Pölscheich Blaumann
21-05-2015, 9:06 Subject: Can automatic central locking be disabled? Audi A6 4B |
Hi everyone.
Is it fundamentally possible to disable the automatic locking feature on an Audi A6 4B (C5 model year 2002)?
After a short time (approximately 30 seconds), the car will automatically lock again if it was opened remotely and the driver's door is not then opened. It can be really annoying when, for example, you open the back door, put your bag and keys inside, close the door, and then walk to the driver's side... (I wonder where I learned that).
I would like to disable this function. Can it be done individually?
I would like to keep the other functions of the central locking system, such as the remote closing feature.
Profile PM Email |
21-05-2015, 9:27 Subject: Can automatic central locking be disabled? Audi A6 4B |
You can't disable it; simply repair the corresponding door lock, and the problem won't happen again.  MfG. Michael
Profile PM Garage |
Pölscheich Blaumann
21-05-2015, 9:33 Subject: Can automatic central locking be disabled? Audi A6 4B |
Hi.
"Thank you, I had already suspected that based on my own research. I haven't been able to find anything that quite fits the bill."
Looks like it's time to fix some locks...
Thank you and greetings.
Profile PM Email |
matthiasTDI96 Profi-Schrauber
21-05-2015, 10:03 Subject: Can automatic central locking be disabled? Audi A6 4B |
First, we need to determine who is affected... then, perhaps we can just repair that one (the one on the left rear).
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2400 Karma: +437 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
21-05-2015, 11:51 Subject: Can automatic central locking be disabled? Audi A6 4B |
matthiasTDI96 wrote: | | First, we need to determine who is affected.... |
Here's a simple tip for testing: If a door doesn't turn on the interior light, it also won't prevent the door from being locked again.
Profile PM Garage |
KANE326 Schrauber
25-07-2015, 22:32 Subject: Can automatic central locking be disabled? Audi A6 4B |
When I open the rear door, only the reading light in the front turns on, but not the one in the back. Is that normal?
All the door locks are new.
Wiesel Profi-Schrauber
Joined: 04/06/2008 Posts: 896 Karma: +43 / -0 Location: Schleswig-Holstein
25-07-2015, 23:09 Subject: Can automatic central locking be disabled? Audi A6 4B |
KANE326 wrote: | When I open the rear door, only the reading light in the front turns on, but not in the back. Is that normal?
All door locks are new. |
Does your Octavia do the same thing? It might be normal behavior. Touran 5T1 / DFGA / TGV; Fabia 6Y5 / BNV / GGV
