Hello
I recently wrote a "how-to" guide on how to adjust the synchronization angle retroactively in another forum:
It is advantageous to measure when the engine is at its full operating temperature and idling in neutral.
It's best to make notes of the values.
First, turn off the engine, then remove the upper part of the timing belt cover.
You don't need to loosen the strap to adjust the twist angle; instead, you leave the strap and the tensioning roller as they are.
Often, it is helpful to use a marker to make a marking around the 3 screw heads, in order to better assess the adjustment.
Loosen the 3 screws on the camshaft pulley, while holding the central screw in place.
Then, turn the large screw/NW in the middle, in the direction indicated by VCDS (VCDS always shows you where you need to go, not where you are).
When the crank angle is advanced (the crankshaft leads), rotate counterclockwise.
For positive values (the crankshaft is lagging), in the clockwise direction.
You only need to turn it very slightly, because 1° is not much, about 0.5mm of movement on the screws.
Above 4° it becomes critical to closely monitor the gap between the valves and the piston.
The 3 M8 SW13 screws are then tightened again to 25Nm.
Then restart the motor and check MWB 4 again with VDCS.
Repeat the procedure as many times as necessary until it works.
Don't despair,
you'll gradually get a sense of how much you need to adjust.
0.5° is fine, or even zero, depending on your ambition or preference
Hope this helps some writers.
Greetings, Mpire
