milledriver
Joined: 12/04/2013 Posts: 22 Karma: +0 / -0 Location: Aargau
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
18-10-2014, 20:28 Subject: VCDS - Communication Interrupted. WIN 8.1 (Solved) |
Quote: | VCDS is up to date and has already been reinstalled.
Have you tried connecting to the vehicle with a different computer or laptop to rule out the vehicle itself as the source of the problem?
I would first uninstall it again, then download the version from the store and install it again. The same applies to the Rosstech USB driver package; if it needs to be installed separately under Windows 8?
milledriver
18-10-2014, 20:38 Subject: VCDS - Communication Interrupted. WIN 8.1 (Solved) |
Thank you for the quick response!
"It worked perfectly with the XP calculator, but the version I downloaded from the store didn't work. Are there any other settings I need to adjust in Windows 8?" Does anyone have any experience with this?
Hi Dani,
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
18-10-2014, 21:43 Subject: VCDS - Communication Interrupted. WIN 8.1 (Solved) |
Please check which background services are currently running (your computer isn't exactly a high-performance machine).
If programs that temporarily halt the computer's operation, such as antivirus scanners, are running, the communication may be interrupted.
Profile PM WWW Garage |
milledriver
19-10-2014, 11:43 Subject: VCDS - Communication Interrupted. WIN 8.1 (Solved) |
Hello Rainer,
I managed to get VCDS working smoothly again.
First, I turned off all the visual effects to make the laptop run faster. After that, I right-clicked and ran the compatibility troubleshooter.
I've been able to test it on 4 vehicles without any problems.
Here's the guide in case this problem occurs for someone else:
Here's how to adjust all visual effects to optimize performance.
To access performance information and tools, first click the "Start" button, and then click "Control Panel." In the search bar, type "performance information and tools" and then click on "performance information and tools" in the results list.
Click on "Customize visual effects." Administrator privileges required. If you are prompted to enter an administrator password or confirmation, please enter the password or confirmation.
Click the "Visual Effects" tab, then click "Adjust for best performance," and then click "OK." (A less drastic solution is the "Let Windows choose what's best for my computer" option, which allows Windows to select the effects to disable.)
Thank you very much.
Hi Dani,
19-10-2014, 14:13 Subject: VCDS - Communication Interrupted. WIN 8.1 (Solved) |
Thank you for the feedback  .
It would be interesting to know which of the two changes ultimately led to the desired outcome.
It's unfortunately well-known that Windows 8.1 sometimes tends to be problematic.
