Error: Incorrect Request Order - Fix Now!
R082rt7971
2006 Audi A4
Post24-03-2015, 10:48    Subject: Error: Incorrect Request Order - Fix Now! Quote
Hi there!
Perhaps you can help me.
I tried to reset the oil service interval (WIV) and fuel filter service interval (FIV) on an Audi A6 B8 3.0 TDI using VCDS. To do this, it is necessary to access the adaptation settings via the control panel module.
When setting the FIV (presumably a configuration parameter) to "0" and then attempting to execute something, the error message "Error 24: Incorrect request sequence" appears. Subsequently, it refers me to the operating number, importer's number, and device number.
Translated on 12-08-2026, 13:05.
Post24-03-2015, 12:29    Subject: Error: Incorrect Request Order - Fix Now! Quote
Maybe you can help me.
No, not without the automatic scan feature... Which version of VCDS is being used?
Translated on 12-08-2026, 13:06.
Post24-03-2015, 12:30    Subject: Error: Incorrect Request Order - Fix Now! Quote
Audi A6 B8
What is that?
Do you mean the current A6 C7 or A4 B8?
R082rt7971
2006 Audi A4
Post24-03-2015, 13:02    Subject: Error: Incorrect Request Order - Fix Now! Quote
Ah, sorry.
I meant the C7.
Could it really be due to the version?
I haven't downloaded the latest update yet. I was in the system for the first time since the end of last year yesterday. I've also been thinking that it might be related to that.
Translated on 12-08-2026, 13:07.
Karma: +437 / -0   Thank you, like it!
Post24-03-2015, 14:47    Subject: Error 24: Incorrect Request Order Quote
R082rt7971 wrote:
(...)to reset the WIV/FIV (...). To do this, it is necessary to access the adjustment settings via the control panel interface.
When setting the FIV to "0" (...)
Did you try it manually in module 17, or through the guided VCDS application on the start screen?
Greetings.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 12-08-2026, 13:08.
R082rt7971
2006 Audi A4
Post24-03-2015, 15:37    Subject: Error: Incorrect Request Order - Fix Now! Quote
He referred me to section 17 from the start screen and then told me to reset it under "Settings."
The reset function using the button on the startup screen doesn't seem to be working.
Translated on 12-08-2026, 13:09.
No new posts Spark plug firing order Technical Data
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error message: "Control unit incorrectly coded" Diesel Engine Technology
No new posts Rear brake caliper, sequence Transmission, Chassis, Body & Interior
No new posts Change MFA Display Order Levels On-Board Diagnostics (OBD)
No new posts Einspritzbeginn falsch??? Diesel Engine Technology
