AWX: Water Pump Failure After 13,000 km!
D.
Post27-03-2003, 22:23    Subject: AWX: Water Pump Failure After 13,000 km! Quote
Hello!
My AUDI (see below) now has a mileage of 11,100 km. Recently, I checked the remaining mileage until the next service. Oh dear, the next service is already due in 1,700 km.
It's not used for extreme short-distance driving, nor for particularly long distances (except for two vacation trips). So, it's used in a completely normal way.
I'm planning a trip for Easter (approximately 2,000 km) and I'm really worried that I might have to go in for a service appointment while I'm on vacation.
Has anyone had similar experiences?
Can I wait until after the vacation?
Best regards, D.
Translated on 09-10-2026, 18:22.
Post27-03-2003, 23:45    Subject: AWX: Water Pump Failure After 13,000 km! Quote
Normally, the WIV 3000 system warns you about the upcoming service 3000 km in advance, or is it different with Audi?
However, if the car is frequently started in cold conditions, then the interval is acceptable.
Translated on 09-10-2026, 18:24.
D.
Post29-03-2003, 11:07    Subject: AWX: Water Pump Failure After 13,000 km! Quote
The vehicle was neither 'revved' when cold, nor did the upcoming service warning appear before reaching 3,000 km.
After the vacation, I have an appointment with the 'friendly' people who want to check the 'coding' for the WIV.
In the latest issue of 'Gute Fahrt,' it was reported that WIV (Vehicle Identification Number) is only possible for vehicles with the code QG1 in the data carrier.
I'm going to check that right away.
Keep you updated.
Best regards, D.
Translated on 09-10-2026, 18:25.
D.
Post29-03-2003, 17:54    Subject: AWX: Water Pump Failure After 13,000 km! Quote
So, I just checked the owner's manual. When you turn on the ignition, it should display a reminder for a few seconds if the next service is less than 2,000 kilometers away.
My service is supposed to be due in 1,700 km after the last one, but I haven't received any notification on the display yet.
Best regards, D.
Translated on 09-10-2026, 18:26.
Manuel Thomas
Post18-04-2003, 21:57    Subject: AWX: Water Pump Failure After 13,000 km! Quote
The shortest recommended oil change interval for this vehicle is 15,000 km or one year, whichever comes first.
Your workshop probably coded something incorrectly!
Manuel.
D.
Post10-05-2003, 10:29    Subject: AWX: Water Pump Failure After 13,000 km! Quote
So, I finally went to the 'friendly' place yesterday.
Channels 42, 43, and 44 were read.
According to the 'experts,' everything was fine.
However, no one could explain why, given the mileage of 13,000 km, the remaining distance should now be limited to a maximum of 600 km.
I was then advised to ignore the warning light and to change the oil sometime in the fall. It wouldn't hurt to do that.
I then went to another Audi dealer because I wasn't satisfied with the answer I received.
However, the (Audi Center Braunschweig) only listened to the history being described. No one wanted to actually look at it. They simply stated that it was a dynamic interval and that the total distance was perfectly acceptable. If an oil change is requested, then I should just have it done.
I don't quite understand that.
I'll wait and see for now.
Best regards, D.
Translated on 09-10-2026, 18:28.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Problems with CAYC After Just Over a Year Diesel Engine Technology
No new posts ASZ and clutch worn out after only 28,000 km? Diesel Engine Technology
No new posts AHU engine in Caddy experiencing issues at nearly 400,000 km Diesel Engine Technology
This topic is locked, you cannot edit or reply. Timing Belt Replacement: When to Change at 60k Miles? Diesel Engine Technology
