Passat 3c key programming
dodo65
Post06-11-2014, 21:10    Subject: Passat 3c key programming Quote
Now, here is the continuation of key learning for electronic keys for the Passat 3c, based on Michael II's report dated 8/20/2003.
It remains the case that all keys must first be deleted before being re-programmed in a single operation.
One of the key elements is to activate the ignition, so that contact can be established with Control Unit 46 (Comfort System) via VCDS. Then remove the ignition key, and the contact remains even without the ignition.
Then: Select "Customize".
Channel 00 to select for key deletion.
The "Delete Function" option only appears when you have created channels with
The channel is switched up and then comes back down.
Delete query and confirm delete query and save.
Both keys are now non-functional.
New Attachment:
Channel 01. Additionally, VCDS also provides an explanation/instruction, but it is not immediately understandable because it includes two things (the possibility of learning a key = 1 and the ability to also enter the number of keys to be learned here)
If the "1" is visible, keys can be duplicated. Then, enter the number of keys in this field, for example, "2". Test 1 and save.
Test 2 and save.
Then just take the keys and activate the door opening button. The vehicle beeps to indicate payment. And with the next key, do the same. The car is flashing, and that's that.
If this does not function correctly, an entry will be made in the error memory with the approximate meaning "Incorrect key coding".
Post06-11-2014, 21:35    Subject: Passat 3c key programming Quote
Do you mean the FFB (remote control)?
No new posts Passat V157: How to Replace and Calibrate CBDC Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C Remote Key Fob Programming - Old Key On-Board Diagnostics (OBD)
No new posts Used Passat 3C Key Programming (2010) Transmission, Chassis, Body & Interior
No new posts Golf 5 Key Programming: How-To Guide On-Board Diagnostics (OBD)
No new posts VW Polo 6N: Key Programming Guide On-Board Diagnostics (OBD)
