VW T5, 2.0 BiTDI, excessive oil consumption (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Karma: +784 / -0   Thank you, like it!
Post06-04-2017, 14:09    Subject: VW T5, 2.0 BiTDI, excessive oil consumption Quote
Engine affected: 2.0 BiTDI CFCA 179 hp, possibly also other models.
Problem description: Excessive oil consumption, DPF constantly clogging.
Besides the usual suspects for high oil consumption, such as a faulty turbocharger, a compression test should be performed in this case. It is also advisable to inspect the cylinder bores, for example using an endoscope.
Background: Scratches can form on the cylinder walls due to particles dislodged from within the engine or foreign objects that are drawn in, ultimately leading to engine damage. Check the AGR valve and AGR cooler for damage or foreign objects.
Ratings - VW T5, 2.0 BiTDI, excessive oil consumption
No new posts Document: High oil consumption, AFB and AKN engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9, MKB AGP, Increased oil consumption Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 B5 und Besch... Bremsleistung bei extremer Nässe Transmission, Chassis, Body & Interior
No new posts T5 BiTDI Engine Problems Diesel Engine Technology
This topic is locked, you cannot edit or reply. 3.0 BiTDI Injektorwerte? Diesel Engine Technology
No new posts Ölverbrauch !!! Diesel Engine Technology
