map update is only valid once. Just enough to bring the hopelessly outdated maps up to a somewhat current state. I personally had a negative experience with Becker in the past, when I still had a fixed navigation system. It's possible that this has changed in the meantime. To be on the safe side, read the terms and conditions carefully again. The short update duration suggests that only the navigation software is being updated.
Garmin takes a different approach. They explicitly mention (for some offerings - I'm not sure if it's for all) "NüMaps Lifetime Updates." It's clear that they actually provide updates even years after the initial release, as long as the device is still functioning. Of course, this doesn't necessarily mean that the maps are always completely up-to-date. Even with the two map providers, TeleAtlas and Navteq, some new roads haven't yet been incorporated.
Greetings from Styria.
Edit: I just checked this device, and it advertises "lifetime updates." So, it should actually work... what do the map info details say?
Edit2a: Irrelevant.
Translated on 10-10-2026, 8:12.
Post15-05-2014, 21:25    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
Hello!
Thank you for the responses.
From the beginning, the whole thing with the free updates seemed a bit suspicious to me.
So, I've looked up the documents again.
"So, in the fine print, it states that there are 3 free software updates per year for the pre-installed map software, until the device breaks down, or the supplier of the map data stops providing them, goes bankrupt, or something like that."
In the fine print, it states that the device must be registered online within 30 days of its first use.
I did that.
This content manager has been updated, so now, to receive the updates, you have to add the entire package to your shopping cart, register for a free account, etc.
It wasn't like that when I bought it.
So, looks like it's a case for customer support, which I'm already dreading... this is definitely going to be a disaster.
Perhaps what's meant is that 30% would rather pay for the update than deal with people via email... there's no phone support available.
Well, and what I noticed today, while I was out and about all day, was something else that was extremely negative:
The traffic reports and the TMC (Traffic Message Channel) are just as much of a disaster.
It might not be the navigation system's fault, but this just isn't working at all.
Initially, a section of the road was closed, and there was no information about it on the radio. I'm considering taking a detour.
Then the blockage will be lifted. I will then drive along the section of road that has been reopened.
There's a tanker truck on the roof, in the ditch beside the road.
A tow truck and a crane were just arriving at the accident site.
and the police were right behind me.
Three hours later, it was played on the radio for the first time.
This has happened to me before, and I think I'm going to start ignoring it altogether.
Translated on 10-10-2026, 8:16.
Post16-05-2014, 8:40    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
My experiences with 2 aftermarket navigation systems from well-known manufacturers:
- The map data varies greatly depending on the region, and can be very outdated (a bypass road near Herzogenaurach, in the direction of Emskirchen, has existed for 20 years, but the navigation system directs you onto a field).
- Free map updates are useless. Even after the update, a detour that was approximately 5 years old (near Altstätten, Switzerland) was still not included in the map.
- TMC: I ignore it, just like the most stupid questions like "... consider?". Whether you click yes or no, it only changes the displayed arrival time; the route itself only changes in exceptional cases, even though you would probably know better. The TMC messages are either too late (the traffic jam is already gone) or there is a traffic jam, but there is no TMC message about it. I bought the second navigation device specifically because of TMC, but I wouldn't consider it a criterion anymore. On the packaging of the first navigation device, it said "suitable for TMC". Unfortunately, the suitability only consisted of not having to purchase a relatively very expensive TMC antenna... icon_rolleyes.gif
If you are not familiar with the area, want to reach a destination in a reasonable amount of time, or are looking for an address, then an aftermarket navigation system is a very useful thing. icon_wink.gif
I also thought that with such a device, the annoying task of carrying maps would become unnecessary. In my opinion, when you venture away from the main roads, nothing beats a large, foldable map, as you simply don't get a good overview of the area on the small display of the navigation system.
Translated on 10-10-2026, 8:20.
Post16-05-2014, 10:07    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
Yes.
TMC is really useless.
And that's solely because of its absolutely amazing lack of relevance.
TomTom's GSM-based service (something like "live" or similar) is significantly better, but it comes at a cost. I had it active with my Go 940 for the first year, but then let it expire.
Translated on 10-10-2026, 8:22.
haithamina
Post16-05-2014, 13:31    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
I have been using Garmin products in my car and for my bicycle for many years.
The now-standard lifetime updates for Garmin automotive products work flawlessly and are typically released on a quarterly basis. The content is very up-to-date, and you can also download the illegal speed camera warnings as a so-called "test subscription" from Garmin. This usually ensures that the speed limit warnings are also accurate.
For a bicycle, you only need to purchase the hardware. There are many good websites online that offer routing-enabled (worldwide!) maps for free download.
Online search keyword http://garmin.openstreetmap.nl/. In EU countries, the data often have an insane level of detail (e.g., supermarkets for refilling the glycogen stores of starving cyclists), as they are optimized in an open innovation process by users (geocaching).
"Absolutely brilliant, I highly recommend it, and I'm using a Garmin StreetPilot c550, which is quite old, but I still receive current maps and software updates from Garmin for it."
haithamina
Translated on 10-10-2026, 8:24.
Post16-05-2014, 21:55    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
Hi!
Well, I'd like to thank you all for the many answers.
My expectations were probably a bit too high, considering what one can expect for €179.
Translated on 10-10-2026, 8:26.
haithamina
Post17-05-2014, 11:59    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
Or maybe you missed my post. For the 179, you get hardware plus regularly updated maps and speed camera warnings.
haithamin
Styrian
Post19-05-2014, 10:11    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
"@haithamina...but not for trucks...Navigation solutions designed for trucks cost a bit more, as they are used professionally and cater to a different clientele. The underlying map data is likely the same, but the software has been modified to prevent your 40-ton truck from driving through residential areas."
@SteffenViewing profile: Steffen G: Have you checked what the expiration dates are on your cards yet? And things with the support won't be that bad, I'm sure... Keep your chin up. But you can forget about the TMC feature. It's always been like that and will always be like that when the data is delivered via certain transmitters.
Translated on 10-10-2026, 8:27.
haithamina
Post19-05-2014, 20:40    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
Thank you for the clarification, Styrian!
I'm not really familiar with navigation systems and software specifically designed for trucks.
CU, haithamina
Translated on 10-10-2026, 8:28.
Post19-05-2014, 22:24    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
Hi!
Okay, I've gone through the navigation system again.
also Kartensoftware müsste von 2011, 4. To be a quarter.
I bought it in December 2012.
Actually, it's surprisingly relevant even today.
I'll get in touch with support then.
The next problem is my internet connection; I can't download even 4 GB of data here. It takes hours, and something always interrupts the process.
Otherwise, regarding the truck function:
No, there's not much more to it; I can only set the vehicle type to "truck."
Then it calculates the travel time using a speed of 60 or 80 km/h.
and I can avoid toll roads, so it will route me along country roads.
That actually works quite well.
Bridge heights, etc., are not included; I'll have to figure those things out myself.
Translated on 10-10-2026, 8:29.
Styrian
Post20-05-2014, 17:19    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
...Q4/2011 ??? So, "up2date" is something else. Therefore, I believe that a map update has never been performed (obviously). What kind of internet connection do you have? 4Gb should normally not be a problem. If necessary, you can even let it run overnight.
Best regards, Styrian.
Translated on 10-10-2026, 8:31.
Post21-05-2014, 18:38    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
Hi!
Das ist ein DSL-Anschluss der dt. Telekom.
ich kann sogar froh sein, dass ich das überhaupt habe. Zw. Flat rate.
There are no alternatives here, at least not for a wired connection. I have 3 PCs, 3 phones, and a fax machine connected to it.
I just did a quick test:
Download: 1979 kbps
Upload speed: 194 kbit/s.
Larger downloads are not working.
A while ago, I tried to download a Linux operating system, which was about 4 GB in size.
It will eventually stop working after about 3 hours.
I've tried it several more times with my neighbor, who is supposed to be knowledgeable about PC technology, but it's just not working.
Reluctantly, I ended up ordering it from the Linux distribution on DVD. But, I have to say, it wasn't a bad solution.
Translated on 10-10-2026, 8:32.
Post21-05-2014, 19:56    Subject: Mobile Navigation Problems: Troubleshooting Guide Quote
I have a DSL 2000 connection with a current speed of 2300 kbit/s, and it works without problems. Some downloads are just slower than a blink of an eye, so it's similar to what you're experiencing.
If you want to download 4 GB (approximately) at once, it will naturally take some time.
Can you not download the map data individually, like with Nokia, for example, just Germany?
Sure, here's the translation:
"Best regards," or "Sincerely,".
Translated on 10-10-2026, 8:34.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi B5, 1999 - Retrofitting from small navigation system... Transmission, Chassis, Body & Interior
No new posts Car Navigation System with Audi Integration On-Board Diagnostics (OBD)
No new posts Large Navigation Multifunction Display Electrical Systems, Vehicle Electronics, Multimedia
No new posts Radio/Navigation Electrical Systems, Vehicle Electronics, Multimedia
