17-08-2014, 8:49 Subject: Polo WRC Problems: Common Issues & Solutions |
Hello.
Yesterday, I had my first WRC experience at the VCDS-Lappi.
What particularly struck me was:
1. There is no label file available for the MSG.
2. With the ESP, it is not possible to read out any diagnostic trouble codes (DTCs) or individual measurement values.
Are these specific data points missing from the VCDS database?
Alternatively, could I use a different label file from a MED 9.1 engine for the MSG?
Here's the STG scan and an MWB scan of the MSG.
Translated on 14-09-2026, 20:15.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
18-08-2014, 16:13 Subject: Polo WRC Problems: Common Issues & Solutions |
Hello Ulf,
I inserted it into the pipeline!
Translated on 14-09-2026, 20:17.
Profile PM WWW Garage |
18-08-2014, 17:42 Subject: Polo WRC Problems: Common Issues & Solutions |
Hi Ulf,
Please create .pla and .plb files (both) for the engine control units that do not have a corresponding label file.
18-08-2014, 20:22 Subject: Polo WRC Problems: Common Issues & Solutions |
Quote: | VCDS Version: RKS 12.12.2.0
Data as of: 20130111 |
Ulf, what have you cobbled together there? If I'm going to help you, I need to be able to rely on the fact that there isn't some random mishmash on your computer, but rather the installation package that I specified.
Translated on 14-09-2026, 20:18.
19-08-2014, 7:41 Subject: Polo WRC Problems: Common Issues & Solutions |
dieselschrauber wrote: | Ulf, what have you cobbled together there? If I'm going to help you, I need to be able to rely on the fact that there isn't some random, untested thing on your computer, but rather the installation package I specified.  | I am not aware of any wrongdoing.
There might be a few old, custom-made LBL files in the user label folder (could this trigger the WunderTüte data?), but the rest of the installation is RKS 12.12.2.0.
It's possible that I moved the 12.12.2.0 installation to a different partition.
Should I reinstall them completely?
PLA and PLB filaments are coming soon.
Translated on 14-09-2026, 20:19.
Profile PM Garage |
19-08-2014, 10:37 Subject: Polo WRC Problems: Common Issues & Solutions |
Yes, please ensure a clean installation.
Translated on 14-09-2026, 20:20.
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
19-08-2014, 14:34 Subject: Polo WRC Problems: Common Issues & Solutions |
Regarding errors:
Ulf, have you checked where the surge is coming from?
Profile PM Garage |
19-08-2014, 17:29 Subject: Polo WRC Problems: Common Issues & Solutions |
Roger wrote: | Speaking of mistakes:
Ulf, have you checked where the voltage surge is coming from? | I suspect it's from cable work with the battery disconnected, during which I had plugged a backup battery into the 12V socket.
The errors in today's scan are likely due to the fact that I had removed the RNS unit -> just ignore them.
Here it is, with a fresh, new installation.
 the new vehicle scan.
 PLA and PLB forms for the MSG in ZIP format.
 and something about the ESP-StG. It didn't release any PLA or PLB data, but only the admap.
But now, with the ESP-StG, I at least have the option "Advanced Measurements" (?), so that I can, for example, log the individual wheel speeds.
| Description: |
 Download |
| File name: |
Log-WVWZZZ6RZEYxxxxxx.txt |
| File size: |
12.63 KB |
| Downloaded: |
1714 times |
| Description: |
 Download |
| File name: |
01-6R0-907-115.zip |
| File size: |
4.83 KB |
| Downloaded: |
372 times |
| Description: |
 Download |
| File name: |
adpmap-03-6R0-907-379-BG.CSV |
| File size: |
1.18 KB |
| Downloaded: |
1363 times |
Translated on 14-09-2026, 20:21.
Profile PM Garage |
19-08-2014, 18:01 Subject: Polo WRC Problems: Common Issues & Solutions |
Thank you!
Translated on 14-09-2026, 20:22.
19-08-2014, 20:36 Subject: Polo WRC Problems: Common Issues & Solutions |
I just found the file "06F-907-115-AXX.lbl" in the label path: it seems to fit well with the PLB file from my MSG.
I'll try those out.
Translated on 14-09-2026, 20:23.
Profile PM Garage |
22-08-2014, 21:31 Subject: Polo WRC Problems: Common Issues & Solutions |
@Rainer:
It wasn't until now that I realized that VCDS can't connect to the radio part of the RNS315, but it can connect to the navigation part.
Therefore, the radio address 56 is probably also missing in the Scanlog.
Interestingly, in the "Installed" section of the VCDS software, it initially displays "56 Radio."
If I try to access the StG 56, I get the error message "StG is not responding" after a few attempts. Subsequently, the "56 Radio" button disappears from the "Installed" tab in VCDS.
That would be something to fix in the next VCDS release.
The aforementioned label file seems to be compatible with the CDLJ engine.
Translated on 14-09-2026, 20:24.
Profile PM Garage |
09-09-2014, 12:37 Subject: Polo WRC Problems: Common Issues & Solutions |
Please check VCDS-RKS 12.12.3 (which includes new labels).
Translated on 14-09-2026, 20:25.
09-09-2014, 13:32 Subject: Polo WRC Problems: Common Issues & Solutions |
Okay, I'll keep that in mind... but for now, the RNS315 has been removed and a 1-DIN radio is installed.
If I ever have a lot of time, I'll try putting the RNS315 back in the car for a test run.
Profile PM Garage |
matthiasTDI96 Profi-Schrauber
09-09-2014, 14:40 Subject: Polo WRC Problems: Common Issues & Solutions |
...what is that in kilograms?
Translated on 14-09-2026, 20:26.
09-09-2014, 15:16 Subject: Polo WRC Problems: Common Issues & Solutions |
Approximately 0.5kg  .
But that's not the main reason... what's more important is that I can/could fit another LDA (likely a small electronic device) into the compartment under the flat-screen radio.
Profile PM Garage |
Benni Blaumann
Joined: 11/19/2005 Posts: 302 Karma: +15 / -0 Location: Braunschweig
12-09-2014, 20:53 Subject: Polo WRC Problems: Common Issues & Solutions |
ulf wrote: | OK, I'll keep that in mind... but for now, the RNS315 has been removed and a 1-DIN radio is installed.
If I ever have a lot of time, I'll try putting the RNS315 back into the car, just for testing purposes. |
It's a shame about the beautiful car. I'm not really surprised that the old Polo is just sitting there unsold.
Surely, a lane departure warning system could be integrated digitally, either through the vehicle's infotainment system (FIS) or the navigation system. Alternatively, it could be connected analogously to the A-pillar.
Translated on 14-09-2026, 20:27.
