2.0 TDI CR CFHD: Replace Pressure Sensor
Go to page: 1, 2  Next
invade
Post13-09-2015, 21:57    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
I need to replace the pressure sensor on my 2.0 TDI CR engine with the engine code CFHD, which is installed in my Ibiza 6J, because of the following error:
9127 - Wastegate actuator for turbocharger.
P00AF 00 [167] - Stuck.
The error memory shows a fault, the glow plug warning light is flashing on the dashboard, and there is almost no power.
So far, so good. The part number for the replacement part is 03L 198 716 B.
"The installation and removal are mechanically straightforward, but my question is whether the new pressure sensor needs to be calibrated using VCDS, or how should the linkage be adjusted? Is it simply a matter of transferring the old measurements to the new one?"
Regards, invade.
Translated on 31-08-2026, 15:51.
Karma: +590 / -0   Thank you, like it!
Post13-09-2015, 22:50    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
Hello!
I cannot answer that specific question because I haven't done it myself yet.
"Note:"
Is the can really defective?
Most of the time, the problem with a turbocharger is a mechanical issue.
Translated on 31-08-2026, 15:53.
Post13-09-2015, 23:21    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
Hi.
Let's take a look at how it works on the old loader. Usually, when the container is fully extended, the adjustment lever is right at the stop.
Most of the time, as Steffen already pointed out, the problem is not the vacuum sensor.
I need to replace the pressure sensor on my 2.0 TDI CR engine with the engine code: CFHD, which is installed in my Ibiza 6J, because of the following error:
9127 - Adjustment unit for turbocharger.
The error code is stored, the glow plug indicator is flashing on the dashboard, and there is almost no power.
The conclusion you wrote is nonsense. You don't have to do anything, but first, you should figure out what the exact problem is and which part is stuck.
Translated on 31-08-2026, 15:54.
invade
Post14-09-2015, 15:51    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
The adjustment mechanism works perfectly and is very easy to operate.
Both when the engine is running and when it's idling!
Using VCDS actuator diagnostics, it extends a short distance, but then it seems to lack power. However, if I gently assist it with a screwdriver, it works perfectly. If the turbo adjustment was stuck, I think it would require more force to operate.
What else do you think it could be?
The vacuum hoses are all in good condition!
Translated on 31-08-2026, 15:56.
Post14-09-2015, 15:58    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
It's also possible that the vacuum sensor isn't receiving the correct vacuum pressure. Therefore: disconnect the hose and, for example, use a large syringe to create suction and test it.
And: Measure vacuum pressure!
Translated on 31-08-2026, 15:57.
invade
Post14-09-2015, 16:24    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
Just disconnected the hose directly from the pressure sensor and created a vacuum using a vacuum pump...
Nothing is happening!
"When the engine is off and/or the hose is connected, if I move the rod up and down with a screwdriver, I hear a whistling sound coming from the container, as if something is leaking."
Translated on 31-08-2026, 15:58.
invade
Post14-09-2015, 16:56    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
Just to be on the safe side, a large syringe is still connected.
Suction: No action.
Pressing (blowing): Nothing happens, but you can hear a hissing sound, likely coming from somewhere in the area of the pressure chamber/rod.
Post14-09-2015, 17:06    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
Suction: No action.
Pressing (blowing): Nothing happens either, but you can hear a hissing sound, as if the air is escaping somewhere in the area of the pressure chamber/rod.
Okay, then it's likely that it's actually defective. But that's quite rare.
Translated on 31-08-2026, 15:59.
invade
Post14-09-2015, 17:24    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
Just ordered the part, the repair kit costs 146 euros.
The parts specialist said that he had ordered the repair kit several times before.
I'm excited; it arrives tomorrow, and then, after work, I'll tackle the challenge.
I'll adjust the rod in the same way as the old one, using the same spacing, and then I'll test it. Is my approach okay?
Translated on 31-08-2026, 16:00.
Post14-09-2015, 18:23    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
Yes, a before-and-after log of the boost pressure control (target/actual) would be helpful.
"Response test: Measure the instantaneous boost pressure value when transitioning from zero throttle to full throttle at 3000 rpm in at least 3rd gear. This will reveal whether the tuning is too conservative or too aggressive."
Translated on 31-08-2026, 16:01.
chli1976
Karma: +185 / -0   Thank you, like it!
Post15-09-2015, 10:54    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
Normally, you adjust this using a vacuum pump and VCDS.
The voltage must be 760mV when there is a vacuum pressure of 600 mbar, but I'm not entirely sure about these values.
VCDS
Translated on 31-08-2026, 16:02.
invade
Post15-09-2015, 17:24    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
The new can is installed, and it's working again!
So, it was definitely the vacuum sensor that was defective.
Now I just need to do one more logging run to see if the settings are correct.
Previously, Log couldn't walk normally because he was limping badly.
Post15-09-2015, 18:08    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
Thank you for your feedback!
Translated on 31-08-2026, 16:03.
invade
Herbert likes this.
Post15-09-2015, 18:18    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
Here's the log in 4th gear, without full throttle.
It drives really well, and the values seem okay to me...
LOG-01-491-501-541-551-1101_Gang4.CSV
 Log Ladedruckregelung
 File name:  LOG-01-491-501-541-551-1101_Gang4.CSV
 File size:  5.61 KB
 Downloaded:  496 times
Post15-09-2015, 19:02    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
Is that icon_smile.gif?
invade
Post15-09-2015, 19:41    Subject: 2.0 TDI CR CFHD: Replace Pressure Sensor Quote
dieselschrauber wrote:
So, the values are okay?
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Engine Noise: Troubleshooting & Repair Diesel Engine Technology
No new posts Disable ESP: 2.0 TDI 143HP Seat Ibiza (2015) Electrical Systems, Vehicle Electronics, Multimedia
No new posts TDI Pressure Canister 2.5L Diesel Engine Technology
No new posts Pressure Vessel 1Z - Larger Size Diesel Engine Technology
