VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
georgmech
Post21-01-2016, 16:28    Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission Quote
The right driveshaft is spinning inside the transmission, but there are no more splines on the transmission shaft. Are there any replacement parts available for this?
Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Translated on 10-09-2026, 18:16.
Back to top Profile PM Email
Post21-01-2016, 18:35    Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission Quote
Unfortunately, a new differential will be needed. GKB?
Translated on 10-09-2026, 18:17.
Post21-01-2016, 18:47    Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission Quote
I would also like to know the mileage and the primary purpose for which the vehicle was used. icon_idea.gif
georgmech
Post25-01-2016, 15:37    Subject: Short Distance Applications Quote
The vehicle was an ambulance and, of course, was driven at full speed. It has a mileage of 280,000 km. After cleaning it, I'm now not so sure that the driveshaft spun out, although the ridges in the transmission look quite damaged. According to the previous owner, the car stopped without any unusual noises and couldn't be driven away. However, there was only 1 liter of transmission oil in it, although it's not known if the rest was drained. Currently, I've only removed the clutch discs, and they look like new. They don't smell, and the steel friction discs are neither blue nor warped.
Translated on 10-09-2026, 18:18.
Post25-01-2016, 15:44    Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission Quote
Thanks, it sounds like the DSG didn't perform too badly after all...
Translated on 10-09-2026, 18:19.
georgmech
Post26-01-2016, 10:18    Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission Quote
"Does anyone know where I can find a refurbished or used one? But what bothers me personally is that the car simply wouldn't drive anymore without making any strange noises, meaning you can rule out gear damage or something similar. Are there any common issues I can look out for? Like a faulty control unit or something?"
Post26-01-2016, 12:13    Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission Quote
georgmech wrote:
But there was only 1 liter of transmission oil inside...
Translated on 10-09-2026, 18:20.
Mc_Givertechnik
2010 Volkswagen T5
Post18-04-2016, 8:10    Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission Quote
Hello!
Considering that the right driveshaft has always been a weak point and still is, it's truly remarkable how long it lasted.
Whether it's a manual or automatic transmission, the trapezoidal teeth in the area where the driveshaft connects to the transmission tend to wear out. It's recommended to check this area for play whenever possible, whether during a service or simply when working under the car. This can often help prevent larger damage, as in this case.
"Is there any information from the previous owner or records of the repairs that have been carried out? Is this the original transmission? Is this the original right-hand half-shaft? Based on the mileage and the usage profile, I would be very surprised if all of these parts are still from the factory."
Greetings,
Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 10-09-2026, 18:21.
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts [?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub Diesel Engine Technology
No new posts Upgrade 5-speed to 6-speed gearbox VW G3 AHU Diesel Engine Technology
No new posts TDI Motor dreht durch Diesel Engine Technology
No new posts 1Z dreht durch, nimmt kein Gas an On-Board Diagnostics (OBD)
