Touran AC Not Working? Troubleshooting Guide
Go to page: 1, 2  Next
StreifLicht
Post15-07-2015, 21:09    Subject: Touran AC Not Working? Troubleshooting Guide Quote
The sun is shining - but the air conditioner isn't doing its job icon_wink.gif.
Visual inspection reveals no clues. The compressor is running.
All connections are fine - Now let's check for errors...
BUT: VCDS reports no errors.
How can I narrow down the source of the error?
Why, for example, is the actual compressor current value not being displayed?
I once ran a scan and have attached the resulting file.
Do you perhaps have a suggestion for me here?
Best regards, SL.
 File size:  26.54 KB
 Viewed:  7944 times
 File size:  33.78 KB
 Viewed:  6690 times
 File size:  25.15 KB
 Viewed:  6694 times
 File size:  17.73 KB
 Viewed:  6444 times
AutoScan 2015-07-15.txt
 File name:  AutoScan 2015-07-15.txt
 File size:  11.24 KB
 Downloaded:  770 times
Translated on 09-08-2026, 17:27.
Post15-07-2015, 21:16    Subject: Touran AC Not Working? Troubleshooting Guide Quote
Please update to the latest VCDS version (14.10.2): https://shop.dieselschrauber.de/account.php
Possibly, the actual value will already be displayed then.
Translated on 09-08-2026, 17:28.
StreifLicht
Post16-07-2015, 18:25    Subject: Touran AC Not Working? Troubleshooting Guide Quote
Okay. Thank you. I'll do that right away.
Translated on 09-08-2026, 17:29.
StreifLicht
Post17-07-2015, 6:43    Subject: Touran AC Not Working? Troubleshooting Guide Quote
The actual value is still not being displayed.
But well, the main problem is that it's not getting cool enough.
Post17-07-2015, 11:53    Subject: Touran AC Not Working? Troubleshooting Guide Quote
The (calculated) compressor load of 4.6 Nm is close to zero. Therefore, the control system assumes (and rightly so) that the compressor is not running.
The reason for this should become clear from the shutdown conditions. What do those conditions indicate?
However, I am admittedly puzzled that the compressor's current draw is still above 0A.
Translated on 09-08-2026, 17:30.
dieselschrauber likes this.
Post17-07-2015, 15:43    Subject: Touran AC Not Working? Troubleshooting Guide Quote
I think the system is probably just lacking enough refrigerant.
Here are the specifications for a comparable air conditioning unit, model PA 3C, manufactured in 2007.
With the vehicle at ambient temperature (approximately 30°C), the refrigerant pressure was approximately 8 bar with the air conditioning system still turned off.
 Klimaanlage eingeschaltet.... Laufzeit ca. 3-4 Minuten
 File size:  264.6 KB
 Viewed:  10241 times
 Klima abgeschaltet.... gemessen nach 20 min. Abkühlphase der Anlage
 File size:  273.75 KB
 Viewed:  6692 times
 Fehlerspeicher
 File size:  227.55 KB
 Viewed:  6458 times
Translated on 09-08-2026, 17:31.
StreifLicht
Post18-07-2015, 11:48    Subject: Touran AC Not Working? Troubleshooting Guide Quote
Thank you for the reference values!
I've now experienced the worst-case scenarios. The system is running, but...
"but it's not really getting going." I'm planning to go next week instead.
Let me take a look at the refrigerant. I'll report back later.
-Andreas
 Messung 3 (Vollast( nach 5 Minuten.
 File size:  26.48 KB
 Viewed:  4858 times
 Messung 2 (Teillast) nach 5 Minuten.
 File size:  26.37 KB
 Viewed:  4887 times
 Start. Klima AUS (über Taster)
 File size:  26.18 KB
 Viewed:  5064 times
Translated on 09-08-2026, 17:32.
StreifLicht
Post23-07-2015, 17:16    Subject: Touran AC Not Working? Troubleshooting Guide Quote
Just came back from the "climate control service." They removed 470 grams of refrigerant and 7 ml of oil, and then added 525 ml of refrigerant and 15 ml of oil. The climate control system still isn't working.
The mechanic said, "The compressor is not working."
"But how can the evaporation temperature then be 14°C?" I asked.
Daraufhin hat er das "Anforderungsignal" unter Last gemessen. Die 12 V brechen unter Last zusammen. What now?
Please provide the German text you would like me to translate into English.
Is it the case that in the Touran, the supercharger is constantly running and that the pressure build-up is then regulated via an internal control system?
I'm not sure where to start looking right now...
Translated on 09-08-2026, 17:33.
brezelmann01
Post24-07-2015, 21:31    Subject: Touran AC Not Working? Troubleshooting Guide Quote
Hello!
It depends on what kind of "load" was electrically connected. I would simply measure it in parallel with the control valve. However, it's a PWM signal.
If in doubt, re-wire the cable using temporary connections to check for contact resistance.
Translated on 09-08-2026, 17:34.
StreifLicht
Post25-07-2015, 9:31    Subject: Touran AC Not Working? Troubleshooting Guide Quote
So, the mechanic connected an H7 bulb as a "load" and measured the voltage in parallel with it.
Translated on 09-08-2026, 17:35.
brezelmann01
Post25-07-2015, 9:37    Subject: Touran AC Not Working? Troubleshooting Guide Quote
Nonsense. An H7 bulb has 55 watts. That corresponds to approximately 5 amps. The valve is activated with a maximum of 0.6-0.8 amps when the compressor is at FULL LOAD (or that current flows then). The control unit probably already thought it was heading towards a short circuit. Maybe ask someone who knows about this.
Translated on 09-08-2026, 17:36.
StreifLicht
Post25-07-2015, 15:52    Subject: Touran AC Not Working? Troubleshooting Guide Quote
You wouldn't believe what some German repair shops sometimes have on offer.
My problem is finding someone who really knows what they're doing. I've unfortunately had some bad experiences in the past. That's why I try to understand the issue at least somewhat before going to a workshop – if I can't fix it myself. Otherwise, everyone just guesses and uses half-knowledge, and in the end, I have to pay the bill...
"As you write, I could measure the voltage while the cable is connected. What are the specific measurement characteristics of a PWM signal? Can this be measured with a standard multimeter? Isn't it just a rectangular wave?"
Translated on 09-08-2026, 17:37.
brezelmann01
Post25-07-2015, 16:12    Subject: Touran AC Not Working? Troubleshooting Guide Quote
You won't be able to measure that with a standard multimeter. At least, not in a meaningful way. The frequency is 500 Hz.
Translated on 09-08-2026, 17:38.
StreifLicht
Post25-07-2015, 16:56    Subject: Touran AC Not Working? Troubleshooting Guide Quote
My friend has a digital oscilloscope (ARM DSO203 Nano).
I should be able to measure that with this.
I'm still a bit shocked... someone from the workshop was just telling me that...
that the control signal is not arriving and that I'm facing a very long search.
...can be adjusted in the workshop after encountering any errors.
-Andreas
Translated on 09-08-2026, 17:39.
StreifLicht
Post25-07-2015, 19:41    Subject: Touran AC Not Working? Troubleshooting Guide Quote
... and it seems that important know-how is lacking.
Post26-07-2015, 22:22    Subject: Touran AC Not Working? Troubleshooting Guide Quote
Often, the pressure regulating valve in the compressor is defective! icon_wink.gif You can buy it separately at certain automotive parts stores.
Translated on 09-08-2026, 17:40.
No new posts Doku A3 8P1, Klimaanlage kühlt nicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C air conditioning not cooling General Tips
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AC Not Cooling? Troubleshooting & Repair Tips. Transmission, Chassis, Body & Interior
No new posts Air conditioner not cooling during speed fluctuations Transmission, Chassis, Body & Interior
No new posts Touran AC Not Working: Troubleshooting & Repair Data Diesel Engine Technology
No new posts Air conditioner not cooling - Year of manufacture 2000, c... Transmission, Chassis, Body & Interior
